Question about Kyocera FS Office Equipment & Supplies
KYocera FS-3700 Nothing at all happens when I switch it on; nothing on display. Presumably power supply failure and I will have to scrap (recycle) it?
  • Kyocera Expert
  • 337 Answers
You can replace the power supply
Posted on Jan 02, 2014
Benimur
  • 6966 Answers
SOURCE: Looking for Kyocera Mita Ecosy FS-1010 Instruction Manual
A downloadable copy of the Kyocera Mita FS-1010 user manual is available here.
Good luck and kind regards.
Thank you for using FIXYA.
Posted on Feb 12, 2008
SOURCE: CLEANING A KYOCERA FS-2000D
Follow the page http://www.fixya.com/support/t1336338-kyocera_fs2000_thin_black_vertical_line
Basically, you remove the cartridge and developer all at once, then remove the waste toner bottle, then push the grey tab in to release the drum cartridge (be very, very careful in removing and putting back in. Any scratches on the drum and you will enjoy black spots permanently on printouts).
On the right side of the grey charger section is a tab you can use to release it. Do this, then put the drum away in a light tight back to prevent damage to it.
The reason why this Kyocera printer doesn't have the primary charger wire cleaner is because it did away with it. It now charges via a black fuzzy looking roller on top which is like the secondary corona charger wire, which then applies it to a roller, which then applies it to the drum. I think this is nice since it should prevent printer quality problems better since there is nowhere for oxidation to really collect. But, OTOH, it does happen anyhow.
I cleaned mine off and the streaks disappeared. I used a non amonia based cleaner to help, since I didn't find any dust on it to begin with. Whatever you choose, do not get your fingers on it, or it will put oil onto the rollers and that will make it worse.
Worked for me.
Posted on May 25, 2009
  • 3 Answers
SOURCE: Kyocera FS-1020D lights blinking but doesn't respond
Fuser error (6000 error)
Contact your Kyocera Mita dealer.
Unfortunatly there is not much You could do Yourself
This error means that the fuser is either damaged or not connected properly to the rest of the printer. If its connection error You could try to fix it but in most cacses the fuser is just broken ie. overheated due to not enough air flow.
Posted on Jul 24, 2009
SOURCE: How to scan from Kyocera
There is a send button on the left of the control panel. after pressing send, use address book, and chose where to send to....obviously your address book must be setup first
Posted on Mar 15, 2010
Comp-U-Doc
  • 148 Answers
SOURCE: the 3rd light on my Kyocera FS-1020d is flashing red, no printing
The flashing is a code. Depending on if it is flashing fast, slow or so on...
Turn to page 32 of this manual for more information.
If you are satisfied with my answer, be sure to click on the "Thumbs-Up". If you have further questions, please feel free to ask them. Thanks for using our service!
Posted on May 15, 2010
IT Won't power up.
Possible failure of the main power supply unit which is a switch mode power supply.( SMPS).
You need to disconect the power supply to the printer and open the panel to check the SMPS unit.
Please check on the link below for tips to check the SMPS unit. If this is not possible check with a power supply unit to confirm before you order.
http://www.fixya.com/support/r5826301-working_switch_mode_power_supplies
Jul 29, 2011 | Kyocera Mita FS-C5016N Printer
I just switched off my "Kyocera FS-C5016N" accidentally. When I switched it on again 1min later the red light was glowing and the display showed "Call Service F020". What does it mean?...
Hi misterqm,
  1. From from you have mentioned, I understand that that there has been a fault in your printer's software programming , this is usual for such "contact service" errors, this error not just come up in printer , but also in mobile phones and other such electronic devices.
  2. I would recommend you to take the printer to the authorized service center so that they can repair it for free if it's under warranty or guarantee , or they may replace this as a defective production.
  3. Please make sure you don't open up any seals on the which exist on the printer to not void warranty , in case it's still under warranty.
  4. If it's not under warranty , then you should take it to the kyocera service center so that they can re-install the software in your printer for you.
Hope this helps ... :) Your feedback would be appreciated.
May 16, 2011 | Kyocera Mita FS-C5016N Printer
Kyocera FS 920 won't talk to Mac OS 10.4
try this tutorial or this one and keep one thing in mind there is a generic print driver that mac can install this often works just as good as the one from the manufacturer
Sep 14, 2009 | Kyocera FS-920 Laser Printer
I send a print job to the printer and nothing happens
try downloading the latest print driver from www.kyocera.com or www.mita.com you may have a corrupt driver or it may be incompatable with an update
Jun 11, 2009 | Office Equipment & Supplies
Kycocera fs2000d
Sounds as if the fuser unit has a damaged gear.You will need to call out a technician.
May 01, 2009 | Kyocera FS-2000D Laser Printer
Computer won't start
The power supply is fried partially, or the motherboard went poof.
Dec 19, 2008 | Antec TruePower 2.0 550W 24/20pin nVidia...
Printer not printing - showing 'processing' but nothing happening
Reinstall the driver again, if it doesnot work, you have to update the firm ware of the machine, you can find this on kyocera website.
Nov 25, 2008 | Kyocera Mita KYOCERA/MITA - FS-2000D Mono...
Error Code explanation for Kyocera FS1700+
l e d are villings countineve one by one up to down
May 26, 2008 | Kyocera Mita FS 1000+N Laser Printer
35 people viewed this question
Top Kyocera Office Equipment & Supplies Experts
Kyocera HP Expert
CheckitRight
CheckitRight
Henry Gertcher
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
