Question about Garden
Trying to get my weedeater leaf blower to run changing the ignition module also does this run on mix fuel ? seems the model number is outdated no one has info
  • 2,113 Answers
Never use ethanol gasoline. Here is a list of real gas http://pure-gas.org/ Ethanol burns too hot and ruins warranties and the engine. Once you have your spark back i don't see why it wouldn't run unless something in the carburetor is not allowing the fuel to draw by a low pressure in the venturi. Nothing carburetor cleaner can't fix (or a small rebuild)
Posted on Oct 23, 2013
#1 Taper
  • 1040 Answers
SOURCE: How to you repalce a fuel line on a weedeater gb1/22v leaf blower
When replacing fuel line, make sure that you have the correct size lines. Depending on the size of your engine, the lines may vary in size. The primer bulb line will sometimes be larger in diameter than the fuel line to the carburetor. The primer bulb line will be the shorter of the two. When replacing the fuel line, make sure you have enough line to go from the bottom of the tank up to the carburetor. Give yourself a couple extra inches to work with. Cut one end at an angle, this makes it easier to feed down through the hole. Continue feeding the line until it comes out of the gas cap hole. Then cut the end of the line square again and attach the fuel filter that goes on the end of the line. Place the filter back in the tank, then adjust the line so that the fuel filter lays comfortably at the bottom of the tank. Then attach the other end of the line, (where you inserted it), to the carburetor, cutting off any extra line you may have.
Posted on May 23, 2009
  • 74 Answers
SOURCE: leaf blower won't start. I think it's the module
If you haven't done it already, install a new plug. It's possible you're being fooled by a faulty/fouled plug. A fouled plug may not spark visibly - like if there is dirt down in the recesses of plug around the electrode. It would be a good idea to check it with a new plug before spending $80 bucks for a new ignition module.
Posted on Aug 13, 2009
#1 Taper
  • 1040 Answers
SOURCE: weedeater leaf blower FL1500
Check the fuel lines for cracks/breaks. If they are o.k., then:
Youwill need to disassemble the carburetor and spray withcarb.cleaner.Make sure the small screen is free of debris. (Should beable to see daylight through it.)
Use a Den Tek Brush, (http://www.drugstore.com/products/prod.asp?pid=165357&catid=1152),to clean the small portals in carb. These portals can become blocked. Reassemble and start.
If the carb. parts are more than 4 years old, you may have to replace them.
If you need further assistance on:
1. Fuel line replacement or
2. Carburetor kit replacement
Just let me know.
Jim
Posted on Nov 27, 2009
SOURCE: How to get the spring & starter rope back
easiest is to take a slotted screwdriver, poke into the underside air intake and rotate the wheel a bit...usually the rope goes right back in...if not take the three screws out and release the rope.....while your there give it a few twists to loosen it up....you will do this soon enough when the rope breaks :)
GG
Posted on Sep 20, 2010
  • 10 Answers
SOURCE: Craftsman 200 mph model 358.794741 Leaf
You need to check if the piston was fired, or if the piston rings was stick.
Posted on Jan 11, 2011
Weedeater gbi 22 leaf blower will not start, how do I start it and what could be the cause?
Replace the spark plug, drain last years fuel and use fresh fuel mix.
Sounds like you may have a fouled plug. A speck of carbon or other debris can short the gap causing ZERO runtime.
Apr 02, 2015 | Weedeater Garden
My hand held blower wont spark plug and carb.replaced still wont start
If the plug is wet with fuel and it is firing then pull the muffler and for a struck ring. Struck and bad score cylinders will cause one not to start as you need at least 100 psi of compression to ignite the fuel mix.
These are okay then check the ignition of the flywheel to coil relationship as it could be a sheared flywheel key. Note most 2 cycles are now using cast in key as part of the flywheel itself.
Mar 14, 2015 | Weedeater Weed Eater Fb25 25cc 2 Stroke...
My weedeater worked one time and then it stop working not sure why it stoped i need to know how to fix it
well did you run straight gas or mixed fuel...
straight gas... throw it away and find another one
mixed... we need more info like how long it's sat ???
Aug 09, 2014 | Weedeater / Craftsman Igniton Module...
Should I use 2 stroke oil or synthetic 2 stroke oil
Synthetic oils claim to extend the shelf life of mixed fuel. If you are going to use the fuel within 30 days of mixing use regular 2 stroke oil.
May 22, 2014 | Weedeater Featherlite Blower 18 Cc 150 Mph...
Oil leaking from an older homelite weedeater
Oil leaking.? The only oil that would be in the machine would be the 2 stroke mixed in the fuel.. I dont understand where 'oil' would be leaking from. (more info please)
Also your question refers to an 'older homelite weedeater' yet its titled 'Problem with Stihl BR400 Backpack Leaf Blower' Which one is it.?
Mar 14, 2013 | Stihl BR400 Backpack Leaf Blower
I have a Weedeater fl 1500 le leaf blower that won't run wide open. It will start, but it has to remain at one half to three quarter choke to remain running. Changing the throttle opening seems to make no...
Simple solution your weed-eater has a Walbro carb buy a rebuild kit and rebuild the carb and it will run like new, don't touch any screw settings on the carb. You can purchase from your local repair center just give them the number on your carb and they will give you the correct kit. Go to smalleng.com they have a video on just this issue. Good Luck.. Don't forget thumbs and feedback.
Apr 02, 2011 | Weedeater 2 Speed Gas Blower FL1500LE ()
I have a Weedeater FL1500. I just changed the
Once it heats up either the spark plug or the ignition module is breaking causing them not to work. I would first check on the price of the ignition module, Then decide it is to expensive to repair and send it to the scrap man.
Good Day.
Oct 30, 2009 | Poulan Featherlite Gas Blower, with Low...
Ran great sat. but would not start sun. same gas changed plug air filter gas soaked with it off still not running tried putting gas in spark plug hole still not running this is a craftmans 2 cycle leaf...
Were you running a fuel mixture of 40:1(3.2 oz of 2 cycle oil to 1 gal of gas), that you mixed up before you started using it again. The unit may have had to much use on Saturday and may be burned up. Try to have a compression test done on the engine, needs to be at least 100 psi to run. If that proves to be good then you can start looking at Fresh gas mixture, a new spark plug, Carburetor rebuild or an ignition module.
HTH
Good Day.
Oct 26, 2009 | Garden
Garden Logo
29 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
