Question about Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator
Kenmore 106 freezer side wont go below 15 degrees
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 56 Answers
Did you try it with the manual? Kenmore Coldspot Model 106 Manual
Posted on Nov 17, 2013
4 Suggested Answers
HVACRH20
  • 237 Answers
SOURCE: Kenmore Side by Side Refrigerator, freezer doesn't work, refrigerator works
Unless specifically made for use in a garage most units won't work properly. The owners manual should say what the temp range for proper operation is (usually 55F is the low range). This is because the refrigerator section doesn't need to be "cooling" to maintain 37F if the temps on the outside are below 55F. These things are made to work in a 70F room and will not work properly if under 55F. Stupid thing thinks it's cold enough so it will never turn on, the refer section will stay cold/cool due to outside temps but since the compressor never runs the freezer will just be the same temp as the refer section (at best). Sorry, but in order for a freezer or refrigerator to work in an unheated space it must have the temp control device controling the freezer section NOT the fresh food section. In other words, that model will not work in a garage unless the temps are above 55F always.
Posted on Feb 08, 2007
VANMAN69
  • 23 Answers
SOURCE: freezer works ok.refrigerator temp varies from 39 deg.to 60 deg.
check to see if there is frost in the back of the freezer if so you have a defrost prob..
Posted on Jun 29, 2007
  • 2318 Answers
SOURCE: kenmore elite refrigerator
If this appliance is new, I would suggest to contact the vendor or manufacturer and ask them for in home service.
It could be the thermostat that might be not working properly or not set properly.
Check the user manual for more info on the thermostat settings.
Posted on Jul 08, 2008
Kenmore 106 56703500 Freeze is cold refrigerator is not
The problem could be an intermittently defective temperature control.
May 16, 2014 | Refrigerators
Icemaker is not making any ice after freezer defrosting, how long should I wait ?
Normally a new batch of ice is produced every two hours or so. The ice maker will not eject any freshly made ice until the interior temp of freezer is about 10 degrees; at that point the thermometer will close and initiate the ice ejection and the other steps to make more ice.
Nov 27, 2013 | Refrigerators
Need bolt torqe specs , rods, mains, oil pump & oil pan for 6.0 vortec engine thanks
Connecting Rods: First pass 15 lb ft. If you have an early first design final pass 60 degrees. Second design 75 degrees.
Main Crank Bolts: Inner bolts first pass 15 lb ft. A final pass additional 80 degrees. Tighten the outer bolts/studs 15 lb ft. Final pass 53 degrees.
Tighten the side cap bolts to 18 lb ft. Tighten the bolt on ones side of the bearing and then tighten the bolt on the opposite side of the same bearing cap.
Oil Pump Bolts: 18 lb ft.
Oil Pump Screen Nut: 18 lb ft
Oil Pump Screen Bolt: 106 lb in
Oil Level Indicator Tube Bolt: 18 lb ft
Oil Level Sensor: 115 lb in
Oil Pan Drain Plug: 18 lb ft
Oil Pan Bolt: 18 lb ft
Oil Pan (to front cover): 18 lb ft
Oil Pan (to rear cover): 106 lb in
Oil Pan Skid Plate Bolt: 15 lb ft
If you need more specs contact: melissapowers75@gmail.com
Feb 02, 2010 | Chevrolet C2500 Cars & Trucks
Kenmore Cold spot 106 Warm Fridge
I would replace the evaporator fan, this fan problem is hard to diagnose because the fan will spin but not fast enough to circulate the chilled air thru the freezer and the refrigerator. The minimum cost to repair/replace is around $300.00
Jul 26, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Warm refrigerator compartment
There is a fan that blows the cold air down from the freezer to the fridge compartment. It is usually called a freezer fan. Most of them are behind the plastic lining in the freezer. I just noticed that your fridge is a side by side. I have never wored on a side by side but I imagine there is fan in them as well.
Jul 06, 2009 | GE GSH25KGRWW Side by Side Refrigerator
Side by side freezer cold fridge not
the freezer may be overload or poor air circulation inside the freezer
Mar 10, 2009 | Kenmore Refrigerators
Vegetable & Meat Tray Freezing on refrigerator
you have the freezer set too low. set it at -02 degrees and then turn up the adjustment for the meat tray and the humidity up on the vegetables. let me know if this helps.
Jan 08, 2009 | Kenmore Refrigerators
Refrigerator is freezing at the bottom and 60 degrees at the top
probably the fan is not running
take the fan housing off and you may find a buildup of ice preventing the fan from running
Nov 29, 2008 | Kenmore 53642 / 53644 Side by Side...
ICE MAKER NOT WORKING
Check to make sure you freezer is at 0 to 5 degrees. If it is not the water valve to the ice maker will not even open.
Nov 20, 2008 | Kenmore 53642 / 53644 Side by Side...
Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator Logo
219 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
Jim Goldsmith
Jim Goldsmith
jackdo2
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
