Question about LG LFC22740 Bottom Freezer French Door Refrigerator
Closing clam on door broke-how to replace - LG LFC22740 Bottom Freezer French Door Refrigerator
Hp laserjet 6500 how do I close clam shell? (E709a)
some machines have a support leg that needs to be tripped to close them
May 22, 2015 | HP Office Equipment & Supplies
How can I clear the Lanier 6112 "used toner" on the display?
Open the front door, lift the clam shell open and carefully replace or empty the white used toner container. Replace and turn the blue knob clockwise a few times.
Aug 03, 2014 | Lanier Compatible Copier Toner Black For...
Not working
open the front door to the copier release the clam shell so you can see inside the machine gently but firm close the machine and shut the front door have a feeling the interlock switch is not in the right position
Feb 19, 2014 | Toshiba 1360 Black and White Copier
2002 F-250 door not register that it closed
The sensor is inside the door and is part of the latch to close the door. It has either come loose or is broke and you will need to replace the actual latch inside the door that keeps the door closed.
Mar 19, 2010 | 2002 Ford F250 Super Duty SuperCab
Fuel door lever broke
YES THE DOOR COMES AS AN ASSEMBLY
Mar 16, 2010 | 2005 Jaguar S-Type
Door locks flipped around and now doors will not close
Most likely your door latch is broken and needs to be replaced. First, try to use a screwdriver and see if the lock jaw will reopen and when door is closed, if it will work properly. If it will not open or does not keep the door closed, it is broke and needs replacement.
Oct 01, 2009 | 2002 Kia Rio
My washing machine works most of the time but sometimes i need to push the door really hard a few times to get the cycle to start. Today it broke down half way through cycle, got it going again then the...
Hi
Seems like the door switch is failing, or failed.
wpecially if a front loader, the door has to be closed, and register on the circuit as closed before the machine will start.
they are cheap and easy to replace, most of the time, but cant give instructions for an unknown whirlpool other than
take front panel off
replace door switch
replace front panel
Sep 21, 2008 | Whirlpool Washing Machines
Top will not close!
Is the hinge busted or can you snap it back into the holder?
Nov 01, 2007 | HP Photosmart 3210 Printer
Broken hinge
It is a snap together construction. a fine blade along the seam perhaps But if you have doubts about that I certainly would have- How about Gaffer tape? I have made many hinge type repairs [not a lappie admittedly] on stuff like the tool cover on a vacuum cleaner- it gets tacky after a while and will need replacing- but far better that trying to rip a clam shell apart.
Jun 13, 2007 | Acer TravelMate 508DX Notebook
LG LFC22740 Bottom Freezer French Door Refrigerator Logo
26 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Mike
Mike
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
