Heater wiring diagram modine g50a - Heating & Cooling
Unit will not light. want electric print of the control circuit.
do u require a manual? plse also provide the model number of ur device
Oct 23, 2008 | Heating & Cooling
Modine Hot Dawg heater - no heat
that sounds like the limit look for a little round thing with two wires with a button between the wires push it to reset it but there could be several of them even one buy the blower motor there is also a high limit in the center of the furnace all you see is two wires if that one is out you have to remove it two screws then just drop it on the floor it will free the numeral bymetal inside put it back on and you should begood
Nov 23, 2013 | Modine Hot Dawg Heater Model HDS - Natural...
I need a wireing diagram for two elament electric water heater. Mine runs on 220 volt, my question is what about the common or white wire where do i hook it to or do I not need it when running a 220 circut
Links below show specific wiring diagrams and explain 240V with two hot wires vrs 120V with hot and neutral wires.
Then if you have more questions, add a comment and I will fill in blanks:
http://waterheatertimer.org/How-to-wire-water-heater-thermostats.html
First diagram will be for your water heater.
http://waterheatertimer.org/B220C.html
Add a comment for more free help.
Also take advantage of fixya expert assistance live.
For a price, expert works with you via e-mail while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Feb 17, 2011 | Reliance & 40 Gal Electric Mobile Home...
How do I light the pilot on my Modine PA105AB?
Look on the side or bottom there will be a little circular door held on with one screw it will swing from side to side there should be a long wire with a hook on the end that looks like a key ring this is used for holding the match if you can't find the match holder in the bottom of you unit find some way to get the match up to the pilot head then turn your gas valve to pilot position and push in on the button while holding the button in light the match hold it to the pilot head once the fire lights continue to hold the button down for 10 seconds then instantly let off the button and turn the knob to the on position and your set .
Hope this helps......
Nov 18, 2010 | Heating & Cooling
Need wiring schematic for heater model ETS 508 240 V heater unit
img_0613-uk3nsfrbjmmgqc2tsboqpvuj-4-2.jpg Heres a wiring diagram which can be found on the inside of the heater. What i would like to find is the system wiring diagram referenced at the bottom of that diagram.
Nov 14, 2010 | Stiebel Eltron Heating & Cooling
I replaced the heating elements(2) and switiches(2) on my Rudd electric hot water heater. Model PES 40-2. The switghes came with several wiring diagrams.(universal) Can I get a diagram specific to my...
Residential water heaters USUALLY follow same diagram unless water heater is wired for other purpose. Multiple diagrams on instructions show available options. Take photo of wiring before removing wires on any electrical device.
Upper element.
Black wire from top of heater connects to #1 top left screw.
Red wire from top connects to #3 top right screw.
Blue wire from upper element connects to #4 middle screw on right side
Red wire from lower element connects to #4 middle screw on right side
Yellow wire from upper element connects to #2 lower left screw
Black wire from lower thermostat connects to #4 lower right screw
Upper element: Yellow and Blue wires connect to either screw
Lower element: Red wire from top connects to either screw
Lower thermostat: Black wire from top connects to top screw
Short wire between lower thermostat and lower element
http://waterheatertimer.org/images/Water-heater-wiring-w-numbe.jpg
http://waterheatertimer.org/images/Thermostats-numbered-divided-500.jpg
Sep 18, 2010 | Whirlpool Water Heaters
Wiring diagram for Dimplex wall heater Model 6100770000
installing a wall mount heater not sure on the wiring .heater has 3 wire black red and blue sources has white and black what wires go together
Jul 16, 2010 | Heating & Cooling
Wires not connected to gas valve need wiring diagram for Cozy wall vent heater
I think you mean a milli-volt system. I went to the cozy heaters website and found the wiring diagram in an owners manual for a similar unit, a W355. I bet the wiring diagram will work for your.
Dec 10, 2009 | Cozy (W352E) Heater
Heating & Cooling Logo
60 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
