Question about Rainbow E series Canister Wet/Dry Vacuum
My problem/// cleaner turns on for a around ten (10) seconds and then shuts off wait a few minutes and it will turn on but goes off again at ten (10) seconds?????
    Novelist:
    Champion:
  • 210 Answers
These units have a automatic resetting thermal fuse near the motor to help to protect it from burning up by running too hot. This will need to be inspected and tested to see if it's holding it's proper temps., if not it will have to be replaced. There should also be an inspection of the machine to detect what was causing the reset to shut down that quickly, so that can be repaired as well.
Posted on Oct 22, 2013
Polaris p93 shuts off after a few minutes
Best bet would be return as defective and get a new one
May 27, 2014 | Polaris New P93 Premium Robotic Automatic...
Tip
Miele vacuum cleaner suddenly stops
So this is a problem I identified in Miele's mid size ranged canister cleaners. Not only the S318...
If you go about cleaning on the highest power setting the engine will overheat after 5-10 minutes. It then will need around 20-30 minutes to cool down before you can use it again.
Tip: Don't run the machine on 100% power, instead turn the setting to around 80-90% and then you can enjoy good suction un-interrupted.
on Jan 28, 2010 | Miele S318 Bagged Canister Vacuum
My vacuum cleaner will run for a few minutes and then shuts off. The plug light on the panel blinks. I thought the motor was shut, but after a long time it will turn on again, but again, only for a few...
I know nothing about your particular vacuum, but many vacuum cleaners these days have
safety cut out's, which causes the motor to do exactly what you describe. Sadly blockages, faulty switches, over stretched cables, carbon brushes etc could also give similar symptoms, so sounds like a job for the repairer on this occasion. Get a quote first if you can.
Feb 06, 2011 | Electrolux Epic 6500 Vacuum
The unit works well for 3~4 minutes and then stops. Wait another 10 minutes to cool down and it works again but the same issue happens again and again. It is a brand new unit. I read the manual for the...
Hi, I have a Hoover Bagless myself. I also have worked professionally fixing Vacuum Cleaners. There may be some material caught between the roller end and the end bearing or the edge of the roller compartment. This could be causing excessive friction causing the motor to overheat. Like a piece of carpet fabric that wrapped around the end. However, that is not supposed to happen to a vacuum cleaner. If you turn the vacuum cleaner over, exposing the brush, you may find it. And be able to remove.
HOWEVER: This is supposed to be a premium Vacuum. It has a very high rating. It certainly is still covered under warranty. I would take my receipt, be safe, and exchange it.
I hope this helps,
Have a Happy New Year
Best, Mark
Jan 01, 2011 | Hoover UH70015 Bagless Upright Cyclonic...
My iRobot Roomba runs for about ten minutes, then shuts off. I can keep pushing the clean button and it will run for another ten minutes and stop again. Nothing seems to get clean.
Take the brush rolls out and you should see a copper disc. It is the dirt sensor. Clean it with Windex or some other cleaner. This works sometimes.
Sep 08, 2010 | iRobot Roomba 550 Vacuum
I have lux4000 vacuum cleaner. It started to shut down in brush mode vacuum in after 10 to 15 minutes. Motor seems hot when I touch the bottom part. It will start up after 10 to 15 minutes but shuts down...
It sounds like something is catching in the brush. Remove all foreign matter from around brush. Ensure belt is properly engaged. Ensure brush is installed correctly.
If these don't correct the problem, consider taking it to an authorized service center.
Aug 23, 2010 | Vacuums
MY CLEANER CUTS OFF
Check that the bag is not full, check that is not a broken contact in one of the wires.
Jul 13, 2008 | Hoover S3639 WindTunnel Bagged Canister...
MY CLEANER CUTS OFF
My Hoover S3639 on/off switch stopped working. I don't hear the 'click' any more. I removed the top of the vacuum but can't determine how to replace the switch.
Aug 18, 2007 | Hoover S3639 WindTunnel Bagged Canister...
Rainbow E series Canister Wet/Dry Vacuum Logo
183 people viewed this question
Top Rainbow Vacuums Experts
Joseph Hoffmann
Jax Planet
Jax Planet
Are you a Rainbow Vacuum Expert? Answer questions, earn points and help others
