Question about Baumatic B904SS Stainless Steel Electric Double Oven
Main oven 25w lamp keeps ''blowing'' - Baumatic B904SS Stainless Steel Electric Double Oven
Replace light inside oven
Switch oven off and switch main oven switch on wall off if no wall switch, switch off at main switch board.
Open door and check glass cover if it screws off or has retaining screws. be careful as it could be hard to loosen, once loose unscrew lamp anticlockwise slowly as lamp my break off base if tight move side to side very little and unscrew. get replacement and replace opp to removal. Switch on main switch and test.
Oct 17, 2014 | Ovens
Unable to remove light cover inside oven
I'm not familiar with that oven model, but as I have had a similar issue with my Neff oven light, I thought I would give you the benefit of what I had discovered. The light cover in my oven is a round, thick glass cover. The hand book has a graphic showing that the cover is simply twisted with one hand in an anti-clockwise direction as viewed straight onto the cover. No way! The first issue is that the lamp housing is right in a tight corner and getting sufficient grip on the cover is tricky. I put rubber gloves on to increase the grip and resorted to using two hands to exert as much force as I could manage, but it only moved a small amount. I think the movement was only the entire lamp housing moving in the oven wall, rather than any movement of the cover. I tried warming up the oven (not too hot) in the hope that the cover might release due to expansion, but no go. I then wondered if cooking grease / deposits and bonded the cover to the holder; although it appeared reasonable clear. This appears to have been the issue as I applied WD40 to the seam where the glass meets with the lamp housing and left it for a few minutes. It needed a second application, but eventually came free. On inspection, there was only a minor 'varnish' on the glass that appeared to have prevented the two parts from moving. Using WD40 weakened the bond eventually, but it also made the glass incredibly slippery, so gripping the glass cover after application is difficult. I used the rubber gloves and wiped the glass well to remove any residual WD40 prior to attempting to twist the glass cover off.
Oct 06, 2014 | Neff Ovens
Zanussi oven zbf 360 + bulb blows repeatedly
bulbs blow from incorrect voltage in use or loose ground wires ( arcing out)
if they fail while the oven is on it is because the bulb construction glass is wrong
bulbs used in ovens need a special heated treated glass and are generally only available from the service agent
failing immediately on turning on indicates a bigger problem that the bulb so call in an electrician to test the system
Mar 24, 2017 | Zanussi ZBF360 Electric Single Oven
Good Morning Is there a charge for getting your assistance on the type of bulb is in my Stoves 720EF Heritage oven ? Thanks
The only charge for this information is your appreciation and continued future use of FixYa. The bulbs you need are known as "Pygmy" bulbs. The correct size for your model is E14 and is 15W for the top oven/grill or 25W for the lower main oven.
You can buy these in most DIY shops - all the sheds - Homeback, B&Q and Wickes - sell them as well. The best thing to do is remove the old bulb/s first and take them with you to make sure you get the correct one. If they've been in there a long time, it can be quite difficult to unsscrew the the bulb cover/lens.
Hope this helps. Please let me know if you need further assistance.
Your total FixYa bill is £0. Bulbs will be about £3-5 each.
Regards,
BElectric
Feb 16, 2011 | Ovens
Looking for a manual for Whirlpool BS0801/WH oven
I have a paper copy of the manual - if you need to know anything more than the information below post a more specific question.
The function symbols on Knob F, clockwise from the top, are as follows:
  • 0 = Off
  • Lamp symbol = Lamp Only, no fan, no heating.
  • Fan + Drip Symbol = Lamp + Fan, but no Heating - this is for defrosting.
  • Fan inside a Circle symbol = Lamp + Fan + Oven Heating - this is the normal cooking position. The temperature of the oven is set on the Temperature Knob.
  • Final position = Grill. The temperature of the Grill is set on the Grill knob.
The red indicator light only comes on when the Oven is heating (not the Grill), and goes off when the oven has reached it's set temperature.
The bulb is 25W 230V Type E-14 300 Degree C.
The oven draws a maximum of 2300W so requires a 10A supply.
Nov 29, 2010 | Ovens
My light bulb keeps blowing i have replaced it twice with a 25watt and as soon as i switch it back on the bulb blows
Perhaps you have up to 240 V on the lamp socket and you are installing a 120V bulb. Check for wiring faults, especially an open neutral or ground connection in the oven. If the lamp socket neutral is connected to the neutral on a lower-resistance device on the other leg, but the wire connecting these two items is not connected to the power cord neutral, the voltage across the bulb will be more than it can handle. In this scenario, the other device (heating element, timer, or whatever) will probably not work or will work poorly after the bulb blows.
Nov 04, 2010 | Smeg SE210X/1 Stainless Steel Electric...
How do you change light globe in simpson evolution 904 oven
The glass cover definitely unscrews anti-clockwise, but mine was impossible to start moving by hand. I used a pair of adjustable pliers and while the glass cover is made out of pretty thick glass, I didn't want to be squeezing it so I set the pliers jaws to exactly the same width as the glass cover. Because the glass cover has 4 bumps set around it, the pliers jammed on them so I was able to unscrew it.
BTW, the globe under the cover is also a screw mount job - if you're looking for a replacement, keep in mind that it has to be a max of 25W.
Oct 26, 2010 | Ovens
Oven blowing main how fuse
Probably faulty oven element, as it gets hotter, then the insulation resistance is probably breaking down.
Disconnect element, and try it again, if it does not blow, then replace element.
Please rate my solution.
Thanks.
Aug 16, 2009 | Ovens
Cannot find interior light or its switch on Miele H251 oven
so remove metal skin on the right hand side of interior....little pip holds it in place...so shove up.
then just prise glass section gently outwards....4 clips hold this in.
bulb is a PHILIPS 25W X7L
300o H.D.
Apr 01, 2009 | Ovens
Baumatic B904SS Stainless Steel Electric Double Oven Logo
16 people viewed this question
Top Baumatic Ovens Experts
ashburton
Dennis Boxerman
Are you a Baumatic Oven Expert? Answer questions, earn points and help others
