Question about Cuisinart BFP-703 Blender
The plastic gear / splines on the SSB1U Cuisinart Soup maker / blender base has been worn so the spin / power is no longer transmitted to the blade system ... Can this spline assembly be replaced ?
  • 3 Answers
Then I will need to findout what bits go where
Posted on Nov 07, 2013
SOURCE: cuisinart sealing gasket
The gasket goes between the cutting assembly and the glass. So you slip it on over the top of the blades and then put the glass jar over top of that. Screw the bottom cap on to tighten everything together.
Posted on Nov 02, 2007
SOURCE: replace the blade driver clutch on a Cuisinart CBT-500
I had this same problem. It was solved but let me tell you it was a nightmare and we were almost sure the blender would be destroyed at least 3 times during the ordeal.
Here's a hint: the thread is on opposite to a normal screw thread so that it gets tighter as the blender spins.
Steps:
1. Take the base off the blender and pop out the motor.
2. Turn over the motor and remove the round rubber part at the bottom. You will see a flathead screw. This is where you grip the shaft that the cursed brass coupler thread is attached to.
3. Find someone else to help and also a large strong flathead screwdriver.
4. With a friend holding a screwdriver in place at the bottom, grip the top brass thread with pliers (or better yet a pipe wrench) and twist it the opposite way you normally would.
5. Become extremely frustrated by the fact that the screw thread is made of cheap metal and strips instantly and that the brass thread is also cheaply made and rips right through your pliers / wrench.
6. Find a hack saw and a hammer.
7. Cut the brass thread off with the hack saw. Hammer the stubborn remaining pieces of it off with a screwdriver. Be prepared to cut off half of the shaft.
8. Eventually you should have hammered / sawed the brass thread off. If the shaft and motor are still intact, you can now screw the new coupler on (remember - its backwards). We had only about half of the shaft thread left and it still worked ok. Make sure to do this after you put the motor back in place with the shaft poking through the top of the case. Don't worry too much about how tight it is. As I mentioned its on backwards to tighten the coupler during normal use.
9. Replace the casing and screws, don't forget that rubber thing at the bottom.
10. Curse Cuisinart and make a drink, you deserve it.
Posted on May 13, 2008
ThaMp3Doctor
  • 8596 Answers
SOURCE: leaking cuisinart smart power 7-speed electronic blender
There is probably a hairline fracture or tiny crack in the blade assembly itself - replace the blade assembly - it will automatically come with a gasket, so you will have an extra.
Posted on Apr 30, 2009
  • 240 Answers
SOURCE: my cuisinart spb-7 blender won't spin
Any indication thaat the power is reaching it? Power light? If not, check plug wiring and fuse. If you have an electrical tester check if power is going along the cord. Could be a problem with onn off button or motor otherwise.
Posted on Jun 13, 2009
SOURCE: Cuisinart CBT-500 blender won't work
(0) unplug unit (1) Remove the bottom 4 screws, cover plate and motor shield ( 2) unhook the white motor wire from its binding clip ( 3) locate the plastic sleeve with the fuseable link (4) cut the sleeve and test for continuity between points on either side of link with ohmmeter (5) if no continuity, clip out fuseable link and and solder the white wire back together (6) cover with tape (7) rebind to other wires (8) replace bottom and check. This worked for me.
Posted on Nov 22, 2009
Maual for cooks essentials soup maker
https://www.cuisinart.com/share/pdf/manuals/sbc-1000.pdf
Mar 16, 2015 | Cuisinart Blend and Cook 4-Speed Soup...
Blades won't spin
The motor may have failed.
Dec 25, 2013 | Cuisinart Blend & Cook Soup Maker
I have had my Cuisinart SmartPower blender for about 10 years now and it has worked great. Recently there has been a black dust/stain/residue that is on the underside of the bottom collar/blade and on the...
At 10 years you are heading to replace it. With the blender bowl removed, try turning the connector the goes to the blades. Then do the same with the connector on the base. Whichever one doesn't turn easily is the one that is failing. Usually there is corrosion in the spindle of the jug and this causes tightness which in turn causes the connectors to shred. The tightness cause friction, which makes the plastic parts get hot. The blade should spin easily, the connector on the motor, not quite so easy. On some blenders you can switch the base on with out the jug being on it. Run it for 30 seconds and then switch off. If it stop dead, then problem is with the base and the spindle that goes to the motor. In a catering environment, I had a Hamilton Beach, shatter the base connector after 2 years. With blenders, you get what you pay for, Cuisinart aren't bad, but there are better makes if you use them a lot.
Aug 19, 2017 | Cuisinart SPB-7 SmartPower Work Top...
My Cuisinart soup maker keeps switching off
How you removed the bottom? Screws are so deeb and I cant see what screwdriver I have to get.
Nov 20, 2012 | Cuisinart SSB1U Soup Maker
The rotor on the base for the food processor will not engage. It spins freely, and the black wheel on the bottom rotates, but does not engage the blade spindle. Why?
Usuallt, it is simple - you have the position the gear box of the food processor side until there is no gap between the gear box and the teeth on the base - this usually takes me a few tries to get it right.
If you are confident that there is no gap, call Cuisinart and see about getting a new gear box - 1-800-726-0190
Aug 16, 2009 | Cuisinart BFP-703 Blender
Broken glass jug on kitchenaid blender model 5ksb2aer4
Look at the underside of the blade shaft. The metal wing nut on the end of the shaft secures the blade assembly to cream coloured plastic blade base. The wing nut also transmits the drive from the rubber coupling on your blender to the blade shaft. The wing nut has a LEFT HAND thread.
The left hand thread ensures the blade assembly does not unscrew during normal blender use.
Firstly disassemble the blender blade assembly. Place a folded tea towel over the blades and hold the blades firmly. If you do not use a tea towel you may cut yourself.
Grip the wing nut with your other hand and unscrew it CLOCKWISE.
Remove the wing nut. You can now remove the blade from the plastic base.
Put the blade assembly in the new jug and offer up the plastic base from under the jug so that the blade shaft protudes enough for you to install the wing nut.
Screw the wing nut ANTI-CLOCKWISE to secure the blades to the plastic base.
Do not over tighten the wing nut; you may have to replace your jug again at some point.
Jun 06, 2009 | KitchenAid KHB300 Handheld Blender
Plastic pieces on glass jar and base are worn out and shaved down
I did the same thing. Order parts at thegourmetdepotco.com -- This problem is caused when you put the rubber gasket underneath the blade instead of above it. This causes two problems: 1. It lifts the teeth on the jar away from the teeth on the drive gear, which can grind down and break off the teeth, and 2. If the drive gear contacts the rubber gasket, it will melt the rim of the drive gear. In the future, to reassemble the jar after cleaning, first put the rubber gasket on the jar, then the blade, lastly screw on the base ring.
Apr 19, 2009 | Margaritaville Frozen Concoction (DM1000)...
Black plastic "ring" that fits over the spindle on the motor base snapped
I just bought a replacement part on ebay. It cost about $11, which included shipping. buy-it-now-store.com
Jan 16, 2008 | Cuisinart SPB-7 SmartPower Work Top...
Broken gear on BFP-703 base
The drive is replacable and available from Cuisinart, you will have to sign a waver to get the part. the drive is screwed onto the motor shaft with reverse threads. the plastic drive will have to be completely broken off of the unit to expose a brass"nut" which was internal to the drive. depending upon your model you may have to remove the lower half of the base unit to access the lower part of the motor shaft. there will be a slot in the end of the shaft for a large flat blade screwdriver. this is used to hold the shaft still while turning the drive "nut" with a vice grip pliar or similar. the new drive is just threaded onto the shaft and normal operation tightens it.
Feb 14, 2007 | Cuisinart BFP-703 Blender
Cuisinart BFP-703 Blender Logo
155 people viewed this question
Top Cuisinart Blenders Experts
eyecam
ray gallant
richie46
Are you a Cuisinart Blender Expert? Answer questions, earn points and help others
