Question about Biostar P4M80-M7 Motherboard
P4m800ce 8237 - Biostar P4M80-M7 Motherboard
Bios update
If updates are available, you can always get them from the motherboard manufacturer's website.
Why do you think you need an update? If something goes wrong like a power cut, or computer problem, your motherboard will be scrap. Doing bios updates is very risky and should only be undertaken if absolutely neccessary.
Regards
sir andrew
Nov 25, 2009 | Computers & Internet
I need to download a sound driver for Motherboard Model: P4M800CE-8237
This page should have what you need:
http://www.via.com.tw/en/resources/download-center/
Jul 11, 2009 | PC Chips MB PCCHIPS P25G V3.0 P4M800CE 478...
I want audiodriver for p4m800ce-8237-6a7l6b097 audio driver.
Most drivers I get are on the web site driverguide.com but you need to register and it is free once installed reboot the computer
Jan 22, 2009 | PC Chips MB PCCHIPS P25G V3.0 P4M800CE 478...
Motherboard P4M800CE-8237 Pin connection
Hi ohfs55, case's vary & so do the wire colors. The most common wire color for positive are colored wires. Blue, Green, & red. The most common color for negative is White & or black. I wasn't able to find your manual. If you have the manual for the motherboard there will be a page that will show where the positive & negative wire's connect for each jumper to the motherboard.
Without the manual I can not guide you through each connection. PW = power switch, RW =Reset switch, HD_LED = Hard drive LED ECT.
Mike
Oct 21, 2008 | PC Chips MB PCCHIPS P25G V3.0 P4M800CE 478...
Via p4m800 CE - 8237
You set your BIOS to "SATA = Enabled" under that set it to
" IDE ". Most 160gig HDD's are only 1.5gig max read/write. Hope you left the jumoer pin on.
Dec 03, 2007 | PC Chips MB PCCHIPS P25G V3.0 P4M800CE 478...
Biostar P4M80-M7 Motherboard Logo
24 people viewed this question
Top Biostar Computers & Internet Experts
Jayburt
David
David
Martin Murray
Are you a Biostar Computer and Internet Expert? Answer questions, earn points and help others
