Question about Black Box IP Address Translator With Bandwidth Management (LR0051A) Proxy Server
Need ip address for Buffalo LS-WXL Series S/N 65850124513392
  • 45 Answers
To find the IP load the NAS Navigator from the Buffalo web site. It scans the whole network for Buffalo NAS and lists them all. Make sure the firewall is not blocking the software.
http://www.buffalo-technology.com/download_file.php?r=158
It is also available for MAC.
Posted on Oct 29, 2013
How to format a LS-L320GL?
Go to IP address of NAS box logon and then choose the maintenance menu in there select the drive and format
Apr 14, 2014 | BuffaloShop Buffalo LinkStation EZ 320 GB...
How to configure
The WHR-G54S has a default LAN IP address of 192.168.11.1
and Subnet Mask of 255.255.255.0.
Make sure your computer has an IP address in this range 192.168.11. x
Open your browser
type http://192.168.11.1
you will enter the web interface of the router
root is the username and no password is needed.
Configure your router.
http://cdn.cloudfiles.mosso.com/c85091/WHR-G54S-Manual-v1.9-web.pdf
Mar 22, 2014 | Buffalo Technology WHR-G54S Wireless...
Problem setting windows permissions on Buffalo Linkstation duo - NAS
Unfortunately, it is not possible in NAS unless it has a facility to mount LUN to windows server by ISCASI.
Jun 30, 2013 | Buffalo Technology Buffalo ls-wxl/r1 4tb
How to upgrade firmware for buffalo NAS drive
www.buffalo-technology.com/knowledgebase/users/kb.php?i...
Jan 24, 2013 | Buffalo Technology Buffalo ls-wxl/r1 4tb
Buffalo LS CH1.0TL not recognised by computer on IP or USB
If you are using a Windows OS to access the drive, you will be unable to read the filesystem on this drive, as Windows cannot read XFS file systems which Buffalo uses.
Try downloading/booting off of a Linux live cd (knoppix, ubuntu, etc), they are free for download from their respective websites, and should be able to read that XFS partition.
May 05, 2011 | BUFFALO hop 1TB LinkStation Live Network...
Laptop will not connect to wireless internet says it doesn't have a valid IP configuration. Have unplugged loads of times can get other wireless connections in the area but not mine.
In your laptop, try to put an IP Address, subnet mask, default gateway and preferred DNS server. (please see below)
example:
IP address: 192.168.1.13
Subnet mask: 255.255.255.0
Default Gateway: 192.168.1.1
DNS Server: 192.168.1.1
note: 192.168.1.1, is where your modem or your internet is connected (or the IP Address). This is the one that is provided/configured by your Internet Service Provider.
Jun 07, 2010 | Buffalo Technology Buffalo LinkStation...
Buffalo router setup
You have to change the DNS servers on your PC's internet connection.
Instead of using DHCP, type in the two IP addresses from your account at dydns.com.. Right click on your connection icon and choose, "properties".. In the panel presented, choose Internet Protocol (TCP/IP) the last item in the panel. Next click 'properties' and remove the dot from "obtain IP automatically". Next, type in your new DNS server IP's. The top panel is for you PC address which has to be between 192.168.1.2 and 192.168.1.224. It doesn't matter what IP you choose as long as it is not an address used by another device). The subnet mask will fill itself in. Default gateway is 192.168.1.1. In the bottom panel fill in your new IP's. That's it.
Apr 13, 2010 | Buffalo Technology AirStation Nfiniti...
I recently moved. When I did so, I received new high speed internet gateway hardware, ip addresses, etc. I connect my Linkstation Pro Duo (2.0TB) to my home network gateway, and I cannot see it on my...
You must install it again so it obtains the new addresses from your new hardware configuration. You'll need your installation CD and can find instructions/downloads on the Buffalo site (support).
http://www.buffalo-technology.com/en/
Apr 05, 2017 | Buffalo Technology Linkstation (hdh250lan)...
Cannot open web page through router
Try opening network connections TCP/IPv4 on your pc and add ip address manualy to be in the same number match the same as your router ie default gateway and preferred DNS Server eg 192.168.1.1 or 10.1.1.1 depending on what default the router is set on the ip address should be the same apart from the last no. eg 192.168.1.8 or 10.1.1.8 subnet mask will default to the right setting if you push the tab key after entering the ip address
Hope this helps
Feb 27, 2009 | Buffalo Technology WHR-G54S Wireless...
Can't connect
It will be one of two things or both - either your computer is notsetup for DHCP or your router is using the same IP address as your ISPor both.
To check ISP IP address connect your computer to your modem then: from start => run => CMD (hit enter after this)
a command window opens, type "ipconfig /all" without the quotes.
The line with "IP address" gives you your ISP IP addr.
Compare this with what you get from your router manual if they are the same then do the following:
Toconfigure your computer to use a DHCP IP address, go to the Controlpanel => network connections => Properties (right click on yourdefault connection) => double click Internet protocol (From generaltab) => (a new window pops up) from the general tab ensure that"obtain an IP address automatically" is selected.
To change the IP address of your router check your manual and do the following:
IP Addr => 10.10.1.1
Sub net mask => 255.255.0.0
Default gateway => IP address from your ISP
Make sure to the router is set to act as a DHCP server.
You should be up and running.
Aug 10, 2008 | Buffalo Technology WHR-G54S Wireless...
Computers & Internet Logo
284 people viewed this question
Top Black Box Computers & Internet Experts
Johnny Massengill
Johnny Massengill
1860ph
Level 1 Expert
Are you a Black Box Computer and Internet Expert? Answer questions, earn points and help others
