Question about Dualit Kitchen Appliances - Others
Termostat switch NEed new
I put in a new water pump. New thermostat. Put in my coolant but the coolant isn't pumping around n the car is over heating. Can any one help
Try removing the termostat and run without.
if it cools Down you have Wrong termostat.
if not you have a blown headgasget.
br
soren Halling,
Jan 14, 2016 | Cars & Trucks
Termostat
What's your model number?
Apr 11, 2014 | Whirlpool Dryers
Location of the termostat on a 2001 catera
its under the top part of that intake right behind the timing case. for some reason they felt the need to hide it
Apr 18, 2013 | 2001 Cadillac Catera
How to change thermostat
The Termostat fit inside the Termostat Housing. It normally links to one of the radiator hoses leading from the engine block or radiator. Depending on the model you have, the termostat housing needs to be opened, the old termostat removed and the new termostat inserted. It's quiet simple. Before closing up, make sure that the both surfaces on the housing are clean and free from dirt and old sealant. If you remove a gasket, then replace with new gasket. If the housing takes a rubber O ring, then it is advisable to replace this.
Good Luck
Dec 29, 2011 | 2004 GMC Yukon
Is over heating, has new ratiator, termostat, hoses, sensor in the termostat and still over heating
Does the electric fan work...if not the thermatic sensor is faulty, quite common.
Oct 15, 2010 | 1999 Honda Civic
My GE Spectra heating element caught on fire today and completely disintergrated. Is this common?
IT CAN BE IF THE ELEMENT HAS NOT BEEN REPLACED FOR A LONG TIME AND IT SOUNDS LIKE THE TERMOSTATS HAVE FAILD SO REPLACE ELEMENTS AND TERMOSTATS AND YOUR OVEN WILL HAVE A NEW LIFE .
Nov 11, 2009 | GE Spectra JBP78 Electric Kitchen Range
Need to replace thermostat
USING A PAIR OF PLIERS RELEASE HOSE CLIP AND DISCONNECT THE HOSE FROM THE THERMOSTAT HOUSING LOOSEN AND REMOVE THE THERMOSTAT COVER BOLTS AND CAREFULLY THE TERMOSTAT COVER AND WITHDRAW THE TERMOSTAT FROM HOUSING REPLACE NEW TERMOSTAT ,RE FITTING IS THE REVERSE OF THE REMOVAL, BEARING IN MIND IN THE FOLLOWING POINTS ENSURE THAT THE THERMOSTAT IS CORRECTLY LOCATED IN THE HOUSING AND FIT A NEW SEALING RING .
Oct 24, 2009 | 1996 Volkswagen Passat
My Maytag Performa dryer is blowing out cold air. How can I fix it myself?
remove frt cvr,then top then remove drum belt and drum, check for open heater element, defective thermal fuse,hi-limit switch, open neutral to element if it uses the neutral connection
Oct 18, 2009 | Maytag 7.0 Cu. Ft. Electric Dryer
Unit not coming on. air isn't getting cold
First check the breakers for the condensing unit (outside unit) and the disconect outside by the unit (could be a breaker ,a pull off/on switch or fuses)If its ok , you should have 220 ,240 volts to the unit contactor (you'll see it after removing the cover on the condensing unit).When the termostat is in the cold position and the temperature its set is lower than the one inside the house the contactor should be pulled in and give power to the compresor and the fan.But if the termostat is in the cooldest set and the blower inside the house works and the contactor in the condensing unit is not pull in the problem is in the termostat or in the low voltage wire.
Apr 24, 2009 | Heating & Cooling
Thermostat
You must to remove the timing belt to get to the engine thermostat.
The termostat is located behind the timing cover.
Acessing the termostat is not an easy tast, as you have to remove the timing belt to get at it.
If instead you are talking about the radiator fan termic switch, you find it mounted on radiator, where fun wirings get plugged in.
Regards
Aug 29, 2008 | 1996 Audi A4
Kitchen Appliances - Others Logo
24 people viewed this question
Top Dualit Kitchen Appliances - Others Experts
Herve Boissonnault
Herve Boissonnault
Angel Joseph Jr.
Angel Joseph Jr.
Ross Keen
Are you a Dualit Kitchen Appliances - Other Expert? Answer questions, earn points and help others
