Question about Electronics - Others
Tdk flash drive: I switched my computer off with the memory stick still inserted. When I switched it back on after few minutes, the stick wouldn't come up on any of my computers. I am unable to access my saved documents.
    Sergeant:
  • 395 Answers
Does it appear in RMPrepUSB device list? If not it may be damaged. Take it apart and re-solder the 4 contacts onto the PCB.
Posted on Nov 01, 2013
  • 26 Answers
SOURCE: Unable to access files on the flash drive
SDHC cards are not backward compatible with normal SD cards..therefore older devices will not recognise them...your built in card reader is probably not sdhc...try downloading directly from camera or use a sdhc usb card reader
Posted on Apr 29, 2008
SOURCE: pny usb 2.0 flash drive memory stick
windows xp doesnt recognize in drive f, when i open and prompt it to format it says disk is copy right protected. I open it and there is a bunch of foreign mumbo jumbo that i can't delete
Posted on May 28, 2008
SOURCE: my usb 4gb flash don my computer only reads in a secure K with 1m
See http://www.maxell.eu/FAQ2/FAQ.html
Venture USB contain two partitions - one named 'Public' and the other 'Secure'. Unfortunately we have noticed a compatibility problem between these drives and some computers running Windows Vista. In these cases only one drive is showing in 'My Computer' - usually the 'Secure' drive. As a result you are unable to access the user manuals and software which are in the 'Public' drive and cannot alter the partition sizes to allow access to the entire capacity.
Please follow the below instructions to resolve the problem:
1. Connect the USB to the computer
2. Please unzip and run the attached program
3. After completion please unplug the USB
4. Re-insert the USB to the USB port
5. You should now be able to access both drives.
Please click here to download the program and instructions
Posted on Jan 28, 2010
SOURCE: Sony memory stick PRO Duo 2GB Pc will not display photos on PC
Hey all actual solution...sort of will get you your files well it worked for me.
i have winrar on my windows 7 pc but should work for anything with winrar.
  1. open my computer
  2. right click memory stick pro duo
  3. click "add to archive"
  4. in the winrar window under format on the left hand side of the window half way down select "zip" format
  5. click "ok"
  6. once your files have archived the DCIM folder and MISC folder will be in the archived file and should be accessible from there
  7. NOTE: you cannot extract files after the archive has been created DCIM folder and MISC folder will still be invisible even if you extract them from the archive.
  8. Files can still be drag and dropped out of the DCIM folder onto desktop or chosen destination from the archived file.
Hope this has been helpful to all reading this and everyone who posted the problem :D
Posted on Jun 08, 2010
SOURCE: PLEASE INSERT A DISK INTO DRIVE(H): (pendrive problem)
I had the same issue with my 4GB Sony Memory Card when I put it in my memory card slot on my computer. I have a Toshiba laptop, so what I did that fixed the problem is I went to Toshibas Support Webpage in the downloads section and under the CATEGORY: Driver Card Reader and re-downloaded: Ricoh Card Reader for Windows 7 (32/64)(v3.54.02; 09-04-2009; 4.94M) and once I did that it read my memory card and didn't give me any more issues and it opened all my pictures. Of course if you don't have a Toshiba then you would go to your manufacturers web site and see if they have the same thing, because that is what fixed my issue and it didn't take long at all.
Posted on Sep 05, 2010
My TDK 8GB memory stick won't show up on the PS3
click start control panel administrative tools computer management device manager scroll down universal serial bus controllers you could see a yellow question / exclamation mark? ! or a red X
you will need to update/reinstall drivers
right click to reinstall drivers
if you can see your usb drive but its not working
ports (com&lpt) right click update driver if this fails to fix the problem
check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems to a computer and its parts
hope it helps
May 13, 2012 | TDK Electronics - Others
Forgotten password on TDK memory stick
http://majorgeeks.com/Dr._Freeware_System_Utilities_d6416.html Dr.Freeware System Utilities which includes data recovery software, data backup, password reset tools for Windows helps you to maintain your system. Dr.Freeware is freeware, you can download and use it for free.
Hope this helps
Mar 13, 2012 | TDK (CD-RW74HSFXS5) Storage Media
I have a TDK 8GB , i lost my password , so i cant access to entire space on my disk,how can i totally format my flash memory?
Hello and Good Day!
Maybe this will help,first click start button located in the lower left corner of your desktop then click My computer, at the my computer window locate your flash drive perhaps it is labeled as TDK or removable drive then right click using your mouse,look the word "format" left click at the lower part of the window you'll see quick format click the box then click start.
Hope it helps Thank you
Jun 09, 2011 | TDK (CD-RW74HSFXS5) Storage Media
I formated my TDK USB-STICK 4GB TRANS-IT flash drive and now it is has only 239mb space, how can I recover the lost space.
Reformat with this utility.
http://www.pcworld.com/downloads/file/fid,64963-order,4-page,1/download.html
Mar 27, 2010 | TDK (CD-RW74HSFXS5) Storage Media
My memory stick has stopped working, nothing shows up when I insert it into the computer...I need some of the files which are stored on it, do you know how I can fix it?
Files on a flash drive can be corrupted if it is not removed from the USB port properly.
Before removing the flash drive click on the Safely Remove Hardware icon and then click on the flash drive you want to remove and then remove the flash drive when the computer message says it is Safe to remove.
To restore the flash drive you may need to format the flash drive, but you will lose the data stored on the flash drive.
If you need the data on the flash drive this program may help: -
Digital Photo Recovery
www.artplus.hr/adapps/eng/dpr.htm
Nov 12, 2009 | Sony 1GB Memory Stick PRO Duo Memory Card
Only 5GB on TDK TRANS-IT USB 2.0 Flash Drive 8GB
Not the solution you might like but there have been reports of bogus/ counterfeit smaller capacity sticks/drives relabeled and programed to report higher capacities. I've been told that running a formatting/partitioning application on them reflect the true capacity but have not had to try this solution myself..
Submitted for information only but please rate so I accumulate a lot of unanswered solutions, Thanks
Mar 15, 2009 | TDK (CD-RW74HSFXS5) Storage Media
I have a memory Stick PRO Duo 4GB
YEAH, YOU MAY NEED A MEMORY CARD READER to read your memory stick. because some compters have not all type of card slots. the card reader will solve your problem.
Feb 10, 2009 | Sony 4GB Memory Stick PRO Duo Memory Card
Electronics - Others Logo
26 people viewed this question
Top Electronics - Others Experts
Are you an Electronics - Other Expert? Answer questions, earn points and help others
