Question about Whirlpool Dishwashers
Diplomat/whirlpool ADP 8322. The circulation pump gets very noisy, rattles and splutters when the water temperature gets high. Water spray becomes intermittent. The motor normally runs quiet - no bearing noise or impeller noise. If the heater is disconnected the noise stops. Can you help?
hotuna
  • 288 Answers
SOURCE: Low or no spray pressure
You sound like you diagnosed it pretty good, so I think you can change the impeller. The biggest problem is making sure everything is lined up so it wont leak after its re-installed. I've never had much luck removing the old impeller without breaking it into pieces. just be careful not to mess up the shaft. If its an older machine, some Whirlpool/Kenmore can have the whole thing changed in one part. Its a little more $$ but it has the motor and all. And its easier and faster!! Also, your pressure problem may be related to the motor.
Posted on Mar 15, 2008
SOURCE: diplomat dishwasher adp 8322
i had same problem and have found that under the lower basket the connecting bar to the spray arm had become detached this can be reattached by inserting the two nozzles back into position and pushing down youll see what i mean ! however i have found i now have to do this after every wash ,am currently onto diplomat to rectify this completely , hope this is any use.
Posted on Nov 28, 2008
  • 457 Answers
SOURCE: Blanco Dishwaser very noisy pump motor
the only thing you can do is take it to the place where they repair motors. like where they fix windings ect . im in ny so you have to check your area for one in your neighborhood. let me know if this washelpful to you
Posted on Feb 27, 2010
  • 1416 Answers
SOURCE: Diplomat ADP 8322 - 11 Flashes. Will not go beyond
There's never a good time for the washer to stop working correctly. If a washing machine's agitator isn't working properly, your clothes won't come clean.
The back-and-forth movement of the agitator is a main function in the cleaning process of your laundry.
If your agitator isn't working, it could be the agitator itself or broken splines in the assembly beneath the agitator. Either one is a relatively easy and inexpensive repair that you should be able to do yourself.
Instructions and material needed :Socket wrench,Rope,Broom,Replacement parts
  1. Inspect the agitator for breaks. If the agitator is broken or cracked, you'll need to replace it. A broken agitator won't operate correctly, if at all. If the agitator looks fine but isn't moving, you'll need to inspect the plastic splines in the agitator assembly located underneath the agitator.
  2. Remove the agitator from the washing machine by first removing the fabric softener dispenser cap on top of it. This cap should either pull or screw off. It it's difficult to remove, you might have to pry it off.
  3. Unscrew the bolt beneath the softener cap with a socket wrench. Once you've removed the screw, try lifting the agitator out of the washer. If it doesn't easily lift out, loop a rope underneath one side of the agitator and over a broom handle. Continue looping the rope under the other side of the agitator and back over the broom. Using caution not to hit yourself in the head, pull up on the broom until the agitator comes loose.
  4. Replace the broken agitator with a new one. Snap the new one in place and secure the bolt underneath the fabric softener cap. Place the cap back on the agitator and you're ready to start washing.
    Check the plastic splines in the assembly directly underneath the agitator, if the agitator itself isn't broken. If the plastic splines are broken or worn down, this will keep the agitator from properly moving. In fact, it might not move at all. Replace the spline assembly with a new one and reassemble the agitator by reversing your steps to remove it.
Good luck and thanks for using fixya.
Posted on Dec 24, 2010
ercupa190
  • 12223 Answers
SOURCE: circulation pump not turning water jet sprays
see the diagram attached.God bless you1a811c50-59c9-42dd-a9c4-0ff484032968.gif
Posted on Apr 05, 2013
Dishwasher buzzes when filling and draining
see this causes and use the common sense.God bless you
If your dishwasher seems noisy, check these: Water-inlet valve Motor Heater fan Pump Water-inlet valve An aging water-inlet valve can sometimes fail slowly, rather than all at once. It can shudder on and off rapidly, causing the incoming water lines to shake, rumble, and rattle--sometimes violently. If yours is doing this, replace the inlet valve. Motor If it's the motor that's noisy, either of these may be the "culprit:" As motor bearings wear out, they can become quite loud when the motor runs. They wear out quickly if they frequently get wet, because the water washes away the motor bearing grease. Bearings can get wet if the spin seal is defective. Then there will also be water leaking onto the floor beneath the dishwasher. Replace the seal if it leaks (read about the main tub seal in the "It leaks" section, later). If, from beneath the dishwasher, you can see a round, plastic disc that's mounted to the top of the motor (a "slinger"), it may have broken free of the motor shaft. If so, it could be rattling around the shaft while the motor is running. If that's the problem, you need to replace the motor. Heater fan If the heater fan bearings are rusted or worn, they may squeal, or scrape loudly during the drying cycle. If this is the problem, replace the fan motor. Alternatively, the fan blade may be loose. If so, you need to replace it. Pump Small fruit pits, toothpicks, and fragments of glass sometimes get stuck in the pump. When this happens, open the pump and remove the debris. The pump is usually mounted directly to the motor, then attached to the bottom of the dishwasher. To get to the pump, you usually need to remove the lower rack, the spray arms, and the spray arm support from the inside of your dishwasher. A dishwasher pump isn't obvious. Look for an impeller--a round, plastic fan blade-type device that spins around and pushes the water toward the drain. When you can see the drain impeller, you should be able to see the clogging debris
Sep 19, 2012 | Whirlpool Dishwashers
Dishwasher; Diplomat 8322. Set it to wash on any temperature but after a minute it defaults to rinse and bleeps constantly
Apparently there is a sensor above the normal water level where it drains. The water level rises above the sensor if the filter is full of gunge and the water cannot drain properly. The sensor is activated and stops the cycle. You have to remove the filter mesh, clean it, drain out the excess water (I did this with a turkey baster!) and replace the filter. Then everything works again!
Dec 17, 2009 | Dishwashers
The dishwasher makes a horribly loud sound when running. I think it has to do with the lower "spinner arm". When I push it manually, it wobbles and makes noise. So I am guessing that spinning at higher...
It's noisy If your dishwasher seems noisy, check these: Water-inlet valve Motor Heater fan Pump Water-inlet valve An aging water-inlet valve can sometimes fail slowly, rather than all at once. It can shudder on and off rapidly, causing the incoming water lines to shake, rumble, and rattle--sometimes violently. If yours is doing this, replace the inlet valve. Motor If it's the motor that's noisy, either of these may be the "culprit:" As motor bearings wear out, they can become quite loud when the motor runs. They wear out quickly if they frequently get wet, because the water washes away the motor bearing grease. Bearings can get wet if the spin seal is defective. Then there will also be water leaking onto the floor beneath the dishwasher. Replace the seal if it leaks (read about the main tub seal in the "It leaks" section, later). If, from beneath the dishwasher, you can see a round, plastic disc that's mounted to the top of the motor (a "slinger"), it may have broken free of the motor shaft. If so, it could be rattling around the shaft while the motor is running. If that's the problem, you need to replace the motor. Heater fan If the heater fan bearings are rusted or worn, they may squeal, or scrape loudly during the drying cycle. If this is the problem, replace the fan motor. Alternatively, the fan blade may be loose. If so, you need to replace it. Pump Small fruit pits, toothpicks, and fragments of glass sometimes get stuck in the pump. When this happens, open the pump and remove the debris. The pump is usually mounted directly to the motor, then attached to the bottom of the dishwasher. To get to the pump, you usually need to remove the lower rack, the spray arms, and the spray arm support from the inside of your dishwasher. A dishwasher pump isn't obvious. Look for an impeller--a round, plastic fan blade-type device that spins around and pushes the water toward the drain. When you can see the drain impeller, you should be able to see the clogging debris.
Nov 19, 2009 | Whirlpool Dishwashers
I have a Diplomat Fully integrated dishwasher model ADP 8242 when put on any program it fills and seems to be washing then stops after 5 minutes and the dispenser door has not opened. There is a lot of...
Check the small drain pump. Possibly its asking the pump do drain to allow for fresh water, but because low level is not detected it shuts down. The dispenser draw normall opens when the hot wash cycle starts.When you think its washing,briefly open door and see if eater is spraying out of the nozzels.If no water visible, check the main wash motor for sticking
Sep 24, 2009 | Dishwashers
How to reset the programmer on dishwasher
Disconnect power for longer than 45 seconds.
Sep 17, 2009 | Dishwashers
NOISY DISHWASHER WHIRLPOOL GU3600
Water-inlet valve
Motor
Heater fan
Pump
  • As motor bearings wear out, they can become quite loud when the motor runs. They wear out quickly if they frequently get wet, because the water washes away the motor bearing grease. Bearings can get wet if the spin seal is defective. Then there will also be water leaking onto the floor beneath the dishwasher. Replace the seal if it leaks (read about the main tub seal in the "It leaks" section, later).
  • If, from beneath the dishwasher, you can see a round, plastic disc that's mounted to the top of the motor (a "slinger"), it may have broken free of the motor shaft. If so, it could be rattling around the shaft while the motor is running. If that's the problem, you need to replace the motor.
Jul 24, 2009 | Whirlpool GU3600XTS Dishwasher
Dishwasher not drying properly; water in the cups/plates
  1. Check the water temperature. Should be 125 to 140 F.
  2. Check pump re-circulation., Listen, see if it sounds like it is spraying the water around with enough pressure.
  3. Check water level when the fill cycle has completed. Should be just under the heating element. If not, possibly need to replace the water inlet valve.
  4. Check the spray arm and pump cover for splits or leaks.
  5. Check to make sure dishwasher is draining after each cycle. There should only be a little water in the bottom of the tub.
  6. Make sure the dishes are loaded properly, or dishwasher is not overloaded.
  7. Possibly try a different detergent. Some liquid-gels will bubble and a pump cannot pump bubbles.
Dec 06, 2008 | Whirlpool Gold 24 in. Built-In Dishwasher...
Diplomat adp 8520 dishwasher no hot water
two things to check
check continuity thru heater
remove outer door panel and check for faults in wiring loom
get back to me is these are both ok
Nov 14, 2008 | Dishwashers
Noisy dishwasher
Your motor is makinig all the noise.
Jul 15, 2008 | Whirlpool 24 in. GU1500XT - Multiple Color...
Diplomat dishwasher adp 8322
Mar 09, 2008 | Dishwashers
Dishwashers Logo
18 people viewed this question
Top Whirlpool Dishwashers Experts
Mike
Owen Barnes
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
