Question about Sony KDS-R50XBR1 50" HDTV
Have blue screen from HDMI inputs other inputs OK
  • 20 Answers
The first thing to check is the cable, have you tried it on any other HDMI device (if you have one)? The cables are durable but not indestructible and even brand new it could be a bad unit.
On a less likely consideration: Since HDMI is a digital format (as opposed to RCA, S-video and VGA which are all analog) it requires certain compatibility. While ALMOST all HDMI device (DVD players, computers, game systems) use a pretty universal language for HDMI there are occasions where that they are not compatible, this also applies to the cable itself since it does minor translation in the process of transmitting the signal. Again, this would be a rare occurrence.
The third option is that the HDMI ports on either the device sending to the TV or on the TV itself are not working.
Posted on Oct 22, 2013
Jvc projector blue screen
unplug it let it set hit power button plug back in might work for you
Aug 14, 2016 | JVC -HD DILA FRONT PROJECTOR THX CER -...
Sound on but no pitcher
Sound on means audio section is ok. No picture is video board problem. Pl check input cables. Or give Hdmi cable input. Disconnect all inputs switch on u should get plain raster that is only dots on screen, or blue back screen, if nothing contact authorised dealer,
Feb 08, 2015 | Panasonic TH-L32C20X 32 inch Multi-System...
Wd65738 blue screen
blue screen means no video signal, if the source is on hdmi ensure the cable is rca or in simple audio video jacks which u will have to connect in the dvi input of the tv reason is hdmi means high definition interface and transmits by hdcp like the data of an internet meaning its digital platform which the tv can only process thru the dvi inputs or component y,p,b
Jul 17, 2013 | Televison & Video
Sreen blue, no signal floating across screen
Hello
Check all the signal cables at the backside of your Vizio for firmness. If there is any loose or bad cable connection, especialy with HDMI; will poise this problem. Check the input selection also. If improper input selection is done, there will be no signal logo will fly around.If you have selected TV instead of HDMI, when HDMI is connected and you want to see the programme, is an example of improper signal selection. Check these. OK.
May 12, 2011 | Vizio VO32L 32 in. LCD TV
How to connect Blu ray disc player with my Bose 321 system. I have 1080 p samsung LCD TV. How to get the best.
hi,
do the following.
1. connect ur blue rays hdmi out to ur tvs hdmi input.
2. connct blue rays out to any one of the coaxial(aux) input of bose.
3. connect ur tvs optical audio output to optical audio input of bose
4. connect monitor out of ur bose to any one of ur av in of ur tv. connect component video to better quality .
4 . in the blue rays audio setup select audio output priority as optical/coaxial
5 . in bose set aux as digital input.
to see blue ray select hdmi of ur tv, sellect in bose in which the blue rays coaxial is connected(aux) insert disk in blue ray an watch
to see dvd in bose select tvs corresponding input, select bose to dvd . insert dvd and watch
to whach tv program set tv to corresponding mode. set bose to optical audio input mode.
ok
Dec 15, 2010 | Televison & Video
Just purchased Yamaha RX-V465 and need to assign hdmi out puts and can't seem to figure it out. I have connected the cables according to a diagram. My items are Pioneer Elite Flat Screen and a Samsung Blue...
Had to download the manual for this one since i didn't work with that particular model yet, but should be able to help anyway. Ok so on the back of the Yamaha unit you have a total of 5 HDMI plugs. The first on the left is the receiver's output which is supposed to go to the Pioneer flat screen in the Input HDMI plug. The 4 other HDMI plugs on the yamaha receiver are the 4 inputs, so plug in the Blue Ray reader into the second HDMI plug from the left which reads (BD/DVD) HDMI1. Now everything is plugged in the right way, so if you already did plug it all up like that, you were OK so far. All that is left now is to first of all put the Pioneer flat screen on the right input (You can do that with the remote of the TV, or if i'm not mistaken, there is an input selector on the back of your Pioneer flat screen TV). When that is done you just need to put the receiver to the right input also, to do so, either with the remote again, or on the front of the yamaha receiver unit. In both case, the button you need is the Input button, press it untill the receiver says HDMI 1 on the LCD display. And now you're done, all you need to do is to turn on the Blue Ray, put a movie in and enjoy.:) If it does not work, either the receiver or the flat screen are defective and should be returned for waranty.
Jul 07, 2009 | Yamaha Audio Players & Recorders
Connect to PC via hdmi-hdmi cabel (3m)& hdmi to DVI converter
Please provide the driver link to the ATI HDMI applications. its a known problem from ATI
Dec 24, 2008 | Toshiba 32WL55E 32 in. LCD Television
Blue tint to picture
cheak projecter mode your in under hdmi mode blue cool settings on hi ? eash input setup is differt use warm colers not cool 1 2 3 so on u know what i mean sum sterio have hard time with hdmi out to dvi might wann use coumpuont out from reciver to 15 pin vga sum projecter in 720 p mode have gard time 1080i so on u relly need dvi out from setrio to dvi more less for monister cable best use compunt cable projecter only 16 millon colers anyays ok not 529 billon like samsung plmasa would be were u would wann use hdmi to get all those colers but coumpunt is more then worthy wiyth projecters output ok
Jan 23, 2008 | Onkyo TX-SR674S 7.1 Channel Up-Converting...
HDMI connection problem
On your TV set remote are you selecting the proper input; for example when you have different devices connected to the back of your tv set, dvd player, vcr, cable box etc; you have to tell the tv which device you want to use by selecting the right one on your tv remove input selection. Hope this was any help.
Sep 08, 2007 | Mitsubishi WD-52725 52". Rear Projection...
Sony KDS-R50XBR1 50" HDTV Logo
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
