Pc will not start up in windows - Computers & Internet
  • 27,725 Answers
WARNING: Before you start troubleshooting remember that you are dealing with electricity that can KILL.
http://www.kitchentablecomputers.com/static.php - rules
Only work inside the computer case when the power has been switched off and disconnected. Never open the power source.
Some of the below steps recommend removing physical parts within the computer.
While in the computer it is highly recommend that you be aware of ESD and its potential hazards
Remove the memory modules from their slots.
Take the opportunity to clean the slots on the motherboards and the memory module connectors.
Use compressed air to blow dust away and clean contacts with a soft cloth.
Do not use a metallic vacuum cleaner if it touches any component it may create a short and cause damage to the motherboard or other components.
Do not use solvent that may attract dust and never poke things like cotton buds in to slots. lightly rub an alcohol (Methylated Spirits) on a cloth not to hard let the alcohol do the work on the copper gold or silver tabs and r
Allow the pins to dry.
They will air dry in a matter of minutes.
If reseating the memory did not resolve the issue try swapping the location of the memory.
If you have only one stick of memory in the computer try moving it to another slot and then boot the computer.
Check the memory module and memory slot contacts.
They are either copper tin or gold.
The colour will tell you which they are.
Mixing tin and gold can result in corrosion that prevents proper contact.
Look for any sign of physical damage to the memory module, memory slots or the motherboard.
Reseat the memory modules.
You should hear an audible click when they are in place.
Do not use too much force to reseat the memory module in to the slot this can cause damage to the module, slot or motherboard.
The hardware that you are trying to access is damaged or failing.
The device drivers for the hardware are faulty or incompatible.
Could be a problem with the Hard Drive or the Hard drives PCB
http://www.onepcbsolution.com/
http://www.youtube.com/watch?v=du0Qd_3wFWM
There is a connection problem such as a bad cable
for internal hard drives
Test all power and data leads that attach to your hard drive IDE,SATA
the leads from your MOTHERBOARD TO THE HARD DRIVE make sure they have a
secure dust free connections and are not faulty or just replace them they could be faulty if its a flat 40pin ide
this will be the first to fail
Make sure all leads that are attached to your drives dvd\cd and floppy (If Applicable) have secure connections and are not faulty.
or just replace them they could be faulty a computer needs power and data to travel through every working device and continue its cycle and have an end so any faulty leads will end up with a computer error
Posted on Oct 22, 2013
    Problem Solver:
  • 6 Answers
Check to ensure your BIOS is pointed to start on the Hard drive..
Hard drive may be corrupt..
many other possibilities, we need more information
My pc with windows 7 ultimate got stuck on the startup. usually, when you start the pc, "starting windows and windows icon" appear and after that, welcome and your desktop. but in my case, ONLY the...
Back up all data and re-image the computer. You can either use a windows 7 disk or create a bootable usb. there is likly a problem with the boot manager.
Sep 22, 2013 | Microsoft Windows 7 Ultimate for PC
My dell inspiron 2200 wont start up..Well it starts up but then it sais "Windows start up has failed." and it gives me options to start up in safe mode with command promt and safe mode with networking...
Boot your PC with the windows OS disk and choose to repair your computer when asked. Run the chkdsk program in DOS on the recover mode to correct disk errors.
On completion, restart your computer normally and check it it works.
If it does not work, you may need to format your pc & reinstall windows again.
Aug 02, 2010 | Dell Inspiron 2200 Notebook
I have picture publish 7 cd but it will not load on windows 7
right click>properties>compatibility>change to another version of windows and run as admin. or rightclick the setup file on the disk and hit run as admin.
Dec 10, 2009 | Micrografx Webtricity 2.0 Full Version for...
PC keeps booting but doesn't start up
Easy fix! Put the windows boot disk in the optical drive. It will either start up of you can re-install windows. Easy Solution!
Jan 27, 2009 | Dell Dimension 2400 PC Desktop
Windows will not start up
choose start windows in Safe mode, if it starts then everything will look big, don't worry about that for now. Then go to Start>accessories>system Tools>system restore and choose a date when you know that everything was working normally, when it has finished restoring the computer will restart. If asked choose start windows normally.
I hope this helps
Nov 25, 2008 | Sony VAIO V2M (VGCV2M) PC Desktop
Xp caught in loop when started
the Windows Operating system is corrupted.
what operating system are you running??
Windows VISTA or XP??
Nov 04, 2008 | Dell Dimension 2400 PC Desktop
PC won't Start windows normally
You can attempt to undo this through the use of System Restore.
I am going to assume you are on Windows XP, So start your computer in safe mode without networking.
Once you are in the desktop you are going to use System Restore. Choose a date in time on your computer before the incident happened.
For more information on the system restore utility go here:
http://www.microsoft.com/windowsxp/using/helpandsupport/learnmore/systemrestore.mspx
Note : If you have Windows Vista ,read about this utility here:
http://windowshelp.microsoft.com/windows/en-US/help/9f6d755a-74bb-4a7d-a625-d762dd8e79e51033.mspx
Aug 20, 2008 | Computers & Internet
After i load ssp2 my computer does not open window program
What is 2.2 frame?
Do you mean .Net framwork 2.2 update from microsoft?
Press & hold the power on button on the E-Machine. That will shut down the PC. Unplug the power cord from the power supply. Wait a minute. Re-connect the power cord to you're PC & press the power button on you're PC. Windows should start & may run check disk before loading windows. Continue updating windows through windows update service. There are more
.Net framwork updates. If you're system continues to run restarting shut it down as before. This time when you start up the PC start pressing the F5 key every two seconds. Windows Advanced Option Menu will load. Choose Safe mode. Open control panel, open add/remove programs. At the top of the window & slightly to the right of the Add or Remove Programs windows is a box next to Show Updates. Left click in the box. Scroll down & find .Net framwork 2.2 & uninstall it. Close all opened windows & restart the PC.
Continue to update you're windows.
Please let me know if this has helped.
Good Luck!
Mike
May 08, 2008 | E-Machines eMachines Desktop PC
PC constantly reboot
try run windows in safe mode. then scan for virus infection.
Mar 10, 2008 | Lenovo 3000 J Series 1.80G VBE PC Desktop
Computers & Internet Logo
18 people viewed this question
David Payne
David Payne
