Question about Vehicle Parts & Accessories
Car starts and idles well. Requires massive revs to pull away or car Judders through the clutch pedal to a halt. On gear change it Judders also. Any advice before I get down to the work would be great. Thankyou
    New Friend:
  • 32 Answers
Sounds like a flywheel issue hence the judder Dont drive it may cause more damage Gearbox needs to be taken off for investigation Or driveshaft issue
Posted on Oct 22, 2013
2 Suggested Answers
dancandoit
  • 436 Answers
SOURCE: '98 Audi A4, Viper 5501. Car auto-starts and runs
You will be best to connect the real tach wire. You will need to programme the alarm to recognise the speed of the engine, this way it will know where the idle position is.
Posted on Nov 20, 2009
REPLACED CLUTCH ON ZR 550 CLUTCH ENGAGES , BUT WHEN FULLY RELEASED BIKE JUDDERS THEN STALLS OUT . TRY TO ADJUST & GEARS WONT ENGAGE .
So if you raise the revs to say about 4000 rpm and let the clutch out does it stall or judder or both will it engage at all and pull away ?
Mar 07, 2015 | Motorcycles
Revs high when i change gear
Is it possible the clutch pedal is interfering with the throttle? Start the engine in neutral and allow it to idle. Press only the clutch pedal down and see if this increase the engine speed. If it does speed up the engine and slows back down when you release the clutch then somehow this operation is where your fault lies. If it doesn't alter the idle speed, then rev your engine and release the throttle to see if it returns to idle immediately. If it is slow to return to idle then your throttle cable could be sticking. This means when you change gear lifting off the throttle has little effect and depressing the clutch to change gear causes the engine to race as the throttle is still partially open.
Aug 23, 2014 | 2005 Ford Fiesta 1.3
Engine revs but no acceleration
Clutch plate and pressure plate seem to be too weak to pull the car. Or one of the CV joints is detached from the gear box. To test the clutch plate, park the car on flat surface. Pull the hand brake up, start the car, depress the foot brake pedal, depress the clutch pedal, put the car in 1st gear, press the gas pedal and leave the clutch pedal at once, while keeping the brake pedal depressed.
Follow one of the two following statements:
1. Engine does not shut down and remain start. (Clutch plate, pressure plate and clutch bearing defective - Replace all as a set)
2. Engine shuts down. (Clutch system is OK and does not require any repair).
May 22, 2013 | Honda Civic Cars & Trucks
Vw polo 1997 999cc often idles eratically
First- lets change engine coolant sensor/ECT/ and you will be very surprised.Black head with four pins.Be very carefull when change it because there is pressure into coolant system.First-open slowly the cap of engine coolant tank.Then tighten again to safe coolant.Unplug the sensor,remove the pin and pull out the sensor.If the "O"ring/old one/ is still inside-take it out.
Apr 21, 2010 | 1997 Volkswagen Golf
2004 Hyundai Elantra GT (manual)Loosing speed/power while driving
sounds like the clutch is worn out and requires replacement.
Jan 19, 2010 | 2004 Hyundai Elantra
Ford focus slow at take off
clutch slipping change the clutch
Jun 10, 2009 | 2002 Ford SVT Focus
I was my daughter her first driving lesson when she gave it too many revs and lifted the clutch too quick - resuly massive wheel spins, judders & stalls. The gears are now all up the shoot- I cannot...
sure sound like internal damage . will have to come out and come apart to find the extent of the damage. sorry i bet you didnt want to hear that.
Aug 24, 2008 | 2000 Renault 181
My fuxd mx3 N reg
join uk-mx3.com forum and explain your problem as in depth you can, we'll help you there ;)
Aug 12, 2008 | 1992 Mazda MX-3
2001 daewoo lanos
is the car is idling o.k between 750-850 rpm, before you pull away? if it isn't then check your plugs injectors idle control. if it is but the car move's slowly away and you are using high revs it could be a slipping clutch or if automatic transmission worn bands or torq converter. also check for breaks binding.
Aug 05, 2008 | 2002 Daewoo Lanos
Vehicle Parts & Accessories Logo
29 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
