How to change honeywell battery - Heating & Cooling
  • 400 Answers
Looking from the front, on top to the right is an area you can press down slightly, then move to the right. The battery compartment comes out for battery replacement. It uses AA batteries. I hope this helps you.
Posted on Oct 22, 2013
I have Honeywell thermostat..Aube 360 000 071 B It died last night. Simply stopped On-Off of main turning on A/C does not work. I have changed batteries..I need help.
Your Honeywell thermostat may have simply expired. The fact that replacing batteries did not help (provided they were installed correctly) is an indication.
Jun 20, 2018 | Honeywell Heating & Cooling
How do you change the battery on Honeywell Th9421C1004 Thermo
Hello Bob Compher,
It looks like GETTING that battery is the biggest challenge...
After that it simply unplugs (like a portable phone battery).
Your manual is listed (below)
For assistance with this product please visit or call Honeywell Customer Care toll-free at
1-800-468-1502
Homepage
Honeywell VisionPRO IAQ Installation Manual Page 8
Feb 24, 2017 | Honeywell Heating & Cooling
How do I change the battery on Honeywell Thermostat T8001C?
According to the manual for the model series (see link), only the T8002 Model has batteries. They are accessed from the right side of the thermostat. See page 14.
https://customer.honeywell.com/resources/techlit/TechLitDocuments/69-0000s/69-1431.pdf
Jan 10, 2015 | Honeywell T8001C1019 Programmable...
What does it mean when the battery error message stay on.replaced batteries, should. I purchase a new thermostat
No friend,
Inside the Honeywell box WILL be a battery. which is there to keep your settings if a Power Failure occurs.
All you have to do is change it and reset your Control.
A typical change of battery is explained here.
http://homeguides.sfgate.com/change-wall-thermostat-battery-25307.html
Sep 13, 2014 | Honeywell Programmable Thermostat Heater
Changing batteries I Honeywell thermopro 3
Any Honeywell thermostats I have come across you slightly tug on bottom of thermostat which disengages it from the wall and lift up. Batteries are then exposed. Replace with new and reverse take-off procedure to remount. If I remember correctly these do have a small battery backup to save your initial settings so you do not have to reset time and program. Can you tell me the complete model number of thermostat or send a picture of it?
Dec 30, 2013 | Honeywell Heating & Cooling
How do i reset my honeywell thermostat
Remove thermostat from wall, leaving base plate on wall.
Model number appears on back of device.
Google search thermostat model in following format: Honeywell xxxx32 thermostat .pdf
Adding .pdf to search parameter will yield product manual.
Also while thermostat is off the wall, change batteries located in compartment on back of thermostat. These batteries must be changed periodically, for example each 3-4 years.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Jul 17, 2013 | Honeywell TH3110D1008 Pro3000 Thermostat
HOW TO CHANGE THE BATTERY IN HONEYWELL ALPHA 6160 KEYPAD
There is no battery in the Honeywell 6160 keypad. It is powered by the transformer in the control panel. If it is showing BAT on the keypad, check the main system battery in the control panel.
Feb 28, 2013 | Honeywell Ademco 6160 Alpha Keypad Vista...
The thermostat for the main zone in my house (honeywell model RTH5100B1017) is battery powered and it blinked change the battery for a couple of daye and then went blank. I have changed the batteries twice...
  • Check any batteries and replace if needed. Ensure that you use only AA alkaline, nonrechargeable batteries.
  • 2 Check for oxidation buildup on battery contacts. Use electrical contact cleaner and carefully clean the battery contacts of any oxidation buildup.
  • 3 Reset the system switch.
  • Read more: How to Troubleshoot Honeywell Thermostats ' eHow.com http://www.ehow.com/how_6596826_troubleshoot-honeywell-thermostats.html#ixzz17aWIl2Xt
    Dec 09, 2010 | Heating & Cooling
    We have a Honeywell ST7000 which stopped working on friday so i changed the batteries and it was ok. Got up this morning and the batteries had pooped out, changed them again and it is working again but i...
    The honeywell ST7000 Actually runs from the batteries. It is not powered form the mains at all. Silly I know.
    The userguide can be found here; http://www.honeywelluk.com/pdfdownload.aspx?id=1044
    Nov 30, 2009 | Honeywell Hardware & Accessories
    Heating & Cooling Logo
    67 people viewed this question
    Top Heating & Cooling Experts
    Paul Carew
    Tim Whalen
    Mack Baxter
