Question about Barbeques Galore Grilling
Four seasons fs388lp replacement parts - Barbeques Galore Grilling
2 Suggested Answers
SOURCE: I need the assembly instructions for a Four Seasons Gas Grill
I purchased this grill and assembled it yesterday. I noted the area that is providing confusion as it is wrong. Please follow the following instructions. It is quite simple when you have a background in electrical and electronics engineering. These directions should translate my knowledge into step by step instructions for all.
1. Attach the two thinner wires with two terminals on each wire, from the front of the grill head to the larger (Input or Control) terminals on the igniter assembly. These two wires are from the push to turn micro switches on each of the burner control knobs on the grill head. Attach the two smaller terminals on these thinner wires to the micro switch on the side burner control connected as part of the regulator and hose assembly.
2. Attach the three thicker wires from the front of the grill head to three of the six smaller (output) terminals on the igniter assembly. These wires go to the igniters themselves.
3. Connect the two thicker wires from the rear of the grill head to two of the six output terminals on the igniter assembly. The small wire is for the igniter on the bottom infrared burner and the larger, thermally insulated wire, connects to the igniter on the rear infrared burner.
4. Connect the lead from the side burner to the remaining small output terminal on the igniter assembly.
5. Mount the igniter to the front of the right side shelf by removing the battery cover and hexagonal nut. Insert the shaft through the hole in the front of the right side shelf and secure with the hexagonal nut. Replace the battery cap. Do not install the battery at this time.
6. Mount the side burner control by inserting the long end of the control into the side burner assembly. Attach the control to the front of the right side shelf with the two screws held in the front of the control assembly. NOTE: You must remove the screws from the control assembly and insert them through the Off/On bezel and front panel of the right side shelf before screwing them back into the control assembly. Install the control knob for the right side shelf. Verify that the connections to the side burner control micro switch made in step 1 are still intact.
7. Insert the battery into the igniter assembly by removing the batter cap and inserting the AA size battery with the positive (pointed) end out. Replace the battery cap.
8. Test the igniter assembly prior to installing the gas tank and installing the “Flame Tamers” and grates by pushing in on each burner control knob in turn. Listen for a popping sound and look for sparks at each burner.
I hope this helps.
Ed Roberts
President
E. F. Roberts & Associates
www.efrobertsassoc.com
Posted on Apr 09, 2009
Why are season four's episodes an hour long?
The Twilight Zone was about to be canceled after the third season, because Rod Serling took up teaching. However, at the half of the next season (1962-1963) another CBS show was canceled and TZ was put in it's place as a replacement. Because this show was an hour long, new TZ episodes had to be produced in this format. The resulting hour-long episodes are generally considered weaker, save for a few exceptions. This was due mostly to episodes becoming overly padded in their hour-long running time. The experiment was considered a failure, and the next (and final) season, the show returned to its original format.
Sep 04, 2016 | The Twilight Zone (1959)
Lights went out casablanca fan
I never saw a Four Seasons fan with an Intel touch control and I've been in the fan business for over 20 years. What is the actual model #?
Feb 14, 2014 | Dryers
How far is four seasons in mumbai from nariman point area?
there are many hotels in nariman point itself
Apr 26, 2013 | Cars & Trucks
How much is a blower moter for my 1999lumina
TYC Part # 700076 {#19153679, 52498954} AC Condenser Blower Assembly
us.gif ca.gif Front700076_1.jpg* Stocked in outlying warehouse--shipping delayed up to 1 business day$38.79
ACDELCO Part # 158600
us.gif ca.gif MOTOR,BLO(W/IMPLR) [Wholesaler Closeout -- 30 Day Warranty] (Only 2 Remaining)15-8600.jpg$39.79
VDO Part # PM3799
us.gif ca.gif w/Blower Whl. (Only 2 Remaining)pm3799-front.jpg$41.79
us.gif ca.gif w/ Wheel; Use when replacing a two terminal motor35352rsid.jpg$48.99
us.gif ca.gif MOTOR,BLO (W/IMPLR) 4 DOORS15-81104_primary.jpg$51.89
ACDELCO Part # 1580467 {#52498954}
us.gif ca.gif MOTOR,BLO(W/IMPLR) 4 DOORS [Wholesaler Closeout -- 30 Day Warranty] (Only 3 Remaining)15-80467.jpg$64.79
Jul 08, 2012 | 1999 Chevrolet Lumina
A/c discharge hose nissan pathfinder'01
Mar 26, 2012 | Cars & Trucks
The air is lukewarm only, and i am freezing!! The heater control valve appears to be the culprit, but how difficult to replace?? I know very little about cars, but can not afford 1 $700 repair either....
tell me how u checked this valve? is the water hot going in and out of it. it is sandwiched into the hose going to the heater core under the hood, it costs $28, so where does the $700 repair come from? here is a picture and a part number for the valve, it is very easy to replace, just tow hose clamps.
FOUR SEASONS Part # 74649
US Built
Dec 18, 2009 | 1998 Honda Accord
I have a 1996 geo tracker I cant get the compressor to run I have relpaced the compressor relay which dosent help. freon is ok compressor cluch kicks in when direct wired.
does the compressor run when bypass the compressor thermal cutout switch on the compressor? here is the part number and a picture.
also does it run when u bypass/jump the compressor cycling switch? it is located in the low side of the sytem, thios is the line that is the larger of the two, hwere is the part # and picture.
1. compressure cutout switch (3 diff ones used)
FOUR SEASONS Part # 35756
Compressor Mounted Cut-Out Switch; 1 Term White
type two
FOUR SEASONS Part # 35973
Compressor Mounted Cut-Out Switch; 2 Term; Blue or Green; Low Pressure
type 3
FOUR SEASONS Part # 35970
Compressor Mounted Cut-Out Switch; 2 Term; Yellow
d2d2a20.jpgthis is type one and two, two wires.
next is type 3 one wire.
06d325f.jpg Next is the low side compressor cycling switch, most common problem.
ACDELCO Part # 155606 {#96069320}
SWITCH,A/C CYCLING
Nov 02, 2009 | 1996 Geo Tracker 2 Door
DOES A 96 JETTA HAVE A ORIFICE TUBE OR A EXPANSION VALVE
it has an expansion valve, here is the part number.
FOUR SEASONS Part # 38670 Price $31.79 Source: www.Rockauto.com
Jun 29, 2009 | 1996 Volkswagen Jetta
I hope this helps.
Ed Roberts
President
Mar 19, 2009 | Grilling
Grilling Logo
128 people viewed this question
Top Barbeques Galore Grilling Experts
paulcarew
Gary Kenady
Gary Kenady
Dan Webster
Dan Webster
Are you a Barbeques Galore Grilling Expert? Answer questions, earn points and help others
