Question about Bose 3 2 1 GSX System
No sound My system works fine, that is the DVD part, display and all, but there is no sound, nothing. turn on / off, disconnect cables etc etc.
  • Sara Owens Mar 13, 2009
    There's a beautiful picture, but no sound when playing DVD of any sort, CD has no audio either.  Tried unplugging cables and power to reset system and still - nothing.
Unplug it then plug it back in, it will reset something and then will work fine, probably caused by a power surge or power outage. Hope this helps someone, God Bless.
Posted on Oct 02, 2007
SOURCE:
I have a Pioneer VSX D412 S receiver with my Pioneer surround sound system The system SUDDENLY STOPPED RECEIVING SOUND SIGNAL FROM MY HD TV
  1. Turn the TV and receiver off and back on. This is called "power cycling" the devices.
  2. Check the menu settings to make certain the TV is still sending a sound signal out to the receiver.
  3. Disconnect the cable, blow both ends out, reconnect, and see if the cable was partially disconnected or has dust or lint interfering with the connections.
  4. Change the cable for another cable that you know to be working.
  5. Use a different source for the TV: DVD, Cable, different channel, etc.
  6. Connect the receiver to another TV.
Dec 16, 2015 | Pioneer Audio Players & Recorders
Dell demension 4600 wont turn on
An Amber blinking power button indicates a low voltage problem. This can be caused by a defective power supply or a defective motherboard. Since you replaced the power supply, my guess is that the motherboard has a problem.
Just to make sure that nothing else is causing the problem, remove any PCI cards like modem, video card, sound card, etc... Remove the memory modules and disconnect cables to CD/DVD drives. Look at the USB ports to see if any are damaged.
Aug 07, 2012 | Dell Dimension 4600 PC Desktop
Yamaha 5.1 says Check SP Cable and shuts down - has been fine.
It has nothing to do with the input you choose. A speaker wire is shorted. Disconnect each one in turn and try it. The last one disconnected before it stops failing is the one.
Mar 22, 2009 | Yamaha HTR-6030 Receiver
Surround Sound works with DVD, but not with TV, cable, etc.
dont know if it helps,but try connecting audio cables to the dvd from tv. worked for me !
Jan 05, 2009 | Sony DAVHDX265 System
No sound from hdmi cable
PS3 is The amazing device by sony but it has some common problems like sound but no video problem etc.... Good news is that these all problems can be repaired with the help of DIY Guides, one such guide available at PS3 Repair Blog
Nov 24, 2008 | Sony Playstation 3 (PS3) Console
Surround on my system
Have you tried what I said and changed the settings in the DVD?
Also, is it a built in DVD player / TV combo, or a separate unit? You can try doing a hard reset..Unplug the TV from the mains, disconnect all cables from tv and wait for 1 hour. Then press the power button on TV and plug in the mains. Same if your DVD player is stand alone.
Try that and let me know..
May 10, 2008 | Koss KS3102 System
WD-52725
if you get a blue screen than your lamp is working fine. blue screen is considered "video mute" it display that blue if the tv thinks there is no video. try to reset the tv by pressing - menu 123 then reset to system defaults.
Feb 21, 2008 | Mitsubishi WD-52725 52". Rear Projection...
Crashing sound on Protron 32 TV
no sound, everything was working fine the night before. woke up the next morning, and turned the tv on, and there was no sound at all. nothing from the TV, DVD, and nothing from the Computer. Please help. [email protected].
Dec 26, 2007 | Protron PLTV-32 Television
Bose 3 2 1 GSX System Logo
267 people viewed this question
Top Bose Audio Players & Recorders Experts
Ben Armstrong
Ekse
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
