Question about Compaq Presario Notebook
Boot and work but no beeb - Compaq Presario Notebook
    Top Expert:
  • 12,223 Answers
Use your software utility coming with your compaq, the administrator utility, and restore to the factory adjustment. and fix it.
God bless you
Posted on Oct 22, 2013
I have a constant beeb beeb ----beeb beeb---beeb beeb from my speakers or headphones but not from the computer tower when the speakers or headphones are removed. Is this a audio problem with PC or a virus?
Hi there
A couple of points.
Many system boxes no longer have built in speakers, and if they do they are very simple and simply used for POST errors and other alarms eg CPU fan failed, overheating etc. If there is a pattern to the beeps, you need to check against your BIOS codes to ensure nothing serious is happening.
If your system is working completely normally otherwise, then I would suspect an audio problem, which might be resolved by removing and re-installing the audio driver from the disk supplied.
Cheers
Nov 10, 2014 | Computers & Internet
Boot and work fine but no beeb or sound
go to control panel, and use the utility System RESTORE, and put the last days that you know was working Good. and fix it.
God bless you
Oct 22, 2013 | Compaq Computers & Internet
The dial tone is going beeb, beeb,beeb,beeb,but the phone is working ok,its like there is messages but it does not have answering machine
You may be subscribed to a voicemail system provided your telephone company. This system records messages when people call while you're already on the phone. Please contact your telephone company for instructions on accessing their voicemail system.
Jun 15, 2012 | Lands Phones
My dv6000 dont start . i have black screen with one long beeb and two short beebs
HI friend,
one long beeb and two short beebs Indicates a video error has occurred and the BIOS cannot initialize the video screen to display any additional information,some couse of that issue is New hardware conflicting with old hardware or New hardware conflicting with old hardware or Connections not connected or connected properly or other hardware issue.Best solution is
If any new hardware has been recently added to the computer, remove that hardware to make sure it is not the cause of your issue. If after removing the new hardware your computer works it's likely the computer is either not compatible with the new hardware or a system setting needs to be changed to work with the new hardware device.Remove any disks, CD's, DVD's that are in the computer and if any USB devices (ipods, drives, phones, etc)
before all that please
Make sure all fans are running in the computer. If a fan has failed (especially the fan for the CPU) your computer could be overheating and/or detecting the fan failure causing the computer not to boot.
If you continue to to receive the same problem with all the above hardware removed attempt to disconnect the RAM from the Motherboard and turn on the computer. If the computer has a different beep code or if your computer was not beeping and is now beeping turn off your computer and try the below suggestions. Making sure to turn off the computer each time you're adding and removing the memory and then turning the computer back on to see if the suggestion resolves the issue.
  1. Re-insert the memory into the same slot.
  2. If you have more than one stick of memory remove all but one stick of memory, try rotating through each stick.
  3. Try one stick of memory in each slot.
Thanks,
Please rate me.......
Apr 04, 2010 | HP Pavilion dv6000 dv6100 dv6200 dv6300...
Intel desktop board D845wN - no screen display
HI,
Switch on your computer and listen for a beeb sound.... if no beeb sound available then your Motherboard has a problem.
if beeb sound comes then switch off your computer and see for the loose contacts on motherboard.
eg. remove ram, clean ram socket and put back the ram
your problem may solved.
thanks
ehsan (md_ehsan_1@yahoo.co.in)
Jun 15, 2009 | Intel Desktop Board D845WN Motherboard
Long beeb sound
find out what brand your motherboard is and look for the beep codes, each motherboard is different but these beeps are there to tell you the problem. if it isnt turning on when you press the button it is most likely a power supply problem like you said and you should try reconnecting all the power connectors to the motherboard and make sure everything is in place. also look for the voltage switch on the back and make sure it isn't at the wrong voltage that has happened to me more than once ;)
Dec 13, 2008 | Intel Motherboard
The screen stay black on booting computer, it's an acer aspire
plug an external monitor to see if the laptop is booting up at all, it could be the inverter or a memory address problem
good luck
Nov 16, 2008 | Computers & Internet
Not switching ON
It turned out that the bracket on my video card was too long and when i was tightening it , it was bending and stressing the video card. put in some spacers and it is working fine now
Nov 16, 2008 | Abit IP35P Motherboard
Problem withPanasonic phone
Unplug the power supply to the phone, wait 1 minute and plug it in again
Mar 05, 2008 | Lands Phones
Compaq Presario Notebook Logo
19 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
