Question about Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator
Dispensed water tastes like plastic - Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator
  • Liz Thomas
    Liz Thomas Oct 24, 2013
    I have had my Kenmore Elite for several years and have not any problems with the taste of the water. I replaced the filter recently and a couple of weeks later noticed the water tasted like plastic. I took the filter out, flushed the dispenser, and it still tastes like plastic. Solution?
    Problem Solver:
  • 5 Answers
If the refrigerator is new, or if you used PVC cement, it's normal to get this taste for a few days. Take water out but not for drinking in the next days.
Posted on Oct 24, 2013
3 Suggested Answers
huuum
  • 750 Answers
SOURCE: Bad water & ice cube taste
Hello redwood City
Welcome
You said,
Your Kitchenaid Superba KSRG25FKBL15 has bad tasting water and ice cubes. You replaced the copper tubing which delivers the water to the fridge and that didn't help. You replaced the copper tubing again with plastic tubing...no better. Any suggestions? Your tap water doesn't taste this bad.You bought a Kenmore french door fridge with water dispenser in the door in July 2008. The fridge has a filter. A few weeks after the fridge came the water and ice started tasting really bad, unlike any bad water taste I have ever tasted. And your tap water is fine. The bad taste appears to be random. Sometimes you get a cup full of nasty water and sometimes it tastes fine.
First you must know you have a 1 year warranty and can have them come out to fix anything, no charge.If it persists. You will have to get tough and you , MUST INSIST THEY REPLACE YOUR FRIDGE
When installing the water line these were a part of the directions!
Did you do this before connecting the water line to your fridge?
"Place the free end of the tubing in a container or sink, and
turn ON the main water supply. Flush the tubing until water is
clear. Turn OFF the shutoff valve on the water pipe. Coil the
copper tubing."
Whirlpool remedy
Off-taste, odor or gray color in the ice
1.Are the plumbing connections new, causing discolored or
off-flavored ice? Discard the first few batches of ice.
2.Have the ice cubes been stored too long? Throw old ice
away and make a new supply.
3.Does the freezer and ice storage bin need to be cleaned?
See “Cleaning” or “Ice Maker and Storage Bin.”
4.Has food in the freezer or refrigerator been wrapped
properly? Use airtight, moisture-proof packaging to help
prevent odor transfer to stored food.
5.Does the water contain minerals (such as sulfur)? A filter
may need to be installed to remove the minerals.
6. Is there a water filter installed on the refrigerator? Gray or
dark discoloration in ice indicates that the water filtration
system needs additional flushing. Run additional water
through the water dispenser to flush the water filtration
system more thoroughly (at least 2 to 3 gal. [8 to 12 L] or 6 to
7 minutes initially). Discard discolored ice.
Let me know what works,
Thank You ,
HUUUM!!
Please remember to leave a rating.
Posted on Oct 12, 2008
  • 531 Answers
SOURCE: Taste of water from water dispenser has "plastic taste"
you have to flush dispense water on till taste gone
Posted on Apr 02, 2009
Whirlpool Gold Series Refrigerator has foul tasting water and ice.
and what does the water elsewhere in home taste like .is it city water or well water . usually you can take a sample to local health dept and they will test it free .
May 20, 2015 | Whirlpool Refrigerators
Our Sub-Zero Mdl 680F is 11 years old, and virtually for its entire existence in our house, the water and ice dispenser has been un-useable because they taste bad. The taste was "oily" almost as...
Hello
Change the supply line to the plastic tube line or copper. Do not use a braided plastic or metal braided line these will make the water taste bad. Changed mine to the plastic line and cured mine, no filters needed.
Replace the water filter cartridge in your refrigerator if the ice tastes bad or the control center display recommends it.
Sep 07, 2011 | Sub-Zero 680 / F
Plastic taste in water dispenser Fridigaire Gallery series
You need to replace the entire plastic tubing from the solenoid water valve all the way to the water dispenser. That is your best chance.
Dec 17, 2010 | Frigidaire Refrigerators
There is a bad order coming from ice and water dispenser. I changed the filter but it didn't help. Smells like ''dirt''. Thanks, Linda
Replace water supply line with the plastic tubing ice maker line. It fixed mine that had a metal braided line on it that made the water taste kie rubber and dirt,, after that I tried a vinyl braided line.and it made the water taste like garden hose water.. The plastic tubing was the cure. Reply and tell me what you have.
Mar 24, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Terrible Plastic After-Tast in Dispensed Water (Refrig)
If indeed it is stagnant water you have to find the water source tap off of your water supply. Then trace out the routing of the feed water line to your refrigerator. Turn off the tap, remove the line at both ends. You can abandon the existing line. Reroute the new line. or you can remove the old line and follow the same route. Reconnect the tap and refrigerator ends.
Jul 14, 2009 | Refrigerators
My new Whirlpool Refrigerator the water and ice still stink
Dec 19, 2008 | Whirlpool 25.6 cu. ft. Side-by-Side...
Water Tastes Funny From Sub Zero Dispenser
It will take about three to four months of using it before the plastic loses it freshness into your water. It has to dissipate the "New Car/Plumbing Smell" so to speak. It.s a normal unpleasant necessity but on the bright side... it does go away with use.
Sep 18, 2017 | Sub-Zero 685/S Stainless Steel Side by...
Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator Logo
41 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
Jim Goldsmith
Jim Goldsmith
jackdo2
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
