Question about Ovens
Rational scc101g stuck in cleansing mode - Ovens
Omega double wall oven model E88 stuck in demo mode and won't disable
Suggest you contact the manufacturer. There is little information on the web
Aug 04, 2016 | Ovens
Scc-101 rational fault codes
Rational SCC error code service 100
Aug 27, 2012 | Ovens
I have one rational oven showing error 34
34 what there should be a no after 34 ie like 34-6,34-8 etc
Mar 22, 2012 | Ovens
My rational selfcooking center says service34-2- no function please help
You really need a specialist repairer to resolve this but this generally relates to a main fan motor defect or a failure elsewhere in the bus circuit.
Sep 03, 2011 | Ovens
Rational combi oven service manual
Alarm beeping control board not working
Apr 28, 2010 | Ovens
Rational combitherm electric service codes
service 3, you have a cpc type oven yeah? if so then service means your meat probe needs replacing
Mar 13, 2009 | Ovens
Error " service 34 -6-
check polarity means you have the live and neutral to the oven swapped over, you need to change the live and neutral. service 34-6 means there is a communication problem with both the fan motors but this will probably be cured when you swap the live and neutral
Mar 01, 2009 | Bakers Pride CO11-G2 Gas Double Oven
Ovens Logo
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
