Question about Car Audio & Video
Hard clutch over night & clutch engages while depressed
    New Friend:
  • 7 Answers
Hi brad, cant understand your question well....
when you depress the clutch fully, the gear are supposed to engage and disengage. if this happens in partial depression you might need to adjust the clutch free play or check clutch plate wear
Posted on Oct 22, 2013
The clutchpedal seems to work but does not engage and the fluid level reamains full
It is still a bit unclear what is going on here, when you say it seems to work, do you mean the clutch disengages? Can you change gears OK with the engine running and the clutch depressed?
When you say it does not engage the plate, do you mean the vehicle does not move? To change gears it must DISengage the plate, not the other way round.
Sorry if I seem picky, but I'm trying to get it all straight. If you can change gears OK with the engine running and the clutch depressed, but the vehicle does not move when you let the clutch pedal up, then the clutch is possibly worn out and needs replacing.
If the opposite and you cannot get it into gear with the clutch depressed, then the clutch throwout fork has possibly broken, which is not uncommon. Alternatively but less likely is that there is so much air in the clutch hydraulic line that it has become ineffective.
Apr 06, 2016 | 1990 Ford F150
How do you release the clutch on a juki that has dis-engaged, and I can't budge the wheel in the opposite direction with the button depressed?
Depress the clutch button and turn the handwheel backwards, it is really hard to turn so you need to use both hands and lots of muscle power. It will be a bit easier if you remove the belt.
Oct 03, 2014 | Sewing Machines
My clutch won't engage 1997 Honda civic
Clutch plate and pressure plate seem to be too weak to pull the car. To test the clutch plate, park the car on flat surface. Pull the hand brake up, start the car, depress the foot brake pedal, depress the clutch pedal, put the car in 1st gear, press the gas pedal and leave the clutch pedal at once, while keeping the brake pedal depressed.
Follow one of the two following statements:
1. Engine does not shut down and remain start. (Clutch plate, pressure plate and clutch bearing defective - Replace all as a set)
2. Engine shuts down. (Clutch system is OK and does not require any repair).
Apr 06, 2013 | 1997 Honda Civic
How can depressing the clutch engage the starter ?
It sounds like current is feeding into the start wire off the switch. Trace the wire from the clutch switch to the ignition switch connector. Does the wire look good? Examine closely the connector and see if you see a burnt terminal, or some broken plastic in the connector, some way for the start wire to pick up current. If you see nothing wrong, IDK, probably will need a shop to chase the wiring down and find it. I don't know if a bad starter relay (stuck on) could do that, likely not if it only happens when you depress clutch and have clutch switch on.
Good luck.
Dec 31, 2012 | 1991 Chevrolet C1500
How do can you roll start a 86 samurai
Engage two wheel drive. Switch on the ignition. Pull out the choke? Engage second gear and release the hand brake. Depress the clutch pedal and get the vehicle up to about 6-8 mph. Release the clutch and the engine should be turned by the rotation of the wheels - and hopefully start. Once the engine has caught, depress the clutch and keep the engine running in the normal manner.
May 17, 2011 | 1986 Suzuki Samurai
Hard to shift into first gear
Tighten clutch cable until the car would start to move when the clutch peddle is 50% depressed, Before you do that, with the clutch fully depressed and in 2nd gear, start the car and slowly let off the clutch. You may find that the clutch has to be released virtually all the way before the car moves. It should be at about that 50% I spoke about
Dec 07, 2009 | 1999 Mercury Cougar
Engine sputters when clutch/brake engaged; revs when brake only engaged
check under dash where pedals are as there may be wiring there that the pedals are touching and shorting out
Jun 02, 2009 | 1998 Jeep Wrangler
Clutch won't engage
There is a problem with the pressure plate spring or possibly the throwout bearing is bound up,you should be able to pull the rubber boot from around the clutch fork and have someone depress the pedal,you should be able to see if it's a problem with the bearing.Unfortunatly the trans is probably going to have to caome off.
May 25, 2009 | 1991 Toyota Pickup
Clutch pedal suddenly goes to the floor, no longer [dis]engaging the clutch
I found that having a wood stick on the clutch pedal down to the floor all night (the other end of the stick held by the seat. oh yeah !!! ) would help to ease shifting for the first hour the next morning, then it would come back stiff and hard to engage in gear.
Aug 07, 2008 | 2007 Mazda B4000
Car Audio & Video Logo
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
