Question about LG Silver Tilt/Tilting WaMount Bracket for 50PC1DA Plasma HDTV TV/Television
LG 50pcida 50" television- when the tv has been off for a while it is difficult to get it back on. It will turn itself off immediately after you press the standby button about 5 times before it will stay on. Can anyone help?? Thanks :)
  • 8457 Answers
SOURCE: LG 50 inch plasma has trouble powering up. have
Power supply board have dead capcitors.Know how to solders?These capacitors usally bulge or pop open,replaced these capacitors will solved this problem.Or tries websites Shopjimmy.com,Ebay.com to buy a Whole reburbish power supply board for the replacement.
Posted on Mar 10, 2010
  • 380 Answers
SOURCE: LG 42 Plasma try's to turn on but just goes back into "stanby" ?
Check to see if you get Va and Vs voltages from the power supply. There should be some wires running to the y-sus. A couple of those wires will be labeled va and vs. Are they present? There will be a sticker stuck to the panel somewhere telling you what they should be.
Posted on Mar 26, 2010
itvrepair
  • 28 Answers
SOURCE: my lg plasma tv stays on standby
is you already change the power board,is possible
your y board is out...is a big board on the left side of the tv
Posted on May 19, 2010
  • 8457 Answers
SOURCE: LG 50PG20. My TV keeps turning off by itself! We
This problems it is the causes by the tv power supply board.That the board,where the power a/c cord plug into it.Try website like Ebay.com to buy a whole refurbish power supply board for the replacement.
Posted on Nov 24, 2010
SOURCE: LG 50PC3D 50in. plasma.... TV works
Hi, this could be a problem with the power supply in the tv, it is common especially on some Samsungs and specific repair kits are available quite cheaply if you have good soldering skills, this can also apply to many other Flat Screen TV's .
Usually this is caused by capacitors that have dried up and split, you can normally tell as the capacitors are bulging on the pcb, you can get them in a kit as I said eBayer's sometimes do them or you can buy them indivually from a good electronics components supplier, make sure you get the correct values for each!! marked on the side of the capacitors in xx/x V, xxx/x uF and 105oC. (the x's represent numbers)
The picture below shows the type of theing that happens, the brown ones are bulging/split on the top whereas the black one is fine.
High Voltages can exist in these sets, never attempt anything while plugged in and
if in doubt do not attempt it yourself and seek the advice of a qualified TV Technician.
There could also be dry solder joints on the panel, usually applies to the power supply as it's mainly these get the hottest.
Here's an example of what dry joints look like.....
It's also worth considering claiming under the warranty for replacement or repair through you dealer if warranty is valid.
Hope this helps
Midge.
Posted on Feb 12, 2011
Just bought an LG Plasma Screen TV. 50' 50PV400 I turned it on, and the picture was there. After a couple minutes the picture is no longer available and the screen turns black while the sound...
The tv is faulty and the fact that it failed immediately after you have started it for the first time is a clear indication of a manufacturing defect.
Take the tv back to the seller and ask for a replacement one or your money back.
Jun 01, 2011 | LG Televison & Video
Lines on the screen, coloured ones and black ones lg 50pcida
hi there, last night, my 50 lg decided to stop working, im getting a fuzzy picture, no audio and everytime i use remote to turn on tv it keeps doing the same thing?
May 29, 2011 | LG Televison & Video
LG 50PG20. My TV keeps turning off by itself! We can turn it back on immediately but less than 5 minutes later it does it again. How can I fix this?
Nov 24, 2010 | LG 50PG20 50 in. Plasma HDTV
My LG Plasma tv 50pb4d constantly turn itself off. Has been doing it for a year.is this a common problem and can it be fixed?
yes it is, and yes it can. BUT it maybe a difficult problem to determine if it is intermittent, you will be best served waiting until it fails "Hard On" otherwise it may take some time to find the intermittent fault. http://www.retrevo.com/support/LG-50PB4D-TVs-manual/id/3068bh134/t/2/
user manual above service manual below.
http://www.jordansmanuals.com/ServiceManuals\LG\TV\PLASMA\50PB4D\50PB4D%20Service%20Manual.pdf
May 23, 2010 | LG 50PB4D 50 in. Plasma HDTV
No picture. can turn off for a while, then picture will return for a shrot while.
I try to turn on the TV but green light turns on then immediately back off. The TV is 3 years old 50" LG Plasma
Dec 31, 2009 | LG 42LC2D 42 in. LCD HDTV
Tv doesn't turn on
Defective Power Board. I replaced mine today but I have some experience in Electronic. Cost 180.00.
Dec 13, 2009 | LG 50PC1DRA 50 in. Plasma Television
Toshiba 50HP95 - noise in back of tv and then turned itself off
I would contact guy at
plasmatech@gmail.com
he has great expertise and all parts for Toshiba Plasma TVs
Jan 08, 2009 | Toshiba 50HP95 50 in. Plasma Television
LG Silver Tilt/Tilting WaMount Bracket for 50PC1DA Plasma HDTV TV/Television Logo
19 people viewed this question
Top LG Audio Players & Recorders Experts
Electro Med Services...
Are you a LG Audio Player and Recorder Expert? Answer questions, earn points and help others
