Question about Epson Office Equipment & Supplies
I have installed windows 7 32bit in my computer and I want to install my epson lx300+ printer but there is no driver for win7 can u help me
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 91 Answers
You should be able to use the win86 driver
Posted on Oct 22, 2013
acdr
  • 1913 Answers
SOURCE: i m unable to install the epson tm-u220 printer in windows 2003
http://www.barcodesinc.com/epson/tm-u220-drivers.htm
download driver and install from here
Posted on Jan 24, 2009
SOURCE: scanner not working cannot find scanner WINDOWS XP
Cannot scan  on IMac with Epson Stylus CX3900?
Posted on May 15, 2009
SOURCE: Epson printer TM U220 (User Intervention Required)
I spent a good week trying to find an answer to this problem... and finally I HAVE THE SOLUTION!!
it's to do with the Port settings.
go to BIOS and change the port settings on your computer.
there are a number of different options that can be selected, just try them one by one, the one that worked for me was "Normal" try that one first, but it may be differnet depending on the printer.
if your LPT port is using it's own driver (not using BIOS to run) you cant change the settings using the BIOS. see if you can change it useing the settings for the dirver. if not try updating the driver. if that doesn't work, and nothing else works, reinstall Windows, that should fix the problem as a last resort.
good luck.
Posted on Jul 23, 2009
  • 457 Answers
SOURCE: No drivers for Epson Stylus Photo 1200 printer for Windows 7
The driver for this printer comes with Windows 7. Use the "Add a Printer" wizard from Win 7 to install. After that, it should print fine.
Posted on Feb 10, 2010
Basti
  • 1447 Answers
SOURCE: Unable to install Epson TM-U220B[U220 with UB-U02III usb interface] on Windows 7 AND XP!
Hi!
Are you using a third party USB adapter or a USB interface? On the self test page that you printed does it say USB connection or something that will say about USB? or does it say parallel or serial connection? try to check the dip switches setting if its configured properly. visit epsonexperts.com site for more info.
Posted on Sep 20, 2012
EPSON L355
EPSON L355 EPSON Drivers and SW
Jan 27, 2014 | Epson Office Equipment & Supplies
The warnings worked with XP. Changed to Win 7 and now I get no warnings. Printer not printing and I cannot find why or see status of toners.
The warnings were provided by the Epson Status Monitor in XP. In Windows 7, you have a basic printer driver that doesn't include this monitor. Since the error lights do not give sufficient details as to the problem with consumables, it doesn't help much.
You could try to install the XP driver in Win7 using the compatibility mode. To try this, first uninstall the printer and disconnect the data cable (USB) then restart the computer. Download the driver from http://tech.epson.com.au/downloads/category.asp?sCategory=Laser&id=alc900&SelOS=Y (select XP 64-bit if you have Win7 64-bit) and right click on the installer. Then choose Properties and then the Compatibility tab. Turn on Run program as Compatible with the appropriate OS. Then right click again on the installer and choose Run as Administrator.
I do not know if this will work. A method that will work is to use a computer (virtual, dual-boot, or true second machine) with an older version of Windows installed. If you have Win7 Pro or Ultimate, you can create a virtual XP computer for free. Download and install Virtual PC and XP mode from Microsoft. Install them in order. Then install the XP software from the above site in the virtual computer and connect the printer and it will work. Please note that the printer will have to be removed from the Win7 devices list for this to work. (Other virtual computer programs are Parallels and VMWare.) All of the other options will require a licensed version of the older Windows OS. Also note that the virtual computer can't share files directly with the main computer. You'll need to save files to external or removable media (optical media or flash drive, for example) to share them.
I hope this helps.
Mar 27, 2011 | Epson AcuLaser C900 Printer
How to install the epson stylus TX100 scanner to my computer?
What OS does your computer have? Go to the Epson support site and download the software for your OS: http://tech.epson.com.au/downloads/category.asp?sCategory=Multi_Functional&id=StylusTX100&EmailAdd=&CanEmail=&SelOS=Y&MetricIDReturned=4036965&sCategory1=Multi_Functional and use the drop down menu to choose your OS. (With Windows 7, I know that the drivers are included in the OS so you can skip this step.)
For best results use a direct connection, with a USB cable that is 6' long or shorter.
Install the full software if it is available for your OS. Then when prompted to do so, make sure the printer is on and connect the USB cable between the printer and the computer. If needed, restart the computer.
In the case of Win7 or any other OS with these drivers included, just set up the printer and plug in the data cable. However, if the drivers are not included in the OS, then the printer may work after plugging in the data cable but the scanner probably won't. In that case, uninstall the generic driver, unplug the data cable. Then reboot the computer and install the one from the Epson site.
See the Epson support site for using the printer's software package. Please note that the buttons on the front of the unit will not work for initiating actions on the computer unless the full software is installed. Thus for Windows 7, you will need to launch your scans from the computer. Paint, Windows Fax and Scan and Photo Gallery (in Live Essentials) all can acquire scans. Some of these programs are also available for and will acquire scans in XP and Vista. (Paint is in XP, Vista and Win7; Photo Gallery comes with Vista and is available for XP and Win7; Fax and Scan is in some versions of Vista.)
I hope this helps.
Mar 16, 2011 | Office Equipment & Supplies
I have bafo 1284 usb to parallel adapter and Epson LX300 printer os is windows xp with sp2 my usb adapter detect but printer not printing what i can do this problem plz tell me
Please make sure that the printer is properly installed in your system. go to Printer and faxes " Start- Printer and faxes" check if your LX300 is installed there and ready. and the reply to me to assists you more
Dec 02, 2010 | BafoTech BAFO BF-1284 Parallel Adapter
Windows 7 (64-bit), does not accept the printer & scaner of epson stylus cx3700 why ?
The printer install disk probably does not support the Windows 7 64-bit operating system, perhaps not even the Win7 32-bit os. Go to the following link; http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?BV_UseBVCookie=yes&oid=58604&prodoid=58654752&infoType=Downloads&platform=Windows
This link is for the Epson Stylus CX3800; there was no listing for the CX3700
Download the 64-bit driver and double-click it to install
Oct 15, 2010 | Epson Stylus CX3700 Series
I need epson lx300 driver
1st You download Printer Driver. Epson LX Printer Driver After this install the Printer driver in the system.
Installation of Printer Driver
  • Go to the control panel
  • Click on the System Icon
  • Click on the Hardware Tab
  • Click on the Device Manager then
  • Select the Unknown Device or printer device where yellow Question Marks sign on it.
  • Right click on it and uninstall it.
  • After this go to the top of the device manager and click on scan for hardware changes.
  • Driver installation Wizard start.
  • Brows Your Driver from the Hard Disk and click on next.
  • Driver will be install.
May 09, 2010 | Epson LX-300 Matrix Printer
I am trying to instal a driver for an epson lx300 dot matrix printer on a windows xp operating system but can't seem to find the right driver. Anyone got any ideas?
1) Go to below website and download the latest drivers from there.
http://www.epson.com.sg/epson/drivers/driver_download.htm?mode=3&catid=2&productModel=2&catid=&pid=985&ad=1&downloadType=Windows
2) Before you Install new Drivers please remove old drivers for the printer and give a reboot to the computer.
3) After giving a reboot to the computer install the latest drivers those have been downloaded and then give a reboot to your computer again.
This will work in a perfect manner. Best of luck.
Feb 25, 2010 | Office Equipment & Supplies
EPSON LQ 1070+ PRINTER DON´T WORK ON WINDOWS 7
Unfortunately, no Win7 drivers exist for this printer.
You are better off running a Win98 or XP virtual machine on Win7 (like in VMWare), and installing your printer that way. There's no guarantee that would work, but it's at least one more thing to try.
Good Luck!
Jan 23, 2010 | Epson LQ 1070+ Matrix Printer
Where can Iget drivers / software to use my RX620
Windows 7 will install its own driver for your Epson printer. If you have connected the USB cable, disconnect it for now.
With your computer on, power on your printer. Now plug in the USB cable. Win7 will automatically install a driver for your printer.
The Win7 compatible TWAIN driver and Epson Scan Utility software can be download from Epson support:
Epson Stylus Photo RX620 Downloads
Be sure to choose the file(s) for your Win7 version.
Jan 11, 2010 | Epson Stylus Photo RX620 All-In-One InkJet...
Epson lx300+ii with serial port to fujitsu pc
use the com1, and use a baud rate like 9600, with 8 and 1 bit stop. dont. be sure that is in ESC/P or IBM as you requiered. if your software use directly the serial port, be sure that the bios set up is properly. i think that the lx300+ have less buffer than lx300+2
and if you use high speed, could loose info.
Jan 28, 2008 | Epson LX-300+ II Matrix Printer
11 people viewed this question
Top Epson Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
