Question about Mitsubishi WD-62526 Projection TV
Volumn goes up & down especially when static or dishwasher kicks on.
  • Mitsubishi Master
  • 3,261 Answers
Your tv has become to sensitive. could be threw the electric supply or the infrared board. if it is electric you will need to find the appliance that when it use the consumption more. you can use an old analog radio and go round the house with it out of signal listening for buzzing sound. sometimes it is the fuse box or a wire in the wall some were.failing that just change the inferred board and hope for the best but it will come back if there is and electrical fault. had this a few weeks ago in a friends house turnd out to be the fuse breaker changed it and it was fine even his phone works better now as well.
Posted on Oct 23, 2013
Tv volumn
Are you using another remote for the guide? Like the cable box remote? If that is the case then the remote could be sending a signal to the cable box that is the same as the signal used to adjust the volume on the television.
Apr 30, 2013 | Boston Acoustics TVee Model Two TV...
The volumn on my elemnt tv goes to 63,it is very low
Look first to see if a DVD etc connected by itself to a rear input on the set gives you normal sound or not--this will rule some possible things out.
Jun 15, 2012 | Element Televison & Video
2007 Rendezvous CXL. 1) Driving at 65 MPH and all idiot lights come on, car bogs down, hit the accelerator and car goes on. Taken to dealer 4 times and problem can not be duplicated and no code in car...
Sounds like 1 or more of your ground straps from the engine block to the frame either are disconnected or are loose.. I would check there 1st, especially if the engine has been removed and replaced.
Jul 13, 2017 | 2007 Buick Rendezvous CXL SUV
Microphone volume goes down automatically
Go to control panel and select the sound option
There you will find microphone settings that are enabled, one of them is set to on and adjusts volume automatically as the noise increases, jsut disable that option
Cheers
Jul 08, 2009 | HP Pavilion dv6000z Notebook
Centre input active
Go to..
Menu / Setup / Source
Scroll down and Highlight Center Input, And select Off.
If it dont work first time round, Disconnect all Audio/Video leads from TV, and try again.
Jan 22, 2009 | Philips 42PF9966 42 in. HD-Ready Plasma...
Radio volumn goes down when braking
if there is a menu button or something like it look for avc auto volume control set to 0
Nov 13, 2008 | 2006 Ford Focus
GSM2100G02WW/SH791112B
cleaners are available from Lowe's home depot appliances parts stores etc but it sounds to me like you have a drain problem check your drain line where it attaches to your sink and where it goes into your sink for blockage take off the bottom kick plate and you will see a black solenoid with a silver shaft and a white plastic rocker and spring make sure that the silver shaft moves up and down freely if not replace that seloinoid or call for service
Jan 09, 2008 | GE DBSR453EBWW Electric Dryer
BC350A loud static
It may be that someone you are monitoring is now using digital or at least parttime.
when they go digital, you may only hear static.
hope this helps.
UPSO506
Dec 29, 2007 | Radio Communications
Mitsubishi WD-62526 Projection TV Logo
20 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
