Question about RCA 27V530T 27" TV
Crt spark flyback
Need some help. i am fixing a tv for my in-serve training. the problem is when i put the TV on spark come out of the flyback and blow the fuse. need to know how to fix that.
    Top Expert:
  • RCA Master
  • 74,383 Answers
If fly-back transformer gets sparks, no doubt, the horizontal output transistor will blow out, at the instance you switch ON the set. If you wish to get more details, check this link. http://electronicshelponline.blogspot.com/ Selecting the view option, either to Mosaic / Time slide, can be selected by the drop-down list, at the top left of the display window, will make surf easy. You can also do a search, by type in the brand name/model number/IC used, in the search box at the top right of the display window. I think the site will help you like people so much. Good luck.
Posted on Oct 23, 2013
4 Suggested Answers
techman
  • 3130 Answers
SOURCE: fuse blowout
Every time you put in that fuse and it sparks your probably causing more circuit damage as a fuse very very rarly goes bad for no reason.. Ok to the subject at hand. it you put back in a good fuse WITHOUT PLUGGING IN!! Next measure with an olm meter across the two legs on the plug on the end of the wire(the part you normally plug in.) Is there a short circuit?? yes? I would then start trouble shooting the front end of your main power supply like bridge recifyers,main b+ capacitor, the capacitor that goes across the ac line input as well as an VDR can short out in a surge. Now if that dosent get you anywhere your gonna need a schematic diagram. You can get that from howard sams photo facts. It available on line as a PDF for about 27.50. If you dont know what Im saying here then I really cant help you any farther and you will need to take the set to a quilified repair person as a tv even unplugged can hold 100's of volts. Now if you do know what your doing with solid state repairs by all means get the schematic and post it here for us to look at and we can assist you with this repair. Good Luck
Posted on May 21, 2006
  • 97 Answers
SOURCE: flyback and hv splitter
Definate flyback problem or in that area of HV circuit start-up. Would leave it to the warranty to repair, they will just swap the entire supply.
Posted on Apr 11, 2007
  • 26 Answers
SOURCE: RCA F32650 32" TV Problem:
The flyback is a a block with some wires coming from it. One of the wire is a big red wire that goes to the picture tube. The FBT is usually on the right rear of the circuit board.
Please be careful when working around the FBT as there are extremely high voltages present - in excess of 25K.
I would suggest you take it to a service shop as when the FBT goes, other parts are usually gone too.
Posted on Nov 17, 2008
When I turn it on, it makes a buzzy noise but nothing else., no picture or tv sound.
The set has a high voltage problem, "the flyack transformer is defective" It generates the high voltage in the picture tube and with the help of the video circuits it produces a picture. It is not cost effective to repair the tv, cheaper to replace.
Jan 30, 2011 | RCA 27V530T 27" TV
What part do i need to replace to fix a buzzing noise on a Sanyo DS25390? Thanks, Jason
This tv problems,have 2 possibilities problems.1 the CRT(Tv tube) itself is dead.This u can hear the CRT Video board connection buzzing noises at the CRT-(Tv tube) head.The CRT is dead,also have a little high volt sparks flashing on the video board components too.2 is the FBT-the Flyback Tranformer is dead.This is a highvoltage transformer,a big black block of plastic with a red wire with a cap hook to the CRT(Tv tube).This will make buzzing sound at the base of the FBT.If it is the FBT-it is repairable,if u still can find the FBT part for ur tv model.This part the FBT is a critical part for the analog tv to work.Require tools and also know basic soldering too a must.
Dec 01, 2010 | Sanyo DS25390 TV
Help Fixing SONY KP 46S17 Rear Projection TV
#1. is the ground witch the connector can be found most likely from the crt tube ground, the one that clip with return spring.
#2. is the flyback screen voltage can be found from flyback transformer most common color is red and be insert to the hole.
Oct 17, 2009 | Sony KP-46S25 TV
I have an old Zenith SY2568S that hasn't had a crisp picture in a while and has just recently developed a translucent white picture. Everything else seems to be fine. Can I fix this on my own or should I...
This is caused by a device on the television called the "flyback". It is the most dangerous part on the TV and should be set by a trained technician. What is occurring is the flyback is going in and out of it's correct setting by the device that sets the voltage output of it. It is called the Focus Foyer or similar flyback control. Take it to a technician. Have him give you an estimate - I usually set the cost of repair to 50% of the original cost of the unit - beyond that it would be cost INeffective. Hope this helps
Len
Jun 19, 2009 | Zenith A27A11D 27" TV
Bugzapper noises and Sparks
The Flyback transformer is arcing. You could change it or if available replace the whole module. Let me know if this helps.
Oct 07, 2008 | GE 25GT240 25" TV
Tv is sparking and making noise?
Warning: Flyback Transformer Failure. ( extreme high voltage ) 22,000 Volts +
Do not attempt to fix this without another human being present who's trained in CPR.
Thank you for choosing FixYa!
Azkeyz, Wizard Division.
Sep 23, 2008 | Prima CV1311 TV
Flyback transformer BSC 70Y
You will find the flyback on this site.
May 02, 2008 | Apex Digital PF3230 32" TV
Sony Trinitron 13 inch older model tv pops & smells at plug
If everything still works OK, then chances are the problem is even before the internal power supply. This could be a component that simply is nearing its lifeend such as a capacitor to ground, a VDR (voltage dependent resistor), a line filter (technically just a coil of wire), or limiting resistor in line with the degaussing coil. This should be a relatively easy/low cost fix and any qualified TV repair professional should be able to do the job pretty quick.
In some instances, there could be nothing wrong with the TV. It is also possible that the smell and pop is an HV (high voltage) discharge due to accumulated dirt, dust and grime anywhere near the anode cap (end od red wire to picture tube) or the FBT (flyback transformer).
Of course, the best would be to seek the services of a qualified TV repair professional since an onsite diagnosis would best serve your purpose.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
May 02, 2008 | Curtis CM13102 13" TV
Rca projection tv serv#p56938yx mod#p56938 serial#c135c50tx chassis#ptk195s16p cant id
Here are some numbers to call for Flyback Replacement
Electronica 1-800-772-5578
Asti 1-800-221-1828
you will need RCA chassis# PTK195s16p - flyback number1541938b.
ThankYou for using FixYa. Have a Nice Day.
Feb 07, 2008 | Televison & Video
Tv is completely dead
Only 10 years old??? Ok its most likly at the end of its usefull life, unless you want to put some cash into the set, as there are no user replaceable parts inside this TV, so you really should let a trained tech estimate it for you. But once you fix it, you most likly will start have problem after problem. Do yourself a favor, and buy a new one. The problem with this set is most likly the flyback and other componets or the power supply capacitors are bad.
Sep 30, 2006 | Panasonic CT-32G11 32" TV
RCA 27V530T 27" TV Logo
37 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
