Question about Refrigerators
Kenmore freezer upright model 253
I have a Kenmore upright freezer - model 253-26442100. Can you tell me the size in cu and the mfg year?
    Top Expert:
  • Refrigerators Master
  • 35,654 Answers
Refer this inquiry to Sears.
Posted on Oct 22, 2013
aasc
  • 1606 Answers
SOURCE: Upright freezer not working
Tap on the thermostat , not hard , but not softly either , and see if the freezer starts . If so , replace the thermostat ( the piece behind the temp setting knob )
Posted on Dec 10, 2009
SOURCE: Can you tell me what size the Kenmore model # 3639762811 is?
korenb, I too was looking for that answer. I found it at the following link
http://www.applianceblog.com/mainforums/sears-kenmore-brand-forum/11093-kenmore-refrigerator-size.html
Regards, pete
Posted on Mar 15, 2010
  • 760 Answers
SOURCE: I Kenmore elite upright freezer
This could be caused by any number of things. Could be a grounded compressor. If you remove all leads from compressor and test from terminal to body of compressor with an ohm meter you should get no reading on your meter. ( or a very high meg ohm reading) If the neutral wire from the cord ( usually white) is in any way touching a grounded component then the GFCI will trip. If you have a bad defrost heater going to ground it could trip the GFCI. I assume this unit has ran on this GFCI before? You could buy a GFCI tester, that will tell you if the GFCI is tripping at the desired mA level. A GFCI should trip between 4-6mA. Have you plugged this freezer into a non GFCI receptacle to see if the unit functions?
Posted on Jun 30, 2010
richroth
  • 9472 Answers
SOURCE: I have a full size upright kenmore freezer Model # 253 9203281 S1061 55531 06-91.
You need to replace the defrost thermostat on the unit. You will need to remove the shelves and then the back wall to gain access to it. Here is the part to order.
Posted on Nov 08, 2012
flatech
  • 111 Answers
SOURCE: kenmore model 106.5692600...anyone tell me the
Try this site, will need the serial number as well.
Hope it helps.
http://www.appliance411.com/service/date-code.php
Posted on Oct 08, 2013
What should the tempurture control on a 13.7 cu. ft. Kenmore upright , model 253 214 21101 freezer be set at when 3/4 to full be set at?
you will have to play with the adjustment until you get into its range. the load has alot to do with the box temp. I suggest getting a thermometer and try setting the temp to @20-25 degrees and see if that helps
Nov 26, 2009 | Kenmore 13.7 cu. ft. / 388 liter Upright...
Kenmore upright freezer alarm sounds constantly
replace the battery in the grill or the hi-voltage control under the unit in the back
Jul 02, 2009 | Kenmore 20.3 cu. ft. / 575 liter Upright...
Kenmore Frost Free Comm. Model #253-23425100 - will not stay cold
Two things:
Either the thermostat has inadvertently been turned up, (too warm) or the gas in the compressor tank is low. If it isn't #1, call a repair tech to replentish the has in your compressor. If that isn't it he will tell you what he thinks it is. Good luck!
Mar 15, 2009 | Kenmore Freezer 20.3 cu. ft. Frost Free...
FREEZER ALARM WILL NOT SHUT OFF
Use a freezer thermometer and tell me the actual temperature. Or at least store some ice cream and see if it stays brick hard. Unless I have some idea of the actual temp I can't tell if defective freezer or alarm
May 11, 2008 | Kenmore 16.7 cu. ft. / 473 liter Upright...
Freezer runs constantly
not necessarily, is it maintaining temp? all food staying frozen? especially ice creams if stored in there. most newer freezers displace the heat generated while cooling the food through copper lines running through sides of unit, helps to cut down on air temp differences between the inside (0 degrees) and outside temp to prevent moisture and possible condensation causing premature rusting of unit
Mar 02, 2008 | Kenmore 14.1 cu. ft. / 399 liter Upright...
Refrigerators Logo
249 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
