Question about Zebra S4M Thermal Label Printer
LCD said "Head Ele. Bad". After reconnecting the printhead, the massage was gone, but now the printer isn't printing anymore, just empty labels with some black points sometimes. Do we need to change the printhead?
  • 96 Answers
The message shows the printer was powered on with printhead disconnected. The print head is bad and needs to be replaced. Make sure power is off during the installation or it could damage the new printhead.
Posted on Nov 06, 2013
2 Suggested Answers
  • 38 Answers
SOURCE: Printing solid black across the label.
Sounds like a defective printhead.
Reinstall the old one to see if the problem remains or not.
Steve
Posted on Jul 17, 2008
Printhead error #768
The print head problem occurs if the drain tubes being clogged and is preventing the pump from sucking the ink out of the print-head. It could also happens if the ink lines allowing air into it.
There are few troubleshooting steps in trying to fix this issue. Click here for a detailed checkup.
Oct 19, 2011 | Paxar Monarch 9850 Thermal Printer
The labels from one of our heat sensitive label printers are unreadable by our barcode scanners.
Unreadable labels are related to the print head, make sure to clean the print head thoroughly with an alcohol swab and make sure the platen roller is clean also. After cleaning and it still is having issues scanner than you have bad sectors on your printhead.
Hope this helps.
Apr 14, 2011 | Zebra Desktop DA402 Label Printer
I have a zebra zm400 prinetr givig me an error message (head element bad)
turn printer off, press PAUSE button, turn printer on and wait 5 seconds then release the button. The printer is going to print the test label, check if coming some withe lines across the print. try to clean the printhead and the rollar, if pressist, need to replace printhead.
Please check if the cable from the printhead is totaly plug-in
Oct 15, 2010 | Zebra 105SL Thermal Label Printer
I just changed out the print head and upgraded to a 300 dpi print head. Now when I print onto my label (2.5" x 0.75") label about 1/4" at the top of the label is not being used. Is there a configuration...
mmm...didn't think the printheads were interchangable. But the print will be smaller using a 300dpi printhead if you send a format that was designed for a 203dpi printhead. This is because the dots are smaller on the 300dpi. Make sure your formats have been switched to the 300dpi driver.
Hope that helps !
Apr 14, 2010 | Zebra Z4M Printer
When printing a label on the lp2844 the label look faded
This is very little info, but I will try.
First, have you cleaned the printhead, if not procede as follows: -
Open the printer and with a soft cloth dampened with Isopropyl Alcohol or any clening alcohol gently rub the printhead to remove any built up dirt. If you look closely at the printhead elements, you may be able to see and feel with the pad of your finger any build up, continue to clean until it has gone.DO NOT UNDER ANY CIRCUMSTANCES USE A HARD OR SHARP OBJECT TO CLEAN THE PRINHEAD AS THIS WILL DESTROY IT.
Try the print again to see if it has improved.
If not then adjsut the print head heat/contrast settings from either the printer driver or the software you are using to make the labels.
Feb 11, 2010 | Zebra LP 2844 Thermal Printer
Cant scan to computer
Unfortunately many of the All-In-One devices are like this. If the Cartridges are installed but empty the system is reading that fault code as the Cartridges not being installed. Even though you are not using the ink the printer is most likely doing a light head cleaning when it cycles. Replace teh cartridges and it should clear up.
Aug 27, 2009 | Canon PIXMA MP470 All-in-One Printer
Attempting to print labels from a Monarch 9855 printer and receiving error message: "Print Head error 768." Printer was working fine as of last Friday. We have other Monarch 9855 printers that are on other...
the problem is your printhead is bad . do a print test by presing both arrow buttons at tah esame time for two seconds, look fo rthe line that reads bad dots. if the value i sgreater than 000 yu have a bad printhead
jay
Jun 08, 2009 | Monarch Paxar? 9855 Label Printer
Brand New but does not work
If it is truly a brand new printer, call the place of business where you purchased it and give them the error message. They will take it back as warranty and get you a new one. Either the printhead is bad, or there is a problem with the MLB.
Apr 01, 2009 | Zebra S4M Thermal Label Printer
Steve
Jun 25, 2008 | Zebra 105Se Thermal Printer
Jakost@perfect-carpets.cz
that means that your print heads are on overload..the power supply may have gone bad
Mar 20, 2008 | Intermec EasyCoder 501e Label Printer
Zebra S4M Thermal Label Printer Logo
158 people viewed this question
Top Zebra Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
CheckitRight
CheckitRight
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
