Tedelex Manual model T777
POWER SUPPLY RUNNING LOW BEYOND 120V LINE-OUTPUT. WHAT CAN THE PROBLEM BE.
exspert
  • 55 Answers
SOURCE: Have to change power input from 120V/60Hz to 230V/50Hz
ok " check the net for plug and power converters that plug in to
Singapore receptacle
Had a set for Europe worked great
Posted on Jan 22, 2008
Benimur
  • 6966 Answers
SOURCE: no output from power supply
I am assuming that you are very familiar with electronic circuitry and components, use of a DVM and a soldering iron. In the absence of a schematic diagram, and since you have perform initial voltage checks, perhaps you can wing it. Your "brick" will have to follow the basic design of an SMPS (switch mode power supply). Simply stated,an SMPS is an AC to DC to high freq AC then to lo V DC converter. Per your post, you have checked that there is DC (B+) from the AC mains, then what is needed is to check if there is oscillation to produce the high freq AC. Often design calls for an optical coupler, a small rectangular looking component with four pins, two at each end. This is nothing more than a LED and a Light Dependent transistor. Its function is to switch/trigger on the oscillation (and therefore start the SMPS producing the lo B+s).
Again, since there is no readily available schematic diagram, might I suggest that you post back the part numbers of the ICs and transistors. What we can do is pull out their spec/data sheets and/or application diagrams. Such would give us a general idea of the working voltages at what pins and what each component is supposed to do. Example, let us say your power supply uses a 817A/0635 opti coupler and/or an SG5841DZ controller IC, then we can search for them as initially described.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Posted on Sep 30, 2008
SOURCE: Hyundai HLT-3210 POWER SUPPLY FAULT LOW OUTPUT FROM SUPPLY PCB
Hello! My name is Ivica,and I am from Croatia.I have same LCD which have problem with motherboard.Try to disconect power supply from inverters and then measure all volt line.Maybe failure is on inverters board!Write me if you solve the problem,and maybe you know where can I find new motherboard for my LCD.Thanks.
Posted on Jan 24, 2009
  • 6 Answers
SOURCE: Ultra 40" LCD40-500--- Need power supply for this LCD TV--- see below for spec's
Hi!
If anyone would like a Power adapter for their Ultra LCD30-500 and LCD40-500 - please email me Acosta.cal@gmail.com... And I’ll be able to order one…
I too own a Ultra Lcd40-500 HDTV. Bought it from HSN.com back in 2006.
My power adapter burned out 2 weeks ago, and to my dismay PWW, or should I say POS has gone bankrupt.
I looked everywhere online and here in San Jose,CA thinking I would find a replacement or at least someone that could repair the blown capacitor( 630v vpmm), thermitors(IRFD460A) and varistor( SCK206).
After calling every power supply company, distributor, and retailer, had no luck finding a match to this crazy looking 9din pin adapter. Disappointed I gave up on a replacement and took it to various repair shops for repair and was told without schematic would be nearly impossible to replicate the power Output. Finally this one shop was able to replace the burned out components and it seem to work at the store. When I got home with it..no luck..red light would come on…but no light on screen. L
Not wanting to give up or trash my LCD. It was time to dig further…I did some research through my employer; a SemiConductor company here in Santa Clara, CA.
Needless to say this power adapter has driven me crazy….It has been exhausting... But finally just yesterday I got the break needed…I found a manufacturer in Taiwan that has these power supplies for both the Ultra lcd 30" and 40". I was told they only sell to Component or Electronic Suppliers. I’ve asked my employer to see if I would be able to order one on their behalf using their account.
Happy ending! My power supply is on it’s way. I was told it could take up to 4weeks for delivery. But I’m just glad to have a replacement.
Posted on Aug 15, 2009
SOURCE: 2Wire Power Supply
My 2Wire just died - I did not know because of the adapter or the router.
I went to Radio Shack to buy what Glen Smith suggested. They do not have them -
I bought Enercell 3/5/6/6.5/7/7.5VDC 2A (Serie 2730333) - plus using old Adaptaplug (I took from other Universal AC Adaptor). AND IT WORK !!!
Posted on Dec 08, 2009
WHERE CAN I GET DIAGRAM OF TEDELEX T777 CRT TV
TEDELEX may be able to supply a schematic diagram if you inquire.
Aug 05, 2016 | Televison & Video
I HAVE AN AC ADAPTOR,… CLASS 2 TRANFORMER FOR OUTDOOR USE THAT NEEDS TO BE REPLACED.. MODEL: KMUA - 240 - 05000- 66UL INPUT: 120V - 60Hz 570mA OUTUT: 24V - 50VA
Amazon has it.
AC Power Adapter 120V input 24V 50W (50VA) output, UL listed
www.amazon.com › ... › AC Adapters
Mobile-friendly - AC 24V Power Adapter; 50W Output (50VA); 120V AC Input; UL Listed; Ivory Color item in OEM box ... 24V20AC 24V AC 20VA Transformer Input: AC 110V / 120V 60Hz Output: AC 24V 880mA
Dec 09, 2015 | Computers & Internet
AC input pin broken
If it is part of the plug side that goes into the wall then it is not worth fixing. You can replace this pretty easy. On the front or back it will tell you what the input and output voltage are as well as the amperage. It will be 120v input and most likely a 12v output. Could be less like a 9 or 6 but that is the number you need to match. You will also need to match the amperage as well. It will most likely be in the milliamps. There are many universal adaptors that would work for you available at Walmart, Target, Best Buy etc....
Apr 13, 2014 | Casio CTK-541 Keyboard power supply ac...
I have a Sony trinitron wega model number is nd-36can955. when I plug it in the red light blinks but does.not turn on.
Hi
Your tv set needs to be serviced as it seems there is an overload in the supply line output (90/120V) which may be caused by the supply line rectifier diode or a shorted horizontal output transistor.
Sully
Sep 30, 2013 | Televison & Video
Wich is the power supply 120v, 208 1 phasse or 208v 3 phase.
Most Baxter BXA ovens have separate power supplies, usually 120v for the controls and lights, a 120v output on a circuit breaker for the roof fan, and a 208VAC 3 phase supply for your convection motor. Older Baxter ovens may have a 3 phase service disconnect inside the electrical/burner compartment, if I recall correctly the BXA models do not and the only way to shut it off is via the 3 pole breaker at the service panel.
Feb 04, 2011 | Baxter BXA2G Stainless Steel Gas Single...
Cat chewed phone power supply for GE cordless phone. Its in two pieces and also gnawed in many other areas of the line. Looking for a power supply replacement Thomson Inc 5-2812 IW506 Input: 120v 60Hz 0.2A...
Get you some electrical tape and cut cord where it's chew off and splice wire ( match white and black wire with the same and ......match black and black ok,,,after that tightly wrap only matched pair one at a time ok
Dec 03, 2009 | Uniden Cordless Phone
I need to get a power supply for Advent SUB
The adapter in question has the following specs:
Input: AC 120V 60Hz 30W
Output: AC 15V 1500mA 22.5VA
Nov 04, 2009 | Audio Players & Recorders
Cyberhome CH-DVD320 Doesn't Come On
If the 120V was at the connector with black and white wires, that's normal - it's the line voltage.
2V at the connector with black, red, and yellow wires suggests that one of the electrolytic capacitors is partially shorted. If you see one of the electrolytics that looks burned or bulging slightly at the top, you could replace it.
If you're not sure what an electrolytic capacitor is, I suggest giving the player away free or selling it for $1 on craigslist. It's an inexpensive player, anyway.
Aug 02, 2009 | Cyberhome CH-DVD 300 DVD Player
Re: Pyramid PS-36kx power supply buzzer sounded,red light came on
Hi! I saw your question, and maybe this will help. I also have a Texas Star 100w amp, and this same power supply. Even though the nominal draw for your equipment is way below the rated amp flow of the power supply, when you key up, and the output on the amp is at max, you are drawing the limit of your power supply! Try running this setup at a lower linear output. You don't need the full 100 watts to get out! 60-80 watts is aplenty! You should start at a low output, and slowly increase the output(while keyed up), untill the power supply starts to complain.(buzzer/light). This is what your limit will be. The only other cure, is a MUCH bigger power supply. Unfortunately, I cannot afford a 60-90 amp supply, so this is what I am forced to do to use the one we have. Also,keep your cb's output very low when using the linear amp. These amps are supposed to get a low signal from your radio, or the linear amp is overdriven. (noisy and unstable. Hope this helps you! 73's to you! jimsjinx
Apr 30, 2009 | Pyramid (PS36KX) 600-Watt Power Supply
Power supply/ no output voltage
Actually i haven't fixed the problem as yet but i did find some info that would help me to fix problem.
I went to google and entered keyword,,, Electronic parts,,there came up a page,,and i went to several manuf sites till i found a replacement transformer,,then i disassembled the power supply and am now waiting for a replacement transformer.
Sep 21, 2008 | Boston Acoustics MicroMedia Computer...
Televison & Video Logo
46 people viewed this question
Top Televison & Video Experts
Electro Med Services...
