Question about Fujitsu ScanSnap Manager
Scansnap. There is a problem with the installation environment
How to load scansnap s510 on new computer with windows 7?
Hi irene
scansnap s510 drivers (win 7/8) can be found at
driverupdate us . (32/64 bit)
It will take 2 mins from you to install... after updating, go to word and try to print something
I hope I have helped you...
enjoy
Mar 19, 2012 | Fujitsu ScanSnap S510
My ScanSnap S510M stopped working. There is an error code "0xffffdcf7" . I tried rebooting but it still does not work.
I had a similar problem. My problem may be related to installing a second scanner (Canon MG8100). Reinstalling the ScanSnap driver solved my problem.
Jul 20, 2011 | Fujitsu ScanSnap S510
I installed ScanSnap on Windows 7 under the administrator account and it works successfully. The problem is with the other non-administrator account. The ScanSnap icon was not installed on the...
OK; after giving up on lousy tech support I got it working after doing the following (not sure if all required, but this is what I did)
1. Gave admin rights to C:\Program Files (x86)\PFU
2. Updated to latest ScanSnap Manager V5.0 L21
3, Copied C:\Users\<admin acct>\AppData\Roaming\PFU directory to C:\Users\All Users
Good luck...
Mar 21, 2010 | Fujitsu ScanSnap Manager
Have just installed S1500 software and finished the installation but get an error message "Failed to initialize drinver module (0 X 80210019)". What does this mean and how do I proceed? ****
Try the following step :
Pre-Installation Steps
  • Log onto PC with an account that has Administrative Privileges.
  • Disconnect ScanSnap scanner, if connected.
  • Close any open applications.
  • Install ScanSnap Manager, ScanSnap & CardMinder software from the ScanSnap Setup CD-ROM.
    • Upon reboot of the installation you may receive an error message stating, “Failed to initialize driver module.” Please disregard and continue.
ScanSnap fi-5110EOX Vista Update Pack Installation Steps
  1. Download the fi-5110EOX Update Packs (Vista 32-bit Support)
    1. ScanSnap Manager V3.0 – ssv3020up.exe
    2. CardMinder V2.0L10-V2.0L11 – cm2012.exe
  2. Install all two update packs that were downloaded in Step #1.
    1. Reboot is NOT required after each update pack.
  3. Reboot the PC after all three update packs installed completely.
  4. Connect ScanSnap Scanner via USB, open lid, let Windows Vista install the new hardware.
Mar 07, 2010 | Fujitsu ScanSnap Manager
ScanSnap Manager - Error!! You do not have a write authority for the installation folder.\nMake the selected folder writable.
Normally this error will only come up when you have already tried installing the Scansnap Manager.
Go to C:\Windows\SSDriver. Right click the folder and select properties, select the security tab, then make sure "Users" has full control.
Repeat these steps on the PFU folder in Program Files.
Put in the Scansnap disk and navigate to the Tools folder. Run the SSCleaner tool and delete all of the Scansnap components.
If Scansnap Manager is not listed in the Cleaner tool, Delete the contents of the SSDriver and PFU folders manually.
Restart the computer and reinstall the components.
May 14, 2009 | Fujitsu ScanSnap Manager
Scansnap manager won't properly install on windows xp...
Problem solved. Ignore the "Windows XP approval" message & continue with the fix suggested in the troubleshooting section of the manual.
Feb 18, 2009 | Fujitsu ScanSnap S510
Error while attempting to install ScanSnap Manager on Win XP Pro
Bypass installation wizard and just run the setup.exe file for ScanSnap Manager. Installation wizard is bugged.
Jan 09, 2009 | Fujitsu ScanSnap Manager
Driver scansnap
There should not be any problem installing that sofware on that OS and version. My guess is you have a botched (corrupted) install. Try uninstalling if you can otherwise let me know and we'll "clean out the registry." Good luck!
Jul 22, 2008 | Fujitsu ScanSnap Manager
Computers & Internet Logo
358 people viewed this question
Top Fujitsu Computers & Internet Experts
Computer Links
Tony
Are you a Fujitsu Computer and Internet Expert? Answer questions, earn points and help others
