Question about Sony VAIO Computers & Internet
Removing split screen
My screen has a kind of fuzzy and thin dotted green line about 2cm down from the top of screen running all the way across. Above this line it is fine. Below this line it continually flickers and I can't get it to stop! It was very all of a sudden and I'd like it to stop!
  • Sony Master
  • 1,183 Answers
Thank you for posting your query on fixya.
The screen could exhibit such issue , if the screen has gone bad or the video card that give signals to the screen. To isolate the problem connect the laptop to an external monitor / TV if the output on the same is fine , the video card is fine and the screen would need a replacement.
Proton
Posted on Oct 22, 2013
jimbo6
  • 89 Answers
SOURCE: Red line across top half of screen
Inverter board is bad or video cable loose either behind LCD panel or near video adapter.
Posted on Jan 10, 2008
  • 163 Answers
Uh-Oh.. Sounds like the BGA RAM in the video circuit. (These units are Intel based and Core 2 duo if posted correct).. We can repair if you need help and its under warranty and sorry its not a home remedy situation..
ikenfixit.com
Posted on Jan 17, 2008
Geekman
  • 32281 Answers
SOURCE: Display has gone bad with fine vertical pink lines
Connect an external monitor to your laptop, if you get a clear image on this monitor the the video card in the laptop is OK.
The fault could be a defective inverter that supplies high voltage to the CCFL lamp or a faulty CCFL lamp. Most likely a faulty CCFL lamp.
Defective CCFL backlight may has the following symptom:
  • Screen flashs on red/pink and off.
  • Picture stays on in red and slowly be come normal.
  • Picture flickering with dim display.
  • Picture flickering on and off.
All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) as reached the end of the life and all you need to do is replacing the CCFL lamp
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out www.lcdparts.net for parts, repair service and DIY info.
Posted on Mar 06, 2009
Baytel
  • 19 Answers
SOURCE: How to remove a flickering thin green line that
It sounds like you have a bad screen or video cable.
Posted on Nov 17, 2009
Sunnyrepairs
  • 808 Answers
SOURCE: Lenovo Thinkpad SL400 - Screen
Its may b the problem of ur vga use reginout regcleaner to fix ur problems
Posted on Aug 11, 2010
Sinotec PHD-50HU31. First, thin line running vertically down the center of the screen. Now, only a 2cm wide horisontal line appears at the top of the screen. Rest of screen is black.
If you wish to get more details visit the site linked here. Line faults to many popular brand sets are given with illustrations. You can get an idea about the fault. http://electronicshelponline.blogspot.com/
Feb 10, 2017 | Televison & Video
Split screen, kind of inverted w/white wavy lines
It is a calibration problem, let me see if I can find some schematics for your tv.
Jul 19, 2008 | Panasonic CT-32SL14 32" TV
Dell inspiron laptop grey dotted line across
You could try removing the display device in device manager then rebooting. At boot up windows will reinstall the drivers.
Check for new display drivers at Dell's support site.
Mar 13, 2014 | Dell Inspiron E1505 Notebook
Very thin black vertical line moving across tv screen left to right on tv
The screen voltage to the picture tube is more than normal. Adjust it by the help of screen pot-meter integrated with Line Output Transformer. Visit the site named 'Electro-help' for more details. Check this link and select the site named above. View it in 'Flip card' option, which can be selected from the drop down box menu at the left top corner or the display window. It will make search easy.
Aug 05, 2012 | Panasonic CT-20SL14 20" TV
I have just collected a second hand HP 1600 printer and there is a 2cm green vertical line down the left side of the page and a 3mm line down the centre and 2 thin lines down the right side, help!
Dots, Lines and smudges on the printouts are due to deteriorating cartridges and cleaning the green drum of the cartridge may help temporarily. Take out the cartridge and gently clean the roller/ green drum with a dry, soft, lint-free cloth wiping off the toner dots marks/ lines. (corresponding to the location where you are having a green line on the paper)
Also, make sure that the visible inside of the printer and the Black belt are clean and there is no spilled toner inside, which sometimes results in dots.
Moreover, streaks (thicker lines) and dots etc indicate faulty PCR Roller which is located behind the green drum inside the cartridge. Replace the Cartridge or get the PCR Roller changed by a professional.
Hope it helps! Good Luck! Thanks for using Fixya!
CreativeTECH
Jun 16, 2011 | HP LaserJet 1600 Printer
Red static in black background ~ thin line running down center
Robjrpena,
Did you find a solution to your "red dot" problem? I'm having the same issue :(
Thanks John
Jun 17, 2009 | Hitachi 50HDA39 50 in. Plasma HDTV
Red and green fuzzy waves across the screen
my screen just became distorted (red picturer to the upper right & green picture to the bottem left ? can you help me ? wuzuphippie55@yahoo
Sep 08, 2008 | Philips Magnavox 9P6034C 60" Rear...
Thin line across computer screen
This might be a mediaplayer issue. Google on EHtray.exe and you will find a microsoft page with a number of filenames related to these kind of problems. Check by pressing CNRL-ALT-DEL and check if you see any of the filenames on the processes tab. Than stop the file and see if the black line disappears.
Jul 05, 2008 | HP w17e Monitor
Thomson TV Stuck on letterbox
Thank You Matt, This is not an enhanced set. So your friend couldn`t have changed the aspect ratio.
That unfortunately leaves you with a problem in the vertical circuits of the chassis .There is a capacitor going bad. I recommend you take it to your repair shop. First ask for an estimate before you decide you want to repair it. There are no expensive parts involved. Mostly service and labor charges.
Al
May 11, 2008 | Televison & Video
Red Dots
You can get rid of the red dots by adjusting the V-scan voltage down, it's on the panel sticker inside the unit, you can find the test point on the DC to DC pcb, and the adjustment pot is on the same board, lower it as you watch the screen and only lower it enough to rid the screen of the dots
May 27, 2007 | Samsung HP-R5072 50 in. Plasma HDTV
Computers & Internet Logo
56 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
