Question about Rv Slide Out Awning Cover Motorhome Slideout Trailer Awning Slide-out Kover Iii
Leisure battery won't charge when plugged in at mains
  • 2,113 Answers
Either the battery is no good, the clamps are to dirty (invisible oxides or tarnish can create a voltage drop) or something has gone wrong with your charging center. You may have to pull out your charging center to see if it is switching when plugged into a land-line or generator. It may need the voltage rectifier or voltage regulator replaced. Or the relay needs to be cleaned up or replaced. disconnect the wire coming from the charger and test if it has a voltage. If it does work it has to be slightly higher than 14 volts to be able to trickle charge the battery.
Posted on Oct 22, 2013
    Problem Solver:
  • 18 Answers
Open caps water is probably low in cells do not put in tap water only use distilled water .gas is very explosive beware acid will burn beware
I change split charger relay on my circuit and it look like leisure battery still not charging
Check to see if the relay is getting power to get energized and allow current to flow to auxiliary (leisure) battery.
Jan 07, 2015 | Cars & Trucks
The lithium battery won't charge
If the lithium battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all. OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time. If the battery drops to an unacceptable charge level then the battery needs to be replaced. Rechargeable batteries will fail if stored in a discharged state for long periods.
Apr 02, 2013 | Cameras
My Tomtom 300 Go won't charge?
It appears that the battery will not hold a (good) charge anymore. If it is still under warranty, contact TomTom to address that problem. They may replace the unit for you.
It is not unusual for (rechargeable) batteries to loose it's capability to hold a good charge if it is plugged in (to a power source) all the time, even while it is not in use.
May 06, 2012 | Tomtom GO 300 GPS Receiver
My zen vision m 30 gig only comes on when plugged into the mains
If the recharageable battery is more than 3 - 4 years old then the battery could be worn out.Rechargeable batteries have a finite number of charge and discharge cycles andwill lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up at all. OR Thebattery shows a 100% charge but when the adapter is disconnected the batterydrops off to zero capacity in a very short time. If the battery drops to anunacceptable charge level then the battery needs to be replaced.
May 01, 2012 | Creative Labs Zen Vision Digital Media...
I have hp notebook compaq 1610p battery won't
The battery is dead, replace it. If the power cord works and the battery is not charging, then the battery is dead. The battery only has a useful life then it has to be replaced.
Apr 26, 2012 | HP Computers & Internet
Battery showing fully charged- battery charger on but ...
You have a bad connection at main panel, causing voltage drop to system. Check all connections in electrical panel and transfer switch.
Sep 13, 2009 | Electronics - Others
Everything works, but the screen is black
before I fried the pcb used to occasionally get the same problem. I run, sorry ran (still hoping) direct off a large 12 volt leisure bank. Used to take it as a sign that the batteries needed a charge. Will simply reset by cutting cuirit breaker (or pull plug) and put back in. Will go again if you haven't got the watts. So sort out your battery bank. As the thing comes with a step down transformer to run off mains, you may think "what are you talking about batteries for, it runs off mains", never ran on mains but if plug unplug doesn't work suggest you need a new 12v 36w transformer
Jul 18, 2008 | Cyberhome CH-LCTV 150 15 in. LCD...
Battery overcharging from alternator output
It is not your battery overcharging it is your alternater putting out to much juice to the battery. get a new alternater
Jul 03, 2008 | 1991 Peugeot 405
Rv Slide Out Awning Cover Motorhome Slideout Trailer Awning Slide-out Kover Iii Logo
130 people viewed this question
Top Unknown Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you an Unknown Vehicle Part and Accessory Expert? Answer questions, earn points and help others
