Question about Swisher 60" 27 HP Zero Turn Lawn Mower - ZT2760B
Swisherinc com IT WILL NOT START. IT BLOWS FUSE WHEN YOU TURN KEY ON.
    Sergeant:
  • 317 Answers
If you leave this mower out in the weather you might have a wet ignition system. Clean battery, dry out switch (contact cleaner), inner locks and ignition parts. Do not jump the fuse to try to start.
Posted on Oct 22, 2013
I have a 2000 Buick century custom and I had drained my reservoir. Now everything I attempt to start my car my pcm fuse blows instantly. I've replaced my ignition switch and fixed my ignition column yet...
pcm fuse blows instantly ???? What number fuse , how many amps ? Where is it located ? under hood fuse box . ECM fuse 10amp ,underhood fuse box ???? When does the fuse blow ? when you turn the key to the start position . How about when you turn it to just on position ? Replacing the ignition switch an the column ????? Why did you replace these ? You think it was going to fix the problem ? or someother problem ? Bad computer maybe .
Sep 16, 2017 | Buick Cars & Trucks
Ford 99 Taurus ignition fuse keeps blowing every time key is turned
A bad something, yes.
The fuse may be the primary fuse for the key switch. If it is, you would need to disconnect the key switch harness and check for a short to ground on each circuit.
Jun 01, 2013 | Ford Cars & Trucks
30 amp Starter/Ignition fuse keeps blowing when i turn the ignition key. The instrumentpanel lights are dim and then the fuse blows.
I am assuming you are talking about the circuit that powers the key switch. I'm showing a fuseable link to the starter relay instead of a fuse.
If it is the circuit that powers the switch, I would disconnect the switch and see if the fuse blows as each circuit is powered one at a time using a jumper wire. You can get 30amp circuit breakers that plug into the fuse slot to use while you are testing circuits.
You may need a repair book or shop manual to find out what is powered by that fuse since it is most everything on the car.
Mar 01, 2013 | 1997 Dodge Avenger
40 amp main fuse blows wen turn bike to start
dead short in the wiring after the fuse
could be in the starter /solenoid if the fuse blows when you press start or turn of the key
May 21, 2012 | Harley Davidson Motorcycles
Every time I turn the key to start the motor it blows the 30 amp fuse what is the cause and how do I fix it
if the fuse is blowing when you turn key to start position then this is where to look for the fault ,between the ignition switch and the relay then the other side of the relay to the starter motor solonoid
Mar 05, 2011 | Ford Focus Cars & Trucks
When i turn my key to the start position the ignition start/run fuse blows. 2004 ram 1500 3.7 engine
probably a bad starter solenoid, first remove the negative battery cable, then remove the two wires from your starter, wrap them in black tape so they wont short out on anything, repl,ace your fuse and hook battery back up and turn key to start, no blown fuse-bad starter, if it blows the fuse it's a wiring short and you should take it to a qualified mechanic
Nov 24, 2009 | 2004 Dodge Ram 1500
Will not start and away blows the fuse when you turn the key. Change out the starter and fuel caoasitor
If the mower blows the fuse when you turn the key, the magnets under the flywheel have broken and are in direct contact with the stator, both must be replaced
Apr 29, 2009 | Garden
30 amp ignition fuse in engine compartment blows at start
It sounds like a bad ignition switch or something is grounding out.Try to isolate the problem to key positions.See if the fuse blows when you turn the key to ACC(when your dash lights come on without starting)If the fuse does not blow then when you go to start it and it blows it could be one of many problems,the more common ones could be ignition switch,wiring,starter relay,starter soleniod,or perhaps the starter itself is shorting out,this can sometimes happen when a starter goes bad.
Apr 12, 2009 | 1996 Hyundai Accent
No turn no start. blows the start fuel fuse intermitantly.
experience says the starter is the likely culprit....it has a bad spot in it
Nov 16, 2008 | 2001 Chrysler Sebring
Swisher 60" 27 HP Zero Turn Lawn Mower - ZT2760B Logo
125 people viewed this question
Top Swisher Garden Experts
lnbn1975
Tim Whalen
dannydoesita
Are you a Swisher Garden Expert? Answer questions, earn points and help others
