TUNING IN A TELEVISION
I have been given a television but no manual and no obvious way of tuning in the channels from the remote or tv.Can you help?
  • 3 more comments
  • percyplant Sep 28, 2007
    ORION TV455BR
  • Anonymous Mar 28, 2008
    Hi, I have been given a samsung w288ns television has anybody got access to a tuning guide. Thanks Stuart
  • compensation Jul 15, 2008
    I cannot change the channels. I have replaced the battery. and still it won't change channels. Help
  • adrian512 Aug 01, 2008
    I have a Sony KV-M2531U and no manual. COuld anyone help??
  • Anonymous Sep 01, 2008
    Cannot get the tv nor the radio to play at all. Only the weather channel and there is no way to turn it off.
  • 363 Answers
Please could you provide a Manufacturers name and the model of TV. One of us might be able to find a manual for you. Cheers.
Posted on Sep 28, 2007
Can anybody help me find a remote control for naxa 9`` televition_?
thank'you.
Posted on Jul 25, 2008
SOURCE:
Programming my tv with a remote
you can program the channel manually, just press the menu button in the tv panel. select preset and then manual fine tuning to tuned every channel you want to watch and then save it.to make a manual fine tuning, press manual then select channel you want to tuned and then press vol. up/down button to search right frequency channel.do this process in every channel you want to tuned. hope this can help.
Sep 15, 2012 | Haier HL24XLE2 LCD TV
Have tried twice but do not seem able as channels seem all over the place . do not have manual.
Hi, the problem will not be with the remote control. It sounds like you are performing an autoscan when tuning your television. The only time this process works is when all the channels are in order and there are no weak stations in between that could be potentially picked up by the television.
Do you have a manual for the Television as all you need to do now is to sort your channels in the tuning mode.
This should fix your problem.
Hint - Google is your friend
Mar 20, 2010 | Televison & Video
I am unable to pick up sky and set it to a position on analogue tv settings. The Tv is sanyo ce26ld90b.
If first we could ensure some connections are tight before moving into TV settings.
You have told me that you are using sky over an analogue connection. Make sure that these are plugged in at both ends (sky box and TV) and that your sky box is on.
Now using your TV remote, enter the TV settings (there should be a button for this specifically on your remote), and opt for Tuning and manual tuning. The layout for most TV settings are similar.
By manual tuning, you are able to select the number on which you want to view a channel (in the analogue case, Sky as a whole is considered one channel on your television)
Now you should be able to use the left and right keys on your remote to tune up and down a range of frequencies, one of which Sky will be on. Once you have found this frequency, you should store it to the channel you have selected.
To my mind, the only thing that would then cause this to reset is if you turn off your TV from the mains each time you finish using it.
Aug 23, 2009 | Sanyo Televison & Video
Tuning a Grundig Tele Pilot 750c Television
It might be an old hotel tv. Try this, it worked for me
http://www.tvtuning.co.uk/makes/grundig.htm
basically you hold the i button whilst turning on the tv.
ta
Jan 07, 2009 | Grundig GF70-600 TV
How Do I Tune VCR to the TV
I have a panasonic analogue television, and I cannot tune in a Goodman VHS VCR to the television. I have no remote controller for the television, and use the buttons on the front of the set to change stations 1-5. I have however found AV on the television screen and the indication is that the VCR is trying to come through when switched on. I have got a remote controller with the VCR. Can you help me please ??
Mar 14, 2008 | Televison & Video
Tuning My Tv
If you've store the earlier channel, off the tv and on it again. Every should come back as normal.
Regards
alan
Mar 02, 2008 | Televison & Video
Tuning
I have a hikona 14" tv havew lost the tuning manual. Can you help!
Dec 22, 2007 | Philips Magnavox Learning Universal Remote
Sony Television KVX2162U
Hi
You did not mention if you have the remote. You need the remote to tune this model.
On remote, press Menu, once the menu there, curser to the bottom item which is for auto/manual tuning.
You would need original or copy remote, universal one may not work.
Capital98
Nov 30, 2007 | Televison & Video
Televison & Video Logo
413 people viewed this question
Top Televison & Video Experts
Ekse
