Hp laserjet p1102 52.0 scanner error solutions
  • 65 Answers
Hi.
Please make sure your printers powercord is connected directly to a wallsocket, NOT any kind of extentioncord. Also try updating the printers firmware.
I've attached a couple of links for you to look through, and I'm sure they will point you in the right direction.
Blinking Lights
Firmware
Check for HP Warranty
Service Manual
Good luck.
Posted on Nov 23, 2013
4 Suggested Answers
SOURCE: HP LaserJet 2840 Scanner Error
when poering on this HP 2840 it says" Scanner Error 5"
what does it mean? How to get a solution?
Posted on Aug 06, 2008
haivanko
  • 37 Answers
SOURCE: error 6 hp laserjet 1120 mfp
The problem is that the motor that drives the scanner probably overheated and because of the cheap plastic that HP used it melted important points that the motor relis on...so - remove the glas of the scanner(there are some screws - one of them hidden under the label of the panel,unhook the interface cable of the panel).Now you should see the scanner - flip it over and look at the motor exle and the gear that it should mesh with - they are not aligned at this time.To fix it i used 2 small pieces of plastic - sticked it under the motor so that it can not move in vertical direction anymore. Simply this is the solution that i used and it works just fine :) If you have any questions dont hesitate to contact me. alpescomputers@winetbg.com
Posted on Jun 15, 2009
SOURCE: SCANNER ERROR 20 of HP LASERJET M1120 MFP
PRINTER: HP DESKJET M1120 MFP DISPLAY SCREEN SAYS; "SCANNER ERROR 20"...
ANY IDEAS HOW TO FIX?
MANY THX!
Posted on Feb 04, 2011
How to solution scanner error 17 in hp m1005
HP LaserJet M1005 Mfp driver pls check the scaner lamp is moving or not i f not pls replace the scanner cable
Jan 09, 2017 | HP LaserJet M1005 Printer
How to fix scanner error 6?
herewith 3 suggestions (try searching the HP forum or search engine 'scanner error 6'). Read all of them before you decide to do anything and only then decide which order if any to do them depending on ease vs likely effectiveness.
HP LaserJet 3055 Scanner Error 6
HP Laserjet 3055 Scanner Error 6
6.July.2015
Jul 06, 2015 | HP LaserJet 3052 All-In-One Printer
Scanner 12 error
HP LaserJet M1005 mfp is not work properly. printer show scanner error 12 ple. solution
Nov 08, 2012 | HP LaserJet M1005 All-In-One Printer
Error 22
Go to hp website and look for firmware update. The model M1217 had the same issue which was fix in a firmware update.
Jun 07, 2012 | HP LaserJet Pro M1212nf MFP -...
Why hp laserjet m1005 printer are scanner error 6?
Replace Scan head mechanism(while scanning or copying there is a part called scan head moves right to left with light fails to move due to mechanism breakage). For reaching this unit you need to remove flat bed glass. Pl see the snap shot for easy identification:SCAN HEAD:
3_30_2012_9_11_30_pm.jpgSCAN HEAD MECHANISM
Mar 29, 2012 | HP LaserJet M1005 Printer
Hp 1005 Scanner error 20 please suggest the problem
Turn off the power by using the power switch, wait at least 30 seconds, and then turn on the power and wait for the device to initialize.
If a surge protector is being used, remove it. Plug the device directly into the wall socket.
Use thepower switch to turn the device on.
Jul 08, 2011 | HP LaserJet M1005 Printer
MANY THX!
Mar 10, 2010 | HP LaserJet M1120 MFP All-In-One Printer
Scanner error 6
most likely dust on the scanner optics causing scanner to be unable to go to home position. Solution would be to disassemble scanner assy and clean optics or replace scanner assembly.Note HP service manual says to replace scanner assy.
Dec 16, 2008 | HP LaserJet 3055 All-In-One Printer
HP Laserjet 3055 with "scanner error 6 - turn off and on" error
hp laserjet 3055 by scanner error 6
Solution: I found a very small piece of paper between the glass and the scanner housing. The lamp's seen that and sent the error message. Nobody find that little stucked paper and the "IT expert" sad: need to buy a new machine because he can't repair it. So, sometimes the solution is very easy just need some attention. :)
Apr 27, 2008 | HP LaserJet 3055 All-In-One Printer
HP Laserjet 3052
i am getting scanner error 5 in my hp laserjet 3052, pls giv me the solution for the same
Jan 29, 2008 | HP LaserJet 3052 All-In-One Printer
948 people viewed this question
jasbo
jasbo
