Brother typewriter Model GX-100, how to set up the right and left margin?
  • 46 Answers
Normally, you must set the carrier or scale where you want it set on the left then press the left margin set button. Then move the carrier to the right to where you want the right margin set and then press the right margin set button. You may have to use margin release to bypass the previously set margins. Hopw this helps.
Posted on Oct 24, 2013
JayBlair
  • 328 Answers
SOURCE: Margin Release for Brother GX-6750 Typewriter
Typewriters have alimit to how far to the right or left that you can set margins. Once you use the alt & 6 key to bypass the current margin setting then move to the new setting then hold the alt key and touch the 7 key to keep it in the new position.
Posted on Aug 18, 2008
Geno111
  • 183 Answers
SOURCE: cant find margin release
Generally, the way the margins work is, wherever the printhead is positioned, when you hit the right or left margin set, is where the margin is set. To reset the margin you must move the printhead to where you want the margin set, and hit the appropriate mar. set button. to move the printhead past where the margin is set, you must hit the "mar rel" button, and then backspace or space to where you want he printhead positioned. On machines without a "mar rel" button, you just use the "backspace" or "spacebar" to move past the margin. You can't release the margins permenantly, you can only move them, or move past them using the above mentioned processes.
Posted on Oct 24, 2008
Geno111
  • 183 Answers
SOURCE: Setting Margins
move the carrier to where you want the mar.set then hit the R MAR or L MAR key.
to move the carrier beyond the margins hit the MAR REL key
Posted on Nov 25, 2008
  • 125 Answers
SOURCE: Left and right margins of typewriter on Brother ML 500 Memory
Hi:
First find the margin release key and press it once. Then use the spacebar to move the carrier forward and reset the right margin. Or again use the margin release key by pressing it once and then press and hold the backspace key to move through where the left margin was and reset it at the point where you want it.
Andrew
Posted on Mar 19, 2009
SOURCE: i bought a --brother AX-400 electronic typewriter
Move the carrier to the desired position for the new left or right margin using "backspace" or "space"
To move beyond the position of a current margin, first position the carrier on the margin and press "alt +m rel"
When the carrier is on the desired position, press "alt + l mar" (if you are setting the left margin), or "alt + r mar" (if you are setting the right margin.)
The minimim distance between the left and right margins is two inches
Posted on Dec 31, 2009
How to set right/left margins on brother AX110 electronic typewriter?
space or backspace to the place where you want the left margin. You may have to use the margin release key to go past the present margin. When you get the carriage to where you want the margin, depress the left margin set key. Some have L mar and R mar keys, also some use the code key and another key to set.
Apr 14, 2014 | Brother GX-6750 Typewriter
How to type in Landscape form of paper .
Roll the paper in sideways. Use the Margin Release key to allow you to backspace to the left of your left margin, then touch the Left Margin key to set the margin at the new location. Go to the right margin and use the Margin Release key again to allow you to space past the right margin, then touch the Right Margin key to set the new margin there.
Type.
Aug 18, 2011 | Brother GX-6750 Typewriter
How do I type to the end
To reset the margins you need to first release the margins. Once you have released the margins you will be able to set the left and right hand margins.
Thanks,
Pat
May 12, 2010 | Brother GX-6750 Typewriter
What keys do I use the change the left and right margins?
You set the margins by putting the printhead where you want the margin set, and holding down the CODE key, push the key under where L MAR or R MAR is printed, (above the top keys on the keyboard) depending on whether you want to set the right or left margin.
If you want to set the left margin to the left of where it's set, hold down the CODE key and push the key under MAR REL. Then using the Backspace (or spacebar, if you backspace too far) position the printhead where you want the mar. set and holding down the CODE key, hit the key under L MAR.
Setting the right margin works the same way.
Oct 27, 2008 | Brother GX-6750 Typewriter
How to change the Margins
Yurn on, carrige return to left margin. To move to the left, depress the MR or margin release key, back space to where you want margin. There usually a key that says code or mode, up on the top cover if it has not been cleaned off the 3 key is the margin left key and the 4 key is the margin right key. depress the code key and 3 key will set the left margin. Hope this helps...
Jun 10, 2008 | Brother GX-6750 Typewriter
Help with Typewriter
hold down the code key and press the margin release, to set margin, just hold code release margin, space over to where you want it and then press Margin set, left or right.
Jun 05, 2007 | Brother GX-6750 Typewriter
Mar 09, 2007 | Brother GX-6750 Typewriter
65 people viewed this question
jasbo
jasbo
