Question about Sanyo Refrigerators
Sanyo refrigerator not working properly - Sanyo Refrigerators
    New Friend:
  • 27 Answers
Try cleaning the back of it, the compressor area.
Posted on Oct 22, 2013
How do i properly relocate my sanyo mini fridge from one place to another?
No, if you let it sit upright for 24 hours it should be ok. What problem are you having?
Dec 07, 2012 | Sanyo SR-366W Undercounter...
My frigde is working but does not get cold
On something like this what I recommend first is to remove the rear panel inside the freezer so we can inspect the evaporator. If the evaporator is iced up the unit will not cool properly & is a sign of a defrost cycle failure.
Jan 25, 2011 | Sanyo SR-3660S Compact Refrigerator
Ice buildup, not cooling well
The ice build up on the cooling coils prevents you fridge from cooling properly. You need to unplug it and allow the ice to melt. When the coils are free of ice, the fridge should work better. Hope this helps you.
Dec 17, 2010 | Sanyo SR-4910M Compact Refrigerator
How do i fix a mini fridge thats not getting cold
Most refrigerators just get dirty coils and when this happened the air flow does remove the heat properly. I would just give the back side and underneath a good vacuuming and it should work again. If it is an old unit and u can see rust on the coils it might have developed a leak and would need to be repaired. But if that is the cases the cost of a repair is not worth the cost of a new mini fridge
Sep 21, 2010 | Sanyo SR-4910M Compact Refrigerator
SOMETIMES THE THERMOSTAT STICKS TURN IT ON AND OFF A COUPLE OF TIMES YOU MAY UNSTICK IT OTHERWISE YOU NEED TO REPLACE IT
Jan 13, 2010 | Sanyo Refrigerators
Hi, my sanyo stainless steel mini fridge/freezer doesn't appear to be working. for the past few days the freezer has built up a crazy amount of ice, but nothing inside it is frozen. there is condensation...
Hi, Check that the refrigerator is level on the floor. Often when the refrigerator has been moved to clean behind it, its new position may not be level. The doors then do not close properly and the seals on the doors have not sealed properly. Other than this it could be the fan inside has stopped working.
Jan 09, 2018 | Sanyo Refrigerators
Sanyo sr-3620w Poked sensor under freezer tray...hissing sound
More than likely you let the refrigerant out. Is there an oily residue? If so you definitely punctured the evaporator. It's time consuming and expensive to properly repair a standard refrigerator sealed system and maintain the chemical stabilty that will prevent future problems. But with those tiny units priced as they are, it's always cheaper to replace them.
Dec 28, 2007 | Sanyo HF-5020
Not cooling....
Sounds like you checked for the proper items, fans to move cold air, etc. and if stuck in defrost mode. If the compressor is running you would have to be cooling unless... the refrigerant has leaked out. And that is basically a bad thing. If in defrost cycle the compressor would stop while defrosting soooo it's looking like the refrigerant is gone. Can you take the back interior panel off to see if the coils have a full frost pattern?
Jan 04, 2007 | Sanyo SR-4911M Compact Refrigerator
Refrigerators Logo
85 people viewed this question
Top Sanyo Refrigerators Experts
John Tripp
John Tripp
christian nielsen
Are you a Sanyo Refrigerator Expert? Answer questions, earn points and help others
