Question about BestOfferBuy Surveillance Ultra-Portable Design Clothes Hook Camera J018 Hidden Camera
I cant seem to get my coat hook J018 camera to work in a motion detection mode. On pressing the button twice on standby mode, I get three green flashes which means it has entered Motion Detection mode but after 5 minutes of continuous recording, the camers goes back to standby mode and after a further 5 minutes, it switches off.
I NEED A KEY CODE FOR THE BUILT IN RADIO IN A FORD FIGO 1.4 AMBIENTE 2012 MODEL
Try this, found it on another answer board.
Press and hold the Auto button. While holding the Auto button, push and hold the Track Up button. The “_ _ _ _” will disappear after about 5 sec. Enter KCAR using the remote control from a higher end CD Receiver or any Excelon CD Receiver. Enter "KCAR” with the remote controller as described below. “K”: Press TRACK UP key (>>|) after pressing 5 key twice. “C”: Press TRACK UP key (>>|) after pressing 2 key once. “A”: Press TRACK UP key (>>|) after pressing 2 key three times. “R”: Press TRACK UP key (>>|) after pressing 7 key twice. * If you commit a mistake in the code entry, the unit enters the code request mode again. Press the Track Advance button on the remote to enter the override code. The unit will enter the All Off or Standby mode if done properly. Video Unlock: Use a remote from a higher end CD Receiver or any Excelon CD Receiver. Some Video remotes will work, switch on remote must be set to AUD. Press 55222277 on the remote. There will be NO visual verification when entering the override code. Head units with a Up / Down Volume control buttons: Press and hold the Volume Up button. While holding the Volume Up button, push and hold the Disp button. The “_ _ _ _” will disappear after about 5 sec. Enter KCAR using the remote control from a higher end CD Receiver or any Excelon CD Receiver. Enter "KCAR” with the remote controller as described below. “K”: Press TRACK UP key (>>|) after pressing 5 key twice. “C”: Press TRACK UP key (>>|) after pressing 2 key once. “A”: Press TRACK UP key (>>|) after pressing 2 key three times. “R”: Press TRACK UP key (>>|) after pressing 7 key twice. * If you commit a mistake in the code entry, the unit enters the code request mode again. Press the Track Advance button on the remote to enter the override code. The unit will enter the All Off or Standby mode if done properly.
Read more: How can I get the key code for ford figo radio systems? - Radio system key code ford figo :: Ask Me Fast at http://www.askmefast.com/How_can_I_get_the_key_code_for_ford_figo_radio_systems-qna4609185.html#q2909005
Dec 09, 2015 | Ford Cars & Trucks
Samsung digimax d53 is in standby mode cant take pictures
Try this...remove the card and battery...press all the buttons...leave it alone for 20 minutes...insert the card and then the battery...turn it on.
Jan 03, 2010 | Samsung Digimax D53 Digital Camera
Swann pro 4000 dvr
Press the “Menu” button and use the Up or Downbutton until “Motion” is highlighted then press the “Enter” button. Use the Up or Down button to highlight the “OFF” next to “MOTION RECORD” and press the + or -button until “ON” is shown. Use theUp or Down button to Highlight the (MENU) then camera you wish to enable, then use the Left or Right button to highlight the “OFF” next to that camera and press the + and - keys to adjust the setting to “ON”. Use the Right key to highlight “AREA” next to the camera you wish to enable, and press the “Enter” button. Press the - button to turn on Motion Detection for the whole screen as shown by a green overlay, then do the same for your other active cameras.
Jan 14, 2009 | Swann Communications DVR4-Pro-Net...
Standby mode
There are three modes — standby mode, radio mode or CD mode. To enter CD mode, press the power button and then the CD button. To enter radio mode, press the power button and then the radio button. To enter standby mode, press the power button.
If you're in standby mode and press the time set button, the clock digits will blink. If they don't blink, you aren't in standby mode.
Dec 28, 2008 | TruTech Clock Radio
How do I get to standby mode?
Cannot find a device code for ATT Uverse DVR cable box
1. Release the volume controls and assign them to the AUX: A. Press and hold AT&T Button and OK Button at the same time, release both buttons. All the mode keys will flash twice indicating you're in programming mode.
B. Enter 955 on the remote keypad, the AT&T key will flash twice indicating a correct entry
C. Press the mode key you want to alway receive the volume commands - I assigned mine to the AUX mode button. The mode key chosen will flash three times indicating success. Volume commands will now be delivered to the AUX button regardless of the mode you are in. 2. Assign the AUX to the BOSE system: A. Make sure the Boze remote receiver is powered on (green light is on). B. Press and hold the AUX Button and OK Button at the same time, release both Buttons. All the mode keys will flash twice indicating you're in programming mode. C. Enter the 4 digit BOSE code on the keypad, I used BOSE Remote Code 4000.
D. The AUX Button will flash three times indicating correct entry.
Dec 28, 2008 | Bose Cinemate Digital Home Theater System...
Blackberry will not turn on
have you tried pressing the standby button on the very top left hand side of the device
Sep 15, 2008 | RIM BlackBerry Curve 8310 Smartphone
Green mode
Press the trash can button which is also a green dot and it should reset.
Dec 04, 2007 | Cameras
Date and time
1. With power off, press the MODE button to select the DATE mode.
2. Press the zoom out (three trees) button for more than two seconds to enter the date/time set mode.
3. Press the zoom out (three trees) button to select year, month, day, hour, or minute (selected number will flash).
4. Use the zoom in (one tree) button to advance the number.
5. Repeat steps 3. and 4. to set each value.
6. Press the zoom out (three trees) button until the colon (in the hours:minutes) is flashing. When the colon stops flashing, date and time setting is completed.
7. Press the MODE button and the power will switch off.
Nov 07, 2007 | Canon Sure Shot 80U 35mm Point and Shoot...
Can't Get Camera off Standby
may be the rec mode button is set at the anti grounding..usually at sony camera there are 3 switch mode the 5 sec mode, anti grounding and other and always use is the start and stop mode...this switch is located at the side of the camera...
Aug 26, 2007 | Sony Handycam DCR-TRV10 Mini DV Digital...
BestOfferBuy Surveillance Ultra-Portable Design Clothes Hook Camera J018 Hidden Camera Logo
243 people viewed this question
Top BestOfferBuy Video Cameras Experts
Are you a BestOfferBuy Video Camera Expert? Answer questions, earn points and help others
