great site but it did not address the problem I want to know how you can tape a program from the tv onto the camcorder. I did not see anything in the manual that address this. Maybe you just cant do it but I thought I had done it before (when I had the Manual ) thanks great site but it did not address the problem I want to know how you can tape a program from the tv onto the camcorder. I did not see anything in the manual that address this. Maybe you just cant do it but I thought I had done it before (when I had the Manual ) thanks
You can't post conmments that contain an email address.
You need an 8mm player or the camera that recorded the tapes. Connect the video and audio from the 8mm player/camera to a VHS recorder. Put the 8mm on play and the VHS on record.
Hi.Here is a site that will help you:- Free Sharp DVRW360H DVD VCR Combo User Manual ...tv.manualsonline.com/manuals/mfg/sharp/dvrw360h.htmlDownload a free copy of the Sharp DVRW360H DVD VCR Combo User Manual UserManual.
Hello Ron, Well that is like you say an old camera, mind you 8mm is still far the best and safest way to store your valued films as it has kept the data on those tapes longer than any DVD ever did, remember unlike we thought 10 years ago a DVD only has around 8 to 10 years life span, we are finding CD & DVD productions that are over 8 years old just wont play any longer. Kodak put a report on the net 7 years ago that they found even some quite costly DVD recorded media had gone blank and refused to play after a very short time in storage. I think you ought to look around Ebay, find a nice HI8 digital camera, put your loved tapes in that, plug the new Firewire cable into the camera, and your PC and download your treasured items to another media like DVD. Keep your 8mm tapes in a draw safe though because they will out-live all DVD recordings I can honestly say that. David
connect the red/white/yellow from the input on the dvd to the red/white/yellow on the vcr sellect av1 on the dvd recorder and you should be right and as a bit of help here is the manuel to your dvd recorder
it is written in pdf so if it does not open you will have to download adobe reader its free go to adobe.com
using the magnovox remote, reprogram the vcr's channels. set it up to use cable not air. when the vcr was unlugged it lost it's channel memory. don't buy new cables, you're getting a picture and sound so that means your rca cables are ok.
Please connect video out and audio out of your TV to video in and audio in of your vcr respectively.Switch on the TV and the VCR.Put the VCR on camera or AV mode.Press the record key on VCR.The VCR will record the programme being shown on your TV.Thanks.
There are no such adapters that would allow 8mm, Hi8 and Mini DV tapes to be played in a VHS VCR. Only the old VHS-C tapes can fit and play in an adapter.
There are several reasons why 8mm (or Hi8 and miniDV tapes) cannot be physically played in a VHS VCR:
1. 8mm (Hi8, miniDV) is a different format with different technical characteristics than VHS. These formats were never developed with the intention to be mechanically compatible with current VHS technology.
2. 8mm/Hi8 tapes are 8mm wide (miniDV is 6mm wide), while VHS tape is 1/2" wide, making it impossible for a VHS video head to read the taped information correctly.
3. 8mm/Hi8/miniDV tapes are recorded and played at different speeds than VHS, so even if the tapes could physically fit into a standard VHS VCR, the VCR still couldn't play back the tapes at their correct speeds.
4. 8mm/Hi8/minDV audio is recorded differently than VHS. 8mm/Hi8 audio is recorded in AFM HiFi mode, while miniDV audio is recording in 12-Bit or 16-Bit PCM digital audio format. So, even if the video could be played back in a VHS VCR, the audio could not be read properly.
5. 8mm/Hi8 video is of higher resolution than VHS and is recorded in a different bandwidth length (miniDV video is recorded digitally), so once again, a standard VCR still could not read the information correctly, even if the tape could fit into a VCR.
