Question about Rosetta Stone Spanish (Latin American) - Level I: Personal Edition Full Version for PC, Mac
Rosetta stone 3.4.7 in windows 8 not find cd with languages
bluecrash
  • 106 Answers
SOURCE: When Rosetta stone installation tells me to put in
You can get the fixed file and details here:
http://support.rosettastone.com/ics/support/default.asp?deptID=14006
Posted on Jun 25, 2009
laikexpert
  • 281 Answers
SOURCE: Rosetta Stone error 2123
1.)Open BitDefender Antivirus in Expert Mode,
2.)click on the Antivirus module
3.)under the Shield tab click on the Advanced Settings button.
(BitDefender Active Virus Control Settings window should be displayed)
4.)adding an exclusion for Rosetta Stone solved the problem
or
If you have any other antivirus software
adding an exclusion for Rosetta Stone solved the problem.
Posted on Jan 04, 2010
  • 10 Answers
SOURCE: rosetta stone won't recognize my logitech headset
Make sure that your device is set as your default device by making sure that there is a green check mark next to the device. If not, right click and select "set as default device" (or something like that... I have vista and not win7)
If that does not work, right click on the headphones and go to "Properties" then go and under the "General" tab, change the name of the device to "Microphone HS" For some reason, Rosetta Stone does not recognize the headset unless it has the word "Microphone" in its name... Kinda stupid if you ask me. Hope that helps...
Posted on Mar 03, 2010
  • 10 Answers
SOURCE: my rosetta stone cannot or will not recognise that
The disk may be defective or there may be other problems that cannot be diagnosed given the information that you have provided. The best solution would probably be to call Rosetta Stone's free tech support directly at 1-800-767-3882. They can provide step by step problem solving and can help you find a solution.
SOURCE: Rosetta Stone Microphone Not Found
This worked for me:
1) Right click on the Rosetta Stone icon in the Start menu
2) Click the "Compatibility" tab
3) Set it to run in compatibility mode with Windows Vista SP2 (mine was defaulted to run in XP compatibility mode, which seemed to be the problem)
4) Start the program again, if you are lucky all mics will now show up
Posted on Jul 20, 2010
Fatal application 1141
Rosetta Stone Version 4 is compatible with Win 8. and Error 1141 is related to services in your computer i have found the fix at Questions Rosetta Stone Community
Apr 15, 2014 | Rosetta Stone 3 Filipino (Tagalog) Level 1...
Rosetta stone on Mac doesn't open because of error 9120
Go to System Preferences (click on the apple in upper left corner of monitor and pull down)
Look for "hardware" and click on "sound". Is your mike on? Make sure your "output" level is high.
Hope it helps!
Feb 22, 2013 | Rosetta Stone 3 Farsi Level 1 2_3 Set Full...
Rosetta Stone Error 9120
language CD is the main problem to get error 9120. To fix this i got this link for you all Ask Question Rosetta Stone Community
Jan 15, 2012 | Rosetta Stone Chinese Mandarin Level I &...
Loaded Start disc. When installing my language disc 1, I get an 9123 error code and a message " there was an error in the application". I cannot uninstall, because I get messages "...
Version 3/4: Error 9123 during Language CD installation
This error message relates to Version 3 and Version4. If you receive a 9123 error message during language installation, try one of the following resolutions:
  • Clean the disc with alcohol/windex/water and a soft cloth and try installing again.
  • Disable your internet security program, especially Norton or Symantec Security and try installing again.
If you are still experiencing this error, please contact Rosetta Stone Support
Dec 23, 2010 | Rosetta Stone Chinese Mandarin Level I &...
Rosetta stone problem installing language discs
I just had the same problem. Rosetta Stone TOTALe French Level 1. I just ran it in Windows XP Service Pack 2 and it installed right away.
Apr 07, 2010 | Rosetta Stone Spanish (Latin American) -...
My rosetta stone cannot or will not recognise that
Jan 07, 2010 | Rosetta Stone Spanish (Latin American) -...
When i try to install language disk i am getting
Well if it works in XP and Vista then it is safe to say it isn't compatible with W7.
Remember, Windows 7 is not going to be released for another 2+ months.
I have found a large number of programs that just don't work with W7.
Your best bet is to check on Rosetta Stone's website to find out if they list W7 as a supported OS.
Aug 23, 2009 | Rosetta Stone Spanish Level 1-2-3 Full...
Headset Problem Rosetta Stone
I found the answer. Rosetta Stone has a problem detecting the mics if the speaker input is not in someway connected to the mic. I'm not exactly sure how it works, but I don't care and neither should you.
Follow these steps each time you want to use it and you should be fine.
*I'm on Vista, but this should work for every one.
1. Open Control Panel
2. Open Hardware and Sound
3.Open Sound
4.Set Line 1 as your Default Speaker
5. Refresh the Mic list
*All of your mics should now show up.
6. In Rosetta Stone, apply the mic you want and finish the setup.
7.Start whatever language you're using and switch back to the Sound menu.
8.Set whatever speaker you want to use as default.
*Rosetta Stone will continue to work fine until you close it, switch Users, or remove the mic.
In short you have to set the default speaker to LINE 1 to get the mics to appear. Then when you apply the settings switch the default speaker back.
Dec 27, 2008 | Rosetta Stone Chinese Mandarin Level I &...
Rosetta Stone Spanish (Latin American) - Level I: Personal Edition Full Version for PC, Mac Logo
673 people viewed this question
Top Rosetta Stone Computers & Internet Experts
mukhtar21 shaikh
mukhtar21 shaikh
Jax Planet
Jax Planet
IT GURUS OF ATLANTA
IT GURUS OF ATLANTA
Are you a Rosetta Stone Computer and Internet Expert? Answer questions, earn points and help others
