Question about Memorex AM/FM ARMBAND RADIO WITH HEADPHONES MR4402BK
Instructions to sent arm band radio - Memorex AM/FM ARMBAND RADIO WITH HEADPHONES MR4402BK
Can the Baofeng work the 6 meter Ham Band
Normally baofeng transreceivers are working on 2 meter band(144...mhz)and uhf band.You can check it with instruction manual if it covers the 50 mhz range?.I also have baofeng which can receive 65 mhz to 108 mhz(fm band)but I cant transmit.
Sep 17, 2017 | Radio Communications
How so i pick station on my Radio Shack police scanner?
I have never used a scanner of that type but I have seen them in use and know the principle of operation.
If you are certain the radio is working and have checked with the instruction manual that you are operating it the correct way with any squelch control turned down and the volume turned up there should be a loud hissing from the speaker indicating the radio is ready to receive as soon as it is either tuned to the specific frequency of a station by direct entry or by scanning one or more bands of frequencies.
If there is no hissing noise it is possible the audio output is faulty or the aerial is not connected or the radio is otherwise faulty.
If the hissing noise is present and powerful and still nothing is being received it is possible there is nothing to receive or a more powerful aerial is needed.
It is worth noting many scanners available in the past tended to scan bands of frequencies in the upper and lower vhf bands where the aircraft, marine and emergency services radios operated. Since those days many of those services have moved their communications into the UHF bands leaving the vhf bands relatively empty.
Oct 04, 2015 | Radio Shack Radio Communications
How to turn on radio
Just press the larger On / Off button, lower left side of clock, select AM / FM band (make sure you install either the am band wire antenatal and the FM antenna (comes with clock) use the rocker arm switches to search out stations and adjust volume by turning knob on the right side of radio, that's it... (0:
Mar 31, 2013 | RCA RP3721 Clock Radio
Radio code
Is there a question or definition.
Radio code - police band coded language, CB user's jargon, coded messages sent in cryptic radio traffic or error codes found in some car electronics.
Dec 04, 2009 | 1999 Daewoo Nubira
Innovage AM/FM/Weather Radio Problem
I believe it is just a China import; I would give up and just get one from Radio Shack instead - I know how you would like to get it right, but I would send a decent letter to Bass Pro Shops along with a copy of your receipt from Radio Shack and ask them to refund you - it might work.
Oct 25, 2007 | Innovage (1504368) AM/FM/Weather Radio
Memorex AM/FM ARMBAND RADIO WITH HEADPHONES MR4402BK Logo
219 people viewed this question
Top Memorex Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Memorex Audio Player and Recorder Expert? Answer questions, earn points and help others
