Question about Honda 1993 Prelude Workshop / Service / Repair Manual 1089 Pages Cd Pdf
Where I can fix the knock sensor in d15b engine honda civic 1997 ?
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 96 Answers
Knock sensor is located below intake manifold, you would have to probably jack-up the car securely and removed a few fastener. I believe size 17 mm wrench or a socket would do the job, replaced it with a new one.
Posted on Oct 24, 2013
Knock sensor location on a 2001 Honda Civic DX
images for Knock sensor location on a 2001 Honda ...
Honda knock sensor p0325 - YouTube
? 6:41
https://www.youtube.com/watch?v=yacSiSJ5Vc0
Feb 17, 2014 - Uploaded by Cody the Car Guy
do you know where is the knock sensor on a 2005 Honda accord coupe .... 2001-2005 Honda Civic Cam ...
Civic knock sensor - YouTube
? 1:28
https://www.youtube.com/watch?v=D1jk5OxuOB0
Jan 18, 2015 - Uploaded by chriizt1an
96-00 civic ex. ... Civic knock sensor ... 2001-2005 Honda CivicCam Position Sensor TDC Sensor & Valve ...
Honda Civic Knock Sensors - AutoZone
Jan 10, 2016 | Honda Civic Cars & Trucks
Help
so some one has done a engine swap if there are left over plugs then the engine light will be on v-tec engines have solenoids that operate the camshaft the 1500 non v-tec does not .computer and wiring are different.
Jun 02, 2014 | 1997 Honda Civic
Location of knock sensor for honda civic
Mrs PETERSON the knock sensor located on the side of the engine block to the inner side under the inlet manifold and close to the oil filter and oil switch.
Apr 22, 2014 | 2000 Honda Civic
Location of knock sensor on a 98 honda civic v -tech 4 cylinder
It is on the lower left side of the engine (side towards firewall - see picture).
Knock sensor failures are pretty rare, why are you looking for it?
Jun 15, 2012 | 1998 Honda Civic
Trying to get my 1997 honda civic smogged. Replaced the knock sensor about 800 miles ago. No check engine light is on. When I try to smog it i have three things not ready - the catalyst, the evap, and...
As a rule it takes about 50 miles for the computer to finish it's readiness tests. Some take longer so I would drive it about 75 miles and then check.
Jul 25, 2011 | 1997 Honda Civic
I have a d15b engine on honda ek3. what is error code 14, 15, 17, 3 and 7. thanks
14-idle air control valve, 15-ignition output signal, 17-vehicle speed sensor,
3-map sensor, 7-throttle position sensor.
Jan 28, 2011 | 1997 Honda Civic
I need help looking for all the sensors on a d16 honda civic
What sensor are you try to look for?
here is the list of all the sensors for 97 honda civic EX
1.Countershaft Speed sensor
Driven Pulley speed sensor
Engine Coolant Temperature Sensor
Front wheel sensor
Fuel Tank Pressure Sensor
Intake Air Temperature Sensor
Knock Sensor
Mainshaft speed sensor
Manifold Absolute pressure (Map) sensor
Primary Heated Oxygen sensor
Rear Wheel sensor
Secondary Gear shaft speed sensor
Throttle Position sensor
Vehicle speed sensor.
I hope this can help you, please put something on the ratting. good luck.
Mar 18, 2010 | 1997 Honda Civic
1992 honda civic D15B is loud in block
it could be a piston broke or an oil ring
Apr 14, 2009 | 1992 Honda Civic
1.6 sohc vtec...d15b... is it posable
If the block says d15b, it is a 1.5 liter, just as powerful as the 1.6 if you bump the timing up a little bit, but these engines are notorious oil burners and the standard transmissions always eat up their input shaft bearing and growl.
Mar 19, 2009 | 1992 Honda Civic
95 civic wont start
An engine needs 3 things to run: Fuel, compression, ignition.
Maybe the timing belt went out. Take off the dist cap and see if the rotor turns as you crank the engine.
Next run a compression test on all the cylinders.
Dec 09, 2008 | 1997 Honda Civic
Honda 1993 Prelude Workshop / Service / Repair Manual 1089 Pages Cd Pdf Logo
133 people viewed this question
Top Honda Air Tools & Compressors Experts
John Trevino
Renee Knafel-Bullock
Are you a Honda Air Tool and Compressor Expert? Answer questions, earn points and help others
