Question about Epson Office Equipment & Supplies
How do i change the ink catridge? - Epson Office Equipment & Supplies
2 Suggested Answers
  • 14 Answers
SOURCE: how do l change the ink catridge?
the opening from which the papers are coming out ,, above it ,, white cover,,,,, in the middle of it a pit place for ur finger,,,, pull it down ...it will open...... wait untill the cartriges appear....(((( u r working while the printer is turned on for sure) then on the edge of the cartrige u want to change ,,,,on its edge pull down or press down,,,, get it... and replace and push up the new one... thats it ... hope it works with u
Ahmed Nabil
Ahmednabil6@hotmail.com
Posted on May 04, 2010
We changed the ink,and when we installed the catridges it doesn't work.It shows that the catridge doesn't have coloured ink.
If you are using compatible ink cartridge then the problem is that they are compatible with your printer try to use original ones or try an other compatible ink manufacture
Good Luck
Dec 21, 2010 | Office Equipment & Supplies
Cartridge error code 1203
HI Don,
It's mean your catridges overflow even from brand new catridges after a several prints or right after you refilled the catridges. Check to see if ink are smeared on the holder where the contact panel with the catridge
Solution
Use the klennex with a few drops of water to dampen and clean off those contact on the holder and printer may work again.
The refill ink work very well if you let it sit 24 hrs. Then before you print anything, you should run aligned the catridges a couple times then run clean catridges a couple times.
Print the test page to see how it's look and way you go.
Be sure not to leave any debris of klennex on those holder contact panel.
-rate this if it helped you.
Apr 08, 2010 | Dell 962 Photo All-In-One InkJet Printer
How to change the ink catridges in cannon MX310
please your open the printer head couver and you there ink catridge
and out of printer and add ther in place in printer and close the printercouver
Sep 14, 2009 | Canon PIXMA MX310 All-In-One Printer
Reset ink level on hp 6310 #98 cartridge I have been using refilled cartridges and the in level is ''empty'' even when the cartridge is new and just filled. how can I reset the ink level?
if you are using a refilled catridge you would not get ink levels right.
if you want right ink level use genuine ink catridges.
you can try taking out the catridges turning off the printer and turning it back on and then reinstalling the catridges.it might not help so if possible buy hp ink catridges.
Aug 27, 2009 | HP Officejet 6310 All-In-One InkJet...
I cant print it is showing e5 on printer screen
hi,
CANON PIXMA MP160 All-In-One InkJet Printer
has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
http://www.canon.com/printer/prob676ijt65/solution
tokio-3
Jul 30, 2009 | Canon PIXMA MP160 All-In-One InkJet...
Error 1203 how do I fix it?
try this solution:
It's mean your catridges overflow even from brand new catridges after a several prints or right after you refilled the catridges. Check to see if ink are smeared on the holder where the contact panel with the catridge. I have the same problem which I think lexmark have a proble and overlook.
Solution:
I use the klennex with a few drops of water to dampen and clean off those contact on the holder and my printer work again.
Too bad that I also cound not find out how to reset the ink indicator. It's annoying to hit the OK button every time you want to print.
Try and see if it's work for you. Good luck......
Jun 10, 2009 | Lexmark X4250 All-In-One InkJet Printer
Catridge problem
when printing try to press resume button for about 5 seconds
Apr 06, 2009 | Canon PIXMA iP1800 InkJet Photo Printer
Printer will not start after changing ink cart.
u better remove both catridges ,switch on the printer ,after that the print catridges lights will blink ,open the cover the catridge holder will come at the centre,put the catidges n perform the catridge alignement,n complete it
Dec 19, 2007 | HP Photosmart C3180 All-In-One InkJet...
24 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
