Question about Panasonic Lumix DMC-FZ5 Digital Camera
Turns offand on continually
The problem is the camera turns itself off and on automatically until battery is exhausted do you think it is worth fixing or know what it is thanks?
  • Official Brand Answer
  • 350 Answers
If you're sure the battery is fully charged and the camera continues to do this, then it most likely needs service. Here is a link you can use where you can learn about you're available options. Hope this helps.
http://shop.panasonic.com/ecom/onlineRepair/login
Posted on Oct 22, 2013
COLEMAN INVERTER PMP1200 JUST BEEPS WHEN TURNED ON
It is most likely the low voltage alarm. Suggest connecting when the car is running with no load (110 volts not connected). If the alarm continues turn the unit off and on to reset.
Hope this helps?
Inverter Protection Features
• Short Circuit Protection. The inverter will automatically shut down until short is removed.
• Low Voltage Alarm. An alarm will sound when the voltage from the battery discharges to 10.5 +/- 0.5 volts DC. This is an indication that the battery needs to be recharged.
• Over Voltage Protection. The RED LED Indicator Light will illuminate and the inverter will automatically turn itself off when the input exceeds 16.5 +/- 1 volt DC.
• Under Voltage Protection. The RED LED Indicator Light will illuminate and the inverter will automatically turn itself off when the input is less than 10.0 +/- 0.5 volts DC.
• Overload Protection. The RED LED Indicator Light will illuminate and the inverter will automatically turn itself off when the continuous draw of the equipment being operated exceeds 1200 watts or the surge draw of the equipment exceeds 2400 watts.
• Thermal Protection. The RED LED Indicator Light will illuminate and the inverter will automatically turn itself off when the circuit temperature exceeds 150° F
Sep 13, 2016 | Electronics - Others
Video turns off durning video
Make sure your battery is fully charged. Read all the stuff I wrote about batteries last weeks. Lots of problems occur wham batteries are not ok anymore.
For taking a video, the camera needs extra power, because it is recording and the screen is on all the time. Thaking stills for a camera is like a walk. Taking Video is like running. So it is exhausted sooner.
Nov 26, 2013 | Canon EOS 600D Rebel T3i Digital Camera
I have a Samsung PL100 digital camera. I dropped it while at beach, it was switched off. When I went to switch it on the lens came out but then it made a buzzing sound and switched itself off. The lens is...
I had the same exact issue.... try putting it on the charger, even if you think it's fully charged... If the light is red, leave it on the charger until it turns green, and then remove the battery for a second and then put it back in the camera before turning it back on..... try turning it on. If it still won't close, put it back on the charger. If the charger is automatically indicating a red light, that means you have exhausted your battery and will nee a new one... they cost about 5-11 dollars on amazon...... hope that helps...
Jul 20, 2012 | Cameras
Camera turns off when you use telephoto lens camera turns off.
I may be able to help with your Kodak EasyShare Z740 that turns itself off.
Try these steps to fix your camera.
I hope that helps.
_____________________________________________
Kodak EasyShare Z740 Turns Off Fix
Kodak EasyShare Z740 Manual Download
Apr 21, 2010 | Kodak EasyShare Z740 Digital Camera
Exact same problem
After getting a response from someone on here, I was able to determine that the problem could not be fixed without sending it in to Nikon. I contacted Nikon and they confirmed this. I have shipped it to them for repair, depending on the cost.
Aug 18, 2009 | Nikon COOLPIX L12 Digital Camera
Camera showing battery exhausted with new batteries
There are three battery type settings in the set up menu: Alkaline, COOLPiX(NiMH) and Lithium. Might be worth looking at. To be continued.
Jan 29, 2008 | Nikon Coolpix 5600 Digital Camera
Battery Problem
I just had this problem today myself, and looked everywhere online for a solution. I changed the batteries (to Panasonic), and it didn't help. But i tried different batteries (Energizers) and the camera started working again.
Aug 31, 2007 | Nikon Coolpix 3200 Digital Camera
Samsung Digimax A7
Samsung customer support may help but If I understand you correctly you may have killed the camera
May 29, 2007 | Samsung Digimax A7 Digital Camera
Beep
The Polaroid Fun! Digital 320 camera is programmed to shut off automatically after a few minutes if it is not being used. This helps to conserve battery power. When the camera shuts itself off, it will make a continual beeping sound. To use the camera after it has shut off, simply push the shutter button or self-timer button to take a picture. If you are not going to use your camera, turn the power switch to OFF. The camera will also beep in rapid sequence after you press the self-timer button. The camera will continue to beep in faster sequence until a picture is taken (approximately 10 seconds). A final long beep signals that a picture has been taken. NOTE: It is normal for the camera to beep while downloading photos to a computer.
Sep 14, 2005 | Polaroid PhotoMax Fun 320 Digital Camera
Panasonic Lumix DMC-FZ5 Digital Camera Logo
Top Panasonic Cameras Experts
Computer Links
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
