Question about Kenmore Refrigerators
Refrigerator area freezing anything I put in it. have it turned off still running.
    New Friend:
  • 26 Answers
Turn the refrigerator off at the power source - leave off for two days - clean the cabinet and then return to normal service - sometimes ice can form on the damper temp control stopping it from closing - this then allows to much cold air from the freezer to enter the fridge freezing everything in it - worth a try as a quick fix
Posted on Nov 28, 2013
White Westinghouse ( Model# MRT 18FNEWO
refrigerators only have one cooling system and that is for the freezer. The fridge part is cooled by sending a portion of the air from the freezer to the fridge. your fridge thermostat controls a fan that turns on and off as needed. first step is to make sure this is working, and not stuck on. turn your fridge to a somewhat warm no and open the door for a few minutes to allow the cold air out then check and see see if it gets very cold again within say an hour. if it does your fan is always on and you need to repair it. if that is working then you have to play with both freezer and fridge settings. best thing is to get a cheap thermometer and check your freezer temp. it should be around 0 to -5f if it is colder than that frigid air blowing into your fridge too cool the whole area will freeze anything close to the vent. once you have your freezer set then start adjusting your fridge. personally I have mine set at 34f knowing that some things on the top shelf will freeze. but I like my cola's COLD. so I put things like butter that are harder to freeze at that level. but if you don't want anything to freeze then a temp of 37 -39f is correct for your fridge. so it comes down to freezer temp, the amount of time the fan is on, and proximity to the vent. good luck
Nov 24, 2011 | Refrigerators
KITCHENAID SIDE BY SIDE REFRIGERATOR FREEZER DOES NOT FREEZE LIKE IT SHOULD BE. STILL WILL MAKE FEW ICE FROM THE ICEMAKER BUT DOES NOT FREEZE LIKE IT SHOULD BE, REFRIGERATOR IS AT ITS MAX TEMPERATURE WHEN...
Clean condenser coils, remove anything around refrigerator that might prevent air flow on coils. Make sure freezer and fresh food area door are completely closed.
Aug 01, 2017 | Kenmore Side by Side Refrigerator
Refrigerator and Freezer Not Cooling nor Freezing
That leaves only one possible fault; the volatile component of your coolant/lubricant has escaped.
If the unit has been moved or cleaned carelessly, one of the coolant- bearing tubes has developed a leak. Any refrigeration tech will have a leak detector in his tool set so it shouldn't be difficult to find.
Depending on the area in which you live, expect the troubleshooting and recharging to run ~$150-$250 US.
If you reside in the US, check your local (area) Better Business Bureau for a trustworthy service company.
Mar 16, 2009 | Amana 22.6 cu. ft. Side-By-Side...
Anama bottom freezer
Chances are if they are getting cool -
1) the evaporator fan in the freezer is not running
2) Defrost heater has failed
3) Defrost sensor has failed
4) Defrost timer/refrigerator control has failed.
Check for ice build-up on the back wall of the freezer. If there is ice, unplug or turn the unit off for 6-8 hours with the doors open (put any food in a cooler with ice to maintain). Note water may come out of the refrigerator/freezer.
Plug the unit back in or turn it back on, close the doors, and check temperature after a couple of hours of operation. If all OK, you will need to have the above tested, or, if you know how to use a multimeter and can read a schematic/wiring diagram, I can instruct you on how to check the above.
Jan 16, 2009 | Amana ABB1927DE Bottom Freezer...
Amana refrigerator
Check to see if your condeser fan is runnig properly you may need a fan motor.
Jan 04, 2008 | Avanti FF1101W Top Freezer Refrigerator
Freezer and fridge areas both 50 degrees
Assuming you have a frost-free refigerator:
Is your motor-compressor running?
If so, check if you have ice in the freezer section; if so, maybe your defrost thermostat or heating element is kaput.
If the motor-compressor is not running, check in the back of the refrgerator if the defrost time is stuck open, bu turning clockwire the small test screw, with a 1/2inch screwdriver.
Dec 10, 2007 | GE GTS22KBP Top Freezer Refrigerator
Refrigerators Logo
55 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
