Question about Acer TravelMate 610TXVi PC Notebook
Floppy drive problem
When i work the floppy drive makes a trrrr sound. ther is no other problem in working but i scare for this sound might not create a problem to my laptop
    President:
  • 2,961 Answers
What may be happening is that the system is looking for a floppy drive as well as other possible places when you save your work. The last time you saved a document you must have used your floppy drive and it's looking there by default, i wouldnt worry too much, to confirm this you can put a floppy in the drive and the noise will go away because there is a floppy in the drive.
Posted on Sep 28, 2007
  • andrew pester
    andrew pester Oct 01, 2007
    So what was the noise down to then?
How to Create a Startup Floppy Disk?
Insert a floppy disk into your computer's floppy drive. Open My
Computer, and then click the floppy disk drive to select it. On the
File menu, point to the name of the floppy drive, and then click
Format. Under Format options, click Create an MS-DOS startup
disk .
Oct 19, 2016 | Computers & Internet
Bootable USB
rreadow To Boot From A USB Flash For starters this is still a new science and many people have had good luck with at least one of these methods and others have not. Note that flash drives are often also called thumb drives, keychain drives, pendrives, etc. A FEW THINGS YOU NEED TO CONSIDER IN ADVANCE. 1. The PC has to support booting from a USB flash drive. There may be anywhere from 1-3 items to change in the BIOS to make this possible assuming your BIOS supports it. Some bios's may refer to your flash drive as a USB floppy or USB zip.
2. The USB flash drive must support booting from it in general.
3. The flash drive must contain the boot/system files.
4. The flash drive must have bootsector area. This is done with special utilities.
5. References to "A:" drive lines in the autoexec.bat and/or config.sys files you copy to the drive after you make it bootable may result in errors.
6. You "may" have to format your floppy disk first in WinXP before you create a bootdisk as XP may "not" like working later on with a disk formatted otherwise.
7. Included below is a bootable ISO of DOS 7.1 which may be used with some of these methods if you do not have a 1.44 drive.
zivider.gifzivider.gifzivider.gif METHODS Method 1 - Make your flash drive bootable using Bart's mkbt util:
http://www.nu2.nu/mkbt/ | Alt: mkbt20.zip Put a bootable floppy disk in your A: drive or create one using Windows.
Download mkbt20.zip and unpack to to new temp folder you create.
Go to the temp folder.
Extract the bootsector from the bootable floppy disk. eg Open a DOS Window and go to the directory where you extracted MKBT. Type: mkbt -c a: bootsect.bin The boot sectors from the bootable floppy disk have just been saved to a file in the temp folder you created. Format the flash drive in FAT or FAT16. Copy the bootsector to the flash drive. Open a DOS Window and go to the folder where you extracted MKBT. Type: mkbt -x bootsect.bin Z: "Z" represents the flash drive drive Letter. So if your flash drive has another drive letter, then change the "Z" accordingly. Now you can [grin] "should" be able to copy the utils you need to the pen drive.
zivider.gifzivider.gifzivider.gif Method 2 - Try these 2 HP/Compaq USB Flash Drive Utilities. They work with many other brands of flash drives as well. HP USB Disk Storage Format Tool Version 2.0.6
HP Drive Key Boot Utility Version 7.41
Download
zivider.gifzivider.gifzivider.gif Method 3 - Third Party Links http://ucsu.colorado.edu/~shaher/Bootable_USB.html Recall I did say it's a new science.
http://www.microsoft.com/whdc/device/storage/usb-boot.mspx
zivider.gifzivider.gifzivider.gif Method 4 - A Bootdisk.Com Visitor Suggested Here is my another method for creating dos bootable USB sticks using windows format. 1. From Win98 DOS-Prompt type "SYS {USBDriveLetter}:" or "FORMAT {USBDriveLetter} /U /S". If from WinXp then from start->run command.com execute format.exe copied from win95 or win98. OR 2. Simply by enabling copy system files in windows explorer format window. By default it is disabled for non-floppy drives. To enable it use windows enabler program from http://www.angelfire.com/falcon/speedload/Enabler.htm an whoila it works.
zivider.gifzivider.gifzivider.gif Method 5 - Another Bootdisk.Com Fan Suggested - Thanks Keith First if you don't have a physical floppy drive (and don't want one) you can use the [free] "virtual floppy driver" from here: http://chitchat.at.infoseek.co.jp/vmware/vfd.html With that you get an A: drive and can manipulate a floppy image as if you were using real floppy. You can then use that image to make a bootable CD. It's not that user friendly but once you get how it works it does work perfectly. Even cooler you can use a "raw write" utility like dd for windows to write the floppy image directly to your USB thumb drive. Even without that famous HP utility to do the magic this will make your USB thumb drive bootable. The 'dd' ported to Windows is located here: http://www.chrysocome.net/dd Another trick you can use with that dd utility involves MS VritualPC (which is free). You can create a virtual machine/virtual hard drive, set it up the way you want then use dd to "raw write" the virtual hard drive image to the thumb drive; this will make the thumb drive identical to the image, including bootable (again, no HP utilities required). Of course, your thumb drive will effectively have the capacity the size if the image in question (your 1GB flash drive will effectively be 1.44 Megs).
Sep 13, 2008 | Computers & Internet
When I plug my usb floppy drive in, it makes a loud buzzing sounds and does not read disk
dirty head or damaged head alignment. try removing from device manager and reinitialize.. if still not working, it is time to buy another one.
Jan 06, 2014 | Mitsumi Lot Of 3, 3.5 Inch 1.44mb Floppy...
My WD 1TB my passport external hdd doesnt show up in my devices but the light is on and it makes a weird whirring sound, can this be fixed
You can download a program from WD called Data lifeguard Diagnostic for windows there is a floppy and a windows program. I made a bootable floppy and started my computer with the floppy and typed windlg.exe and followed the instructions...http://wdc.custhelp.com/app/answers/detail/a_id/1329/~/how-to-create-a-data-lifeguard-diagnostics-bootable-cd
Jan 01, 2013 | Computers & Internet
My toshiba 7220cte will not load a fresh win 2ooo os , fdisked and formatted drive. tried loading from cd and floppy disk. at very end of install. unit shuts down , and states i have an invalid disk in...
If you have an invalid disk in the unit, is the floppy disk left in the disk drive.
However, to completely erase windows, fdisk and format does not work.
Download delpart.exe and use this utility. Be careful though. When delparting a laptop, make sure not to delete the small partitions, but only the ones that are NTFS.
However, if the laptop has a SATA hard drive, this method will not work unless you create a bootup script with delpart.exe to run automatically. Then it will work.
If you have any issue, blog it on the internet about the exact procedure to create an iso bootable disk to load delpart.exe.
Aug 09, 2009 | Toshiba Portege 7220CTe (PP722U-7D90Q) PC...
R4000
yes u can run a usb from the boot menu
u will have to configure the bios.........
u may have to make some changes to ur external hard disk
u will have to use some ones comp to do these aas urs is not working...................
i got this from the net and this should work
Oct 18, 2008 | Compaq Presario R3000 Notebook
Imation SD-USB-M2 SuperDisk USB(MAC)
Sounds like a dead (or jammed) motor -- the one that spins the media. It's relatively easy to open the case, disconnect the USB-to-IDE interface adapter from the 40-pin IDE connector, and go onto eBay to find any "internal" or "external" LS-120 device, and swap it in, to replace the "not-spinning" device.
Jan 26, 2008 | Imation (01946) External Floppy Drive
No disk message or your disk is not formatted you want to format it , Yes Or No
Sound incompatibility issue, probably your device will only work with Win98
Nov 21, 2007 | Sony (MPF920-Z/131) Internal Floppy Drive
Acer TravelMate 610TXVi PC Notebook Logo
44 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
