Question about Toshiba Computers & Internet
Not running fast - Toshiba Computers & Internet
    Top Expert:
  • Toshiba Master
  • 12,223 Answers
Uninstall some program that you ARE not using, this happen when some software are big, and use enough space in your disk+memory
Use some utility program for to clean memory, download from Internet.
God bless you
Posted on Oct 22, 2013
My clock is running fast and I can't figure out why?
With the new digital clocks, there is really nothing you can do to fix this. The clock running fast is due to a faulty electronic or electric component that is out of tolerance. US electricity runs at 60Hz, which is 1 cycle per second. Clocks use this to advance the seconds on a clock. Too fast means the 60Hz on the AC power input is not being properly used and is running the clock at something less than 1 cycle per second.
Jan 27, 2015 | Audio Players & Recorders
Stihl ms 210. Starts ok revs fast then cuts out. Have to re start on full choke then run fast again on 1/2 choke and again stops after 2-3 seconds.
you have an air leak causing the unit to run to fast. The air leak is also over powering the flow of fuel causing it to die. Hopefully you have not tried running it repeatedly like this or you may have done severe internal damage due to running it to lean
Nov 19, 2014 | Stihl Genuine Ms 210, 230, & 250 Chainsaw...
Engine runs fast and slow
Take a spray of carb cleaner and clean the linkage mechanism from the governor to the carburetor and make sure they move with out sticking.
Dec 07, 2013 | Briggs Stratton Portable Generator 305cc...
What will make the coolent run out fast 2000 navigator
Leak in the coolant system
Obviously you can see it,if it runs out fast
Jul 15, 2013 | 2000 Lincoln Navigator
My 1997 john deere just dont run as fast and hard
check your throtlle cable ... it is very possible that if the engine runs fine just doesn't run as fast as it used to that you throttle cable has slipped in the clamp and you need to adjust it ...
Aug 19, 2009 | Garden
Tissot prs516 & it runs fast 1 minute every day
There is a solution, but you have to wait a bit. I'll contact Tissot tmrw and then will give you advise. It's 3.15 in the morning over here, so, need a little rest.
Aug 14, 2009 | Tissot Prs516 T91141731 Watch
Watch has been running fine, now running fast.
HI there,
If you have an Automatic Wrist watch. Some adjustment has to do inside the watch. You better bring the unit to any local watch repair shop to adjust or correct the polarity of the energizer.
Hope this helps.
micro
Jul 28, 2009 | Watches
Vn800 running fast on tickover
I am not sure what you mean on the "running fast" statement. If idle speed then turn the idle screw outward to slow down the idle.
The backfire is caused by turning off the ignition key when the bike is at high revs. let it idle down THEN turn it off. The backfire is there because the carb idle circuit is active anytime the piston is in motion. Gas goes into the cylinder as the bike revs down then a hot spot in the exhaust pipe finally ignites the built up gas. There is your backfire.
Is the running fast question answered? Give me more information on the problem if it isn't.
Please rate this answer. Thanks njv6!
Apr 15, 2009 | kawasaki KX 250 Motorcycles
Cd and dvd running to fast
How do you mean they are running too fast ? If there is a noise then that is normal and on some laptops there is a cd silencer that could run. Try this should be in the programs.
Thanks J
Feb 14, 2008 | Audio Players & Recorders
Computers & Internet Logo
16 people viewed this question
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
