Gp215 error code E675
Can,t print
GP215 Canon Photocopier says close front door when its closed!
THIS PROBLEM DUE TO YOUR COMPOSITE POWER SUPPLY PROBLEM
Nov 28, 2013 | Office Equipment & Supplies
How do I clear error E100 on my Canon GP215 photocopier? The paper keeps on jamming continuously.
Odds are you will need to replace the fixing unit. The error code deal with the fixing unit not heating up to the correct temp.
May 22, 2012 | Canon Office Equipment & Supplies
Sourcing motor brushes for E675 jazzy motor?
Hi Lane. What happened to your old brushes?
Be carefull fitting different brushes to your machine. If you do, make sure that the brushes you use are also for a 24 volt DC motor. Different voltage motors have different types of material used for the brushes, they can damsge your commutator if you use the wrong ones.
If you find some that are slightly to big, it is Ok to carefully file them down to size.
Contact a local service agent, they often have used brushes that still have a bit of life in them.
I often use brushes from one brand in other brands of machine, and have used brushes as well, but we are probably too far away in New Zealand.
Good luck. Neil.
May 14, 2010 | Pride Jazzy 1103 Ultra Standard Power...
I have a canon GP215 and it give error code e101. what am i supposed to do
The error code indicates that there is a fuser failure. You will need to have it replaced.
You need to contact canon to get one for you .
Hope this helps.
Dec 16, 2009 | Canon GP-200 All-In-One Printer
Cannot print in booklet with the canon gp215
go to printers and faxes, and right click on your printer select propeties. if it is a canon there will be a tab at the top called device settings in there is a button that says get device status click it, it should say got device status then click apply. this will configure the print driver with all available options your copier has installed. after that the booklet option should be in the finishing tab of the driver when u print.
Sep 07, 2009 | Canon Office Equipment & Supplies
Canon gp215 error E064
Hi, Well this error code means there is some problem in Main Power supply or Main PCB.Check it to fix this problem!
Thanks! mannu_rakesh
Aug 26, 2009 | Office Equipment & Supplies
BD error has occurred.
• The laser unit has a fault.
• The BD PCB has a fault.
The BD signal is not generated during image formation
because this error is related to LASER UNIT & BD UNIT we suggese try to repairing with help of a technician, don't self.
Thank's for using FIXYA
Jun 21, 2009 | Canon Office Equipment & Supplies
27 people viewed this question
k24674
jasbo
jasbo
