Question about Fishman Sa220 Sa-220 Solo Performance Pa System
How to change fuse on the S A 220 solo amp - Fishman Sa220 Sa-220 Solo Performance Pa System
I changed my Whirlpoool Duet heat element and it doesn't turn red (doesn't get hot). Continuity is good. Changed fuse to a new one.... need help...
Make sure you have 220 volts across the element when energized. Also check the amp draw...should read about 12 Amps.
Feb 23, 2015 | Dryers
My 2001 focus zts dashboard lites and night running lites(park,rear,licence plate lites) do not work. Manual describes the fuses as left DRL right DRL. Can these be the right fuses? If so they look good.
Hi ,this is shenzhenelectronic.
Our website is http:// www.shenzhenwholesale.com
we have some electronics ,for example Microsoft Xbox360 Live card 10000 US PointsMoster beats by Dr.Dre solo hdMoster beats Dr.Dre pro and so on.
Welcome to visit our website
http://www.shenzhenelectronic.com/monster-beats-by-dr-dre-solo-hd-headphones-black-red-white-hot-sell_p53915.html
http://www.shenzhenelectronic.com/brand-new-monster-beats-by-dre-pro-headphones-in-white-black-5pcslot-hot-selling_p53932.html
Jul 11, 2011 | 2001 Ford Focus
Where is the fuse located in the fishman solo amp
The fuse is inside and if it blows, there is something wrong that caused the failure and MUST be repaired as just changing the fuse MAY do additional damage.
Jul 05, 2011 | Fishman SA220 Solo Performance System...
Why did one of my speakers stop playing i have 2 solo baric l7. i dnt think it's the speaker but i dnt know what it is help help help sos
Check the speaker fuse (inside Pwr Amp), try to connect to the other channel of the Power Amp, check RCA cable from source( Player) connection. There could be one channel of the power amp defected too
Apr 13, 2010 | Kicker Solo-Baric L7 S15L72 Car Subwoofer
Just installed new steam shower, it produces steam for about 5 minutes and then blows the fuse
Based from your comments, a new steam shower that blows the fuse in five minutes. You could have installed a new steam shower that is much bigger than what you previously have.
1. For a 5000 watts steam shower at 220 volts
power must have a fuse rating of 40 amps, supply
wires of at least No. 6 AWG Type THW ; and at
110 volts a fuse rating of 80Amps, supply wires
of at least No. 2 AWG type THW.
2. For a 4000 watts at 220 volts, Fuse: 30 amps,
Supply wire: No. 10 AWG type THW. At 110volts
60 amps, Supply wires : No. 4 AWG Type THW
3. For a 3000 watts at 220 volts, Fuse: 20 amps
Supply wire: No. 10 AWG type THW; At 110volts
Fuse: 40 amps, Supply wire: No. 6 AWG THW
4. For a 2000 watts at 220 volts, Fuse: 15 amps
Supply wire: No. 10 AWG THW and at 110 volts
Fuse: 30 amps, Supply wire: No, 8 AWG THW
Nov 27, 2009 | Hammering
For an 3 Tn unit- single phase- 220 V a.c and gfor
There should be a full load amps or rated load amps on each of these units on the rating or nameplate. The ampacity or fuse size and wire size, which I think that's what you are wanting to know . The fuse size would be full or rated load amps times 125% and the wire size depending on the length of the run, 50 feet or less, (15 amps 14 gauge wire), (20 amps 12 gauge), (30 amps 10 gauge), and (40 amps 8 gauge).
Aug 11, 2009 | Heating & Cooling
Just stopped
how many ohms are your amp and how many for yuor speakers?
Jan 31, 2008 | Kicker Solo-Baric L7 S15L72 Car Subwoofer
Fishman Sa220 Sa-220 Solo Performance Pa System Logo
37 people viewed this question
Top Fishman Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Fishman Audio Player and Recorder Expert? Answer questions, earn points and help others
